Decisions
Quoted: 1743 Post(s)
Liked 1,281 Times
Be aware that the Canyon Ultimate comes with an integrated cockpit which makes adjusting your reach quite difficult. You can't just swap in a different length stem. So triple check the measurements and make sure the bike *really* fits. Of course, that's an extra challenge without a test ride.
You'd need to be more specific for that statement to be of any value. All brands now list stack and reach and they should list the stem length and bar reach on complete bikes with integrated bars. If all that is available, there should not be any problems.
Likes For DaveSSS:
Quoted: 77 Post(s)
Liked 88 Times
By the way, I have a fondness for Pinarellos Beautiful bikes..
Bikes: 2022 Salsa Beargrease Carbon Deore 11, 2020 Salsa Warbird GRX 600, 2020 Canyon Ultimate CF SLX disc 9.0 Di2, 2020 Catrike Eola, 2016 Masi cxgr, 2011, Felt F3 Ltd, 2010 Trek 2.1, 2009 KHS Flite 220
Quoted: 4394 Post(s)
Liked 3,017 Times
Also, this doesn't contradict you at all, but FWIW, their sizes run large. I'm sort of between a Small and a Medium on the Ultimate, and making the Medium work, even though I'm squarely good with 56 cm frames in most other brands.
Quoted: 314 Post(s)
Liked 683 Times
Something in between. If you get the measurements right, there are no problems. Canyon's sizing and integrated cockpits mean that it's possible to fall in between sizes and not have good solutions.
Very true. I think you can specify different cockpit sizes now, but it's a pain.
I tend to be around a "medium" size or 52-54cm in most brands, but for Canyon I ride a small (Aeroad) and I measure up at the smaller end of their small.
Liked 1,281 Times
Well, Canyon uses the S-M-L sizing system. I find that this is not as precise as an actual frame size and virtual TT. For me a "square 55" is perfect. Their S size lists the frame as 50.3 but because of the sloping TT I don't really know what that is. Using stack and reach I would take a M but even then the numbers are a bit off. Same with S. So, using either system I don't fit in. Pinarello, Colnago, Basso, DeRosa, etc sizing is easier to understand.
Quoted: 3957 Post(s)
Liked 7,310 Times
Liked 1,281 Times
I will disagree but in this case I have looked at the geometry chart and, as I was trying to say, I am between their S-M sizes. I come much closer to perfect using numerical sizing. That's just the way it seems to work for me.
Liked 7,310 Times
"Numerical" sizing has nothing to do with it. One manufacturer just happens to size their bikes such that one works out right for you, and the other doesn't. It makes no difference if they call it 52-54-56, S-M-L, blue-green-red, or alpha-beta-gamma.
Liked 1,281 Times
FWIW Canyon offers 7 sizes and Pinarello offers 9. But,enough of this.
Yes, the number of sizes may vary between brands, but size numbers or letters mean absolutely nothing. You have to go straight to the stack and reach. I can figure out any brand in under a minute. Integrated models are stupid, for the most part. If you can't pick a stem length and bar reach, plan on having problems or getting lucky. When I buy a new frame I use the same Easton ec-90 bars I've used for many years and I know what stem and seatpost setback it should need. No surprises.
Quoted: 6199 Post(s)
Liked 4,816 Times
Letter sizes or centimeter sizes or however else you want to describe a bike size will make no difference as long as people have no idea what stack and reach they also want for their new bike.
Though many are similar in their geometries, there is no guaranty that a bike of size with one mfr will have the same reach and stack in the same size with another manufacturer. Some differ between models of the same manufacturer.
https://www.bikegeo.net/
Quoted: 769 Post(s)
Liked 1,748 Times
I'd loved to think this would be true, but just based on the hysteria they are doing over the current variant that seems to be pretty mild, I can't see the lock em down crowd loosening the reigns that fast as well as the supply chain catching up that fast either. However, I hold out hope of some recovery .... I have really grown beyond tired of the back and forth with this thing.
Newbie racer
Bikes: Propel, red is faster
Quoted: 1575 Post(s)
Liked 1,569 Times
On the cockpit, just had a user post on Slowtwitch they don't like the reach/width of their Canyon bars and it is integrated. They can't find a replacement right now, so are stuck.
Something to consider if you don't KNOW your fit coordinates. Otherwise, go get a nice bike fit with known coords you can give a shop and say "I have to have this frame and this handlebar/stem combo".
But this JUST came up with a user on that forum not finding a replacement handlebar.
