stoker handlebars
stoker handlebars
Old 09-02-22, 11:27 AM
Quoted: 22 Post(s)
Liked 18 Times in 13 Posts
I have similar Co-Motion stems on our Co-Motion quad that are for 26.0 bars. I’m sure the ones they sell _now_ are 31.8, but they definitely sold 26.0 in the past.
Rather than speculate, get yourself a cheap digital caliper and measure the stem and the bars: https://www.harborfreight.com/hand-t...per-63586.html
If it turns out that the stem is 26.0 and the bars are 31.8, don’t stress. The chrome portion of the stoker stem extension should be 28.6. Get an old stem out of your parts box that is 28.6 for the steerer and 31.8 for the bars and use that instead of the billet aluminum Co-Motion piece.
WheelsNT is offline
Old 09-02-22, 07:17 PM
Quoted: 80 Post(s)
Liked 39 Times in 32 Posts
I tried inserting the pinch bolt through the exit hole and inserting a penny into the slot. Maybe they don't make pennies like they used to. I removed the penny and tried a steel washer. It worked better. That said, those Profile Stoker bars are not interested in going through that stem. I don't have a caliper but will get one for future use. It's a moot point for the bars because, whatever the size of the bar hole in the stem, the bars are not going all the way through there. I put my trusty Staedtler circle template on the stem extension tube. It's 28.6mm. So, it looks like any standard stem with 31.8mm bars and 28.6 tube should work, right? I am looking at https://www.amazon.com/FOMTOR-Mounta...g%2C121&sr=1-5.
Shouldn't that work?
jethro00 is offline
Old 09-02-22, 08:20 PM
Quoted: 22 Post(s)
Looks good to me.
WheelsNT is offline
Old 09-03-22, 01:25 AM
Bikes: n, I would like n+1
Quoted: 127 Post(s)
Liked 133 Times in 108 Posts
While calipers are incredibly handy, and while cheap junky calipers are astoundingly good (this coming from someone who has more in his metrology gear than you do in your bike), you can tell those two diameters apart with a grade school ruler. Or by checking it against a know item, or by seeing if it’s bigger or smaller than your known size seatpost.
They really don’t make pennies like they used to, at least not like before 1982. That said, if you’re failing a penny you’re probably trying to spread the stem more than you should. Better the penny as a fuse than part of your stem.
So long as a stem has the appropriate length and diameters at the ends along with a reasonable angle, the rest is a matter of non-critical preference.
jccaclimber is offline
Old 09-05-22, 07:26 PM
Quoted: 80 Post(s)
I received the FOMTOR 31.8 Short Bike Stem Forged MTB Stem today. It does not fit. I had wondered what the “26” meant in the “Profile Designs Stoker 26 Bar” name. I just figured out the center of the bar is 26mm, not 31.8 mm like the stem I ordered. So, the Profile Stoker Bar is too big to make it through the one-piece billet aluminum Co-Motion piece and too small to be tightened into the 31.8 mm Bike Stem I ordered. Looks like I need a 2-piece bike stem with a smaller diameter.
jethro00 is offline
Old 09-05-22, 07:35 PM
Quoted: 80 Post(s)
Do I get the 25.4mm stem like this one?
https://www.amazon.com/dp/B08H4YHL6N/ref=emc_b_5_t
If so, does the 7 degrees angle really matter?
Thanks.
jethro00 is offline
Old 09-05-22, 08:01 PM
Bikes: 2004 Trek 520, resto-modded 1987 Cannondale SR400, rando-modded 1976 AD Vent Noir; 2019 Wabi Classic; 1989? Burley Duet
Quoted: 213 Post(s)
Liked 93 Times in 51 Posts
Thanks.
No, get a 26mm stem!
samkl is offline
Old 09-05-22, 08:47 PM
Quoted: 80 Post(s)
<<No, get a 26mm stem!>>
These exist somewhere? It seems odd that the common Profile Stoker Bars would be an uncommon size. I see a lot of 31.8mm and some 25.4 mm stems.But, I am not seeing 26mm stems.
jethro00 is offline
Old 09-05-22, 09:45 PM
Quoted: 22 Post(s)
Search 26.0 stem on amazon or ebay. There are plenty. 26.0 was the road bike standard before 31.8 became a thing. 25.4 was the MTB standard. 26.0 and 25.4 are not interchangeable.
