Why do my BOA shoes keep loosening?
Quoted: 4806 Post(s)
Liked 3,933 Times
Now, with dual BOA shoes, I'm guessing they'd ride fairly well with one BOA out, at least to finish that ride.
Likes For 79pmooney:
Quoted: 1110 Post(s)
Liked 1,204 Times
Why are these seen as better than velcro straps?
My velcro strap shoes last years and years without me having to do anything.
The idea of replacing a fat ratchet/buckle strap with an anorexic string of plastic fiber seems insane to begin with, even if they stay in place.
My bike helmet has one of these, too (Bontrager Wave Cell), and I have to tighten at least once per ride. Helmets should be set and forget. That seems like a design and safety flaw.
But I could change my mind depending on how these new shoes hold up.
Liked 2,981 Times
if the BOA is dirty, it can cause your issue.
IMO, BOAs reduces adding 15 years of age to the user, & helps prevent yelling at folks going across the lawn.
-Oh Hey!
-Oh Hey!
Likes For Troul:
ignominious poltroon
Quoted: 2245 Post(s)
Liked 3,448 Times
With a mighty wind
Quoted: 1089 Post(s)
Liked 871 Times
I find this thread very helpful.
I’ve had several Velcro shoes, and even more ratchet ones. I’ve had one failure ever, where the buckle literally ripped off the shoe. This was a 15 year old shoe. I managed a good ride with some scrap strap I found along the road.
If one person says the BOA slips and nobody else does, I don’t worry about that. But with so many people here saying the same thing to one degree or another, it actually makes shopping a lot easier for me.
I definitely need to retighten my shoes at about 15 minutes. They don’t slip but loosen up once I’ve warmed them up.
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2590 Post(s)
Liked 5,659 Times
I have two different pairs of Specialized shoes with BOAs. Both get a quick twist about 15 mins into each ride and then they are good for the duration. Since they can be tightened while still on the bike, its no big deal. One pair is 4 YO and the other 3 and have not experienced a failure. I like the system.
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
climber has-been
Quoted: 3432 Post(s)
Liked 3,567 Times
Likes For terrymorse:
Liked 3,448 Times
I think if I tried to tighten any shoe while riding, I would become horizontal rather quickly.
Liked 2,981 Times
-Oh Hey!
-Oh Hey!
Quoted: 41 Post(s)
Liked 11 Times
I do know you need to push them in before tightening. Tried after that, but they don't go in any further. The real problem is riding in the cold weather, since I can't tighten them when they're cover with booties. (Got them this past year, thought maybe they needed to be broken in.)
I forgot about my son having the same issue as I had. He replaced his S-Works Boa road shoes with Sidi after 4 failures of the BOA system. His Sidi shoes are now 2 seasons old and have not yet failed, which is 2 season better than the S-Works. Honestly, did the shoe lace need to be reinvented? Really, if you want the "even tension and micro adjustability" of laces, why not just get a lace up shoe?
I use the Sidi ratchet road shoes and have no issues with "micro adjustability" or getting "even tension" across the foot. What the marketing department is selling, a whole lot of folks are believing.
Habitual User
Quoted: 4957 Post(s)
Liked 8,100 Times
My Bonts (both road and MTB) usually need a click or 2 during my rides.
My favorite shoes were Shimano road shoes with 3 velcro straps from about 20 years ago.
Grupetto Bob
Liked 5,659 Times
I use insulated toe covers, which aren’t nearly as warm (today was 45* and cloudy and the toe covers worked fine) which allow me access to the BOAs if I need to.
Grupetto Bob
Liked 5,659 Times
Likes For rosefarts:
Quoted: 3243 Post(s)
Liked 2,092 Times
I just did an experiment with my Shimano's with BOA. I left them off my feet, tightened the BOA system, then put my hand inside the shoe and tried to press outward to see if the BOA loosened. They did not. I assume what I experience is the foot settles in after being on the bike and moving around from pedaling. Thus the foot position loosens up a bit inside the shoe and that what makes me feel like the BOA system is not staying tight. It is.
Thread Killer
Quoted: 3152 Post(s)
Liked 1,717 Times
Granted, as a relatively simple ratcheting system, it seems unlikely either of those mechanisms would be at play here; I’ve never looked at any the Boa mechs, so can’t venture an educated guess at the cause, but would also want to definitively rule out the equally unlikely cable stretch as a cause…unless people are reporting the cable actually, physically breaks, a scenario which would suggest a fatigue cycle.
Liked 3,933 Times
Haven't ripped out a BOA system yet. I have three pairs of formally strapped shoes that until the BOA were my go tos. (Three different cleat systems.) I love the Lake 268 BOA shoes and may well get two more pairs. If so, I will remove the lower BOAs of the fix gear pair and run laces so there is no knob right beside the buckle that I keep spinning and unlocking as I pull tight and loosen the toestraps.
