Can Stem Extend Slightly Higher Than Steerer?
Bought a new stem today for the rise but when I put it on, it extends a little under 1/2" from the top of the steerer. The stem cover and screw still had more than enough threads to tighten and everything feels tight and good but I was just wondering if this could be a problem over time? I do have a spacer beneath I could remove if I had to but I really like the height it's at now so I'd prefer to leave it. Thanks!
Unstated , I assume you mean a threadless steerer.. a steel steerer as long as the top bolt of the 2 on the back has something to grasp,
Stem, no higher than the center line of that bolt hole, you should be OK..
Carbon steerer, the whole stem , no higher than flush with the top of the steerer, add a 5 mm spacer above for the headset adjustment function .
Likes For fietsbob:
Non omnino gravis
If you have a carbon fork, the mfr. will tell you the absolute limits. My Cervelo wants the top of the stem 2-4mm above the top of the steerer, zero spacers above stem, and a max of 50mm below stem (bearing cap and spacers combined.)
Steel fork? Do whatever you want really, as long as the stem bolts aren't grabbing air.
Likes For DrIsotope:
Quoted: 1572 Post(s)
Liked 644 Times
So the top stem bolt isn't clamping against anything. Not something I'd do.
Likes For Retro Grouch:
Likes For andrewclaus:
Quoted: 336 Post(s)
Liked 309 Times
I play fast and loose with drivetrain specs (low consequence), I mix and match brakes and levers across series (redundant systems), and experiment with wheel sizes outside of a frame sets design parameters, but I don’t mess with the handlebar/steerer connection. The worst crashes I have seen and heard of are when the bars are in the rider’s hands, but don’t have control of the front wheel.
Likes For aggiegrads:
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,542 Times
If you need the bars that high, then the bike does not fit you. Switch to an endurance geometry frame with a taller head tube. Please a side view photo of the entire bike as you have it now?
Likes For easyupbug:
SE Wis
Quoted: 2751 Post(s)
Liked 3,407 Times
How about a picture so people aren't guessing?
Quoted: 2611 Post(s)
Liked 1,951 Times
Is there a spacer or two below the stem you can take out? I usually try to get no more than 5 mm of stem height above the steerer -- 1/2" (12 mm) sounds too high.
and still leave a gap for your top cap to pull down into ,..
There is a reason that you don’t see one-bolt stems on the market.
Quoted: 41 Post(s)
Liked 39 Times
1) I agree with the others re the risk of using the stem you just got , but
2) What was the situation with the previous stem; was it's coverage the the steerer enough less so that both bolts were supported ? If so, just measure it and get a new stem with the same measurement ( and the rise angle you need) rather than try some hack that may kill you...and rather than getting a new bike
PS :a year so so ago got a really nice 2003 K2 MOD 4.0 road bike that had an original one bolt alloy stem...it was the first thing to go
Yeah if I take out the spacer below it, it'll bring the stem even with the steerer top so I think I'll do that and order a higher angle stem to see if that makes it better
Likes For cougarkite:
I think the bike fits fine...Got a size L and I'm 6'. Just rather be biking pretty upright due to back issues. Also posted a picture!
Actually I just took out the spacer below and although they look pretty even, I think the steerer is ever so slightly higher and wont allow me to get pressure down when tightening cap screw and thus leaving my fork a bit loose so looks like I need to switch out some spacers ...
I bought a BBB BHP 21 stem raiser, & took out the star nut, there are others that clamp on the outside that use the star nut as it sits ,,
Likes For fietsbob:
