Swapping bars and aero bars
Quoted: 1069 Post(s)
Liked 788 Times
Likes For OldTryGuy:
Quoted: 4717 Post(s)
Liked 1,882 Times
I know you said you don’t want a bargain basement TT bike, but I’d look for an older 10spd Cervelo P2 or P3, without wheels. Tubular 10spd aero wheelsets are really cheap, and 10spd isn’t going to hold you back in any way. I’m sure you have a wheelset to use for training.
serious cyclist
Bikes: S1, R2, P2
Quoted: 9334 Post(s)
Liked 3,679 Times
Likes For Bah Humbug:
serious cyclist
Bikes: S1, R2, P2
Liked 3,679 Times
By contrast, my P2 saves 50 watts at the same speed vs my old S1, which is pretty aero for a roadie.
Likes For bruce19:
Quoted: 4560 Post(s)
Liked 2,803 Times
For the seatpost situation you might want to consider https://redshiftsports.com/dual-position-seatpost as this lets you easily swap between positions.
Although as other folks pointed out, good used TT bikes are often available pretty cheaply. I guess folks either get upgrade fever or just get tired of the whole tri thing. But I see more bargains in TT bikes than comparable road bikes.
Likes For canklecat:
Bikes: Speedvagen Steel
Quoted: 429 Post(s)
Liked 248 Times
That's darned clever. I might try one if I get serious about tackling a time trial later this year.
serious cyclist
Bikes: S1, R2, P2
Liked 3,679 Times
Every year there’s a new wunderbike. Some of us need to buy it every year. I’m running a NOS 2016 P2 retrofitted with UI2, and would probably only swap it if I got serious about doing fulls and wanted more integrated storage.
Liked 2,803 Times
This thread reminded me, I had a project bike tucked away that I hadn't really looked at. A friend is into the tri-thing and is an expert bargain hunter. He has persistent problems in the sit-down region and had been scouring craigslist and other sites for better saddles. He snagged an older Trek Equinox, one of their entry level aero frames that's well designed but quite heavy aluminum. It had a cracked seat tube, probably not dangerous where it's located. But he only wanted the Cobb saddle. The entire bike cost less than a new Cobb. He gave me the rest of the bike to scavenge for parts. I didn't even look at it right away, figuring it was all entry level stuff considering it was Trek's base model Equinox from around a decade ago. But when I finally got around to stripping it, I discovered the previous owner had upgraded to some really nice components, including some Dura Ace goodies.
And I also have a 2014 era Diamondback Podium 5 frame and fork with only the original Ultegra crankset. I wasn't sure what to do with it (I'm pretty satisfied with my old '89 Ironman steelie and '93 Trek 5900). But now I might cobble together a hybrid road/TT bike from that Diamondback frame and parts from the Trek tri-bike. It'll probably look goofy with bullhorn bars and Profile carbon fiber aero bars, but I'm gonna give it a try.
Couldn't be any worse than the old school Scott bars on my Ironman. There's no way to adjust the arm rests on the older Scott bars to support my elbows and get the upper arms vertical. Best I can do is place the armrests under the forearms just in front of the elbows with some angle to the upper arms. And I've set up a compromise fit that's not terribly uncomfortable in the aero bars, while still being able to pedal more or less normally using the drop bar -- if I don't mind the Jacques Anquetil toe-down style. Maitre Jacques was always my favorite of the TdF heroes, as much for his libertine lifestyle as for his cycling. And a friend who owns many local KOMs happens to ride that toe-down style. Looks oddly graceful and sure works for him. I suspect it's uncomfortable on longer rides and best suited to time trials and short, fast rides. It sorta forces us to sit heavily in the saddle. But it may take awhile to strengthen those lower leg muscles that don't get used as much with more flat footed pedaling.
Globo Gym lifetime member
Bikes: Fast ones
Quoted: 410 Post(s)
Liked 614 Times
canklecat I'd take that frame to a Trek dealer and see what Trek has to say about warrantying it. I bought some hella old Bontrager carbon wheels for $50 about 7 years ago that had a cracked rim and Trek warrantied them for a brand new set of Aeolus full carbon hoops.
Worth a shot.
Worth a shot.
