Tire pressure loss due to heavy rider?
Quoted: 6972 Post(s)
Liked 10,970 Times
Just by attaching the floor pump (Bontrager dual charger pump). Interestingly enough my wife has the exact same tubeless tire (bough the bikes and had them converted the same time) and she is not heavy and all our tires after inflated to 50 go down a little right after the ride but within 24 hours go down to 40. They seem to hold at 40 but won't hold at 50 (even without riding). Guess fat me isn't causing this but could a bad seal be stopping it from staying at 50 but holding steady at 40?
Mad bike riding scientist
Quoted: 6220 Post(s)
Liked 4,221 Times
All kidding aside, if you have 4 tires that all behave the same way, you have the diffusion rate for your tires. It’s not a bad seal because that would require all 4 tires to have exactly the same problem which is highly unlikely. That’s just how much air your particular tire brand loses in about 24 hours. It’s perhaps a little high but it’s not outside of the range of expected losses. Most of us don’t actually track how much air is lost. We just pump them up before each ride.
Stuart Black
Stuart Black
Likes For cyccommute:
Quoted: 14 Post(s)
I top off before each ride - it is no big deal. But I was just trying to find out if my tires not holding at 50 but always holding at 40 was normal....plus the guy at the bike place inferred it was happening because of my weight (which I would have known was wrong if I had taken the pressure after the ride not the next day).
Half way there
Quoted: 987 Post(s)
Liked 880 Times
I really think that what you are seeing is an artifact of mounting the pump head on the tire. Assuming that you are adept at attaching the head to the valve without losing air, you have still added volume to the system, i.e. the pump head and tubing back to the check valve in the floor pump. As a consequence, the pressure of the tire/pump system will drop. You will lose some pressure due to diffusion but 10 psi overnight is a stretch.
Try this: Pump up your tires to 50 psi, then unmount the pump head. Remount the pump head and see what pressure you read. I bet it drops some.
Quoted: 14 Post(s)
Liked 10,970 Times
I did that and it stayed at 50. It is not the artifact of mounting the pump head on the tire. Just got back from another ride and only went down to around 47.....can guarantee you in 24 hours with no riding it will be down to 40. These tires just will not hold anything over 40 for more than 24 hours (even with no riding). When I check again after it gets to 40 they always stayed at 40.
Newbie here. I weigh around 235 pounds and ride a Trek Dual Sport 3 with Bontrager GR2 700C X 40MM tubeless tires. If I set my pressure at 50 psi after every ride (average ride is between 20 and 30 miles) it will go down to 40 psi. It doesn't matter if I am riding gravel or road - the exact thing happens (I usually set it lower for gravel but the times I did try 50 it went down to 40). When I asked the guy at the bike shop he told me I should not be at 50 and I should be at 40 and because of my weight it will lose air. Is this normal?
Tires do not significantly lose air because of your weight but rather because they sit overnight and lose air through the pores in the rubber that are a part of the material. Tubeless tires are significantly more expensive than clinchers as well. My experiments are over and while tubeless sounds good the air capacity of a bike tire is just too small to allow them to work well.
Quoted: 1820 Post(s)
Liked 1,696 Times
There are two kinds of "tubeless" - "tubeless" and "tubeless compatible". Tubeless tires have a heavier soft rubber bead on them that supposedly doesn't need sealant. Don't believe it. Although it does allow you to cleanly remove the tire they are a REAL pain in the butt. They are EXTREMELY difficult to mount on the newer Tubeless rims and i have destroyed 3 carbon aero rims trying to fit these things.
Expired Member
Quoted: 3674 Post(s)
Liked 5,441 Times
Find another person using the same tires and you are well on your way to a statistically significant result
Quoted: 14 Post(s)
It caught my attention and it makes sense but I am only allowed 5 posts per 24 hours so I cannot respond to all of them. If losing 10 PSI after 24 hours (without even riding) and losing no more after that is normal for these tires so be it.
Quoted: 14 Post(s)
Did you try any of the tips I referred to in Post #9 ? Just curious to know if they worked, assuming you tried them.
Liked 10,970 Times
Liked 4,221 Times
Pressure loss due to diffusion isn’t linear. You lose more pressure faster at 100 PSI than you do at 40 PSI. 10 PSI loss from 50 to 40PSI in 24 hours is a bit more than I’d expect but you have 4 tires that do the same thing so that’s what your leak rate is.
Stuart Black
Stuart Black