WheelsNT is offline
Old 09-06-22, 08:27 AM
Quoted: 80 Post(s)
I found: Profile Designs Aris Bike.
https://www.amazon.com/Profile-Desig...-14&th=1&psc=1
That seems like it should work since the stem is made by Profile Designs who also makes the “Profile Designs Stoker 26 Bar.”
I can probably select a height based on the height of the bars for my stoker on our other tandems. I suspect the shortest length (60mm) is likely the best choice. But, how do I choose between 83 degrees and 115 degrees? Here is a picture of where the stem is going. Thanks for any suggestions.
jethro00 is offline
Old 09-06-22, 09:16 AM
Quoted: 80 Post(s)
<<26.0 was the road bike standard before 31.8 became a thing. 25.4 was the MTB standard.>>
Thanks for the history lesson
I suppose this is my first of many lessons on owning an older bike and using older components.
jethro00 is offline
Old 09-07-22, 05:00 PM
Quoted: 127 Post(s)
Some light reading:
https://www.sheldonbrown.com/cribsheet-handlebars.html
Old 09-08-22, 10:16 AM
Quoted: 80 Post(s)
<<Some light reading:
https://www.sheldonbrown.com/cribsheet-handlebars.html>>
That is interesting reading. If countries have had that much trouble agreeing on the diameter of bicycle handlebars, I guess it's not hard to see why world peace is so hard to come by
jethro00 is offline
Old 09-08-22, 10:41 AM
motochick's Avatar
Bikes: '80 Medici Tourismo, '82 Merckx, '85 Peugeot PSN10, '86 Ironman, '89 Trek 520, '96 Steelman, '96 Torelli CX, '97 Friday Two'sDay, '02 CoMo Speedster, '09 Giant Reign, '10 Canfield, '13 Turner DHR, '16 Chase BMX
Quoted: 40 Post(s)
Liked 256 Times in 51 Posts
I didn't read thru every single post but I have two sets of bullhorns from a CoMotion if want them. $10ea
motochick is offline
Old 09-08-22, 12:14 PM
Quoted: 80 Post(s)
<<I have two sets of bullhorns from a CoMotion if want them. $10ea>>
That probably would have worked. Alas, we already bought a new pair for my stoker. Thanks
anyway.
jethro00 is offline
Likes For jethro00:
Old 09-10-22, 03:54 AM
Quoted: 42 Post(s)
Liked 11 Times in 9 Posts
There are shims to allow use of a 26.0 bar with a 31.8 stem. I'm using one for our Profile stoker bar.
bwebel is offline
Old 09-10-22, 07:58 AM
Quoted: 80 Post(s)
<<There are shims to allow use of a 26.0 bar with a 31.8 stem. I'm using one for our Profile stoker bar.>>
We returned the 31.8 stem. Amazon has free returns which helps as we fumble our way through which bike parts we need/want. I ordered a Profile Designs Aris Bike Stem 83 degree 80NT for my stoker to go with her Profile Designs Stoker bars. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I ordered Profile Designs Rise Ultra FR Bar 60mm for me which should fit in my current stem. Hopefully, we are now set for our handlebars and stems.
We look forward to getting comfortable with our handlebars and riding the bike enough to see if our derrières will come to love the Brooks saddles that came with the bike. I keep reading how cyclists eventually come to love them after they are broken in. Our eyes love the look. But, our derrières remain undecided at this point
jethro00 is offline
Old 09-10-22, 01:01 PM
Bikes: N+1
Quoted: 229 Post(s)
Liked 652 Times in 319 Posts
Ha! Now do some reading on that website on tire and rim sizes and labeling, and be prepared to sigh deeply and mournfully. Standards? We don't need no stinking standards! I wish sizes of all sorts of bicycle things were standardized. Tried ordering a jersey recently?
JulesCW is offline
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
