Help me identfy my swap meet find
Hoards Thumbshifters
Bikes: '23 Black Mtn MC, '87 Bruce Gordon Chinook, '08 Jamis Aurora, '86 Trek 560, '97 Mongoose Rockadile, & '91 Trek 750
Quoted: 246 Post(s)
Liked 338 Times
I love these threads
Stop reading my posts!
Quoted: 1444 Post(s)
Liked 1,064 Times
Wow. Just Wow.
Again.
I recall when la Perle was first brought up in this forum and it was a decade ago! Long enough ago that I don't even recall the exact year, but it was a marque unknown to most of us at the time.
Again.
Quoted: 3814 Post(s)
Liked 3,345 Times
WOW!
DCI Maurice does it again.
Have a local collector friend who owns a 1950's La Perle in the same red flambouyant with cream trim livery as Maurice's example frame. Yet it failed to make a dent in me dull "braine."
WOW!
Bikes: Lots of French, some British and a couple of Italian
Quoted: 247 Post(s)
Liked 130 Times
Amazing work @MauriceMoss. Gobsmacking in fact.
verktyg
Quoted: 1036 Post(s)
Liked 1,238 Times
Early To Mid 60's La Perle Frame
@MauriceMoss
"We're not worthy, we're not worthy"!
Yes I agree, the OP's frame has all of the hallmarks of your La Perle.
Disregard the paint, it's an old respray.
I'd guess that the frame is from the early to mid 1960's.
The Campy drive side 1010 dropout has a spring hole for an uncommon low end Campy derailleur from the early 60's.
The hole was discontinued by the 1970's and the boss design changed to this.
Fish mouthed fork blades and rear stays were common on better quality French bikes for decades, not just on Bernard Carre frames. The process takes a little longer to do right so you don't see it on many less expensive frames.
The "dots" in the fork crown where the lower bearing race mounts were done with a punch to increase the diameter. Most French bikes used headsets with 27mm fork crown races. Campy and most non French headsets used 26.4mm or 26.5mm crown races. Common practice BITD.
The punch marks in the bottom bracket shell may have been put in to reduce the inside diameter size to compensate for loose threads so the cup fits tighter. Also a common practice.
Many quality French frames were made with very thin walled tubing - Reynolds 531, Vitus or some other French maker. Rene Herse and Singer made many frames with light gauge tubing.
On the other hand, who knows what kind or wall thickness tubing this frame is made of. I've seen quality French and Italian frames from that era made with heavy gas pipe tubes.
The standard Reynolds 531 tubing used up into the 80's had butted wall thicknesses of 1.0mm x 0.7mm in the 3 main tubes. Frames made with this thickness seat tubes would take a 26.4mm seatpost when they were properly rounded and reamed.
Light gauge Reynolds 531 would take a 26.6mm or even a 26.8mm seat post.
Straight gauge French carbon steel tubing usually used a 25.8mm seat tube.
The French rarely used straight gauge Reynolds 531.
Also, up through the 1970's bike boom fad, many quality French bikes came with frames made of butted Reynolds 531 main tubes and Durifort forks and rear stays.
Just because a frame has a small seatpost doesn't mean that it's made of cheap tubing. Frequently (as mentioned above) the seat tube is out of round or the seat lug "ears" have been overtightened to fit a smaller seatpost.
The first thing to check is the gap in the rear of the seat lug. When it's collapsed like this, the bike has an undersized seatpost.
The seat lug can be out of round or have a bulge inside.
There are ways to fix the problem but I'm not going to get into that here. First recommendation though is to round out the top of the seat tube before using a reamer or hone.
Hope this helps,
verktyg
Hope this helps,
verktyg
Chas. ;-)
Chas. ;-)
Likes For verktyg:
2-Wheeled Fool
Bikes: Surly Ogre, Brompton
Quoted: 1385 Post(s)
Liked 677 Times
I'm impressed with the knowledge and dedication to detail from all of the people here. I've been into bicycles since I was a kid in the '60's, and I thought that I knew it all. Yeah right. I'm stunned by the magnitude of experience here. I'm humbled.
Likes For J.Higgins:
Yes @MauriceMoss
I would say you hit the nail on the head. I am very excited to know so much history about this old frame. I assembled it just enough yesterday to ride around the neighborhood to confirm it is not bent. It rides and handles wonderfully and is a perfect size for me. Thanks to all who read and gave insight. Now I need to find some brakes with the anchor arm on the opposite side?
Likes For wschellen:
2-Wheeled Fool
Liked 677 Times
@wshellen, are you going to try to source a headbadge? Will you be trying to restore this bike to its former glory? I'm really smitten with the artistic qualities of this frame!
Yes I would like to try and restore it. Do you know a source for a headbadge? I agree it was the subtle "artistic qualities" that drew me to the frame. Now that I have ridden it and feel like it is in sound condition I will try and restore it. Thanks
Quoted: 5888 Post(s)
Liked 3,471 Times
Bikes: 48 Alleluia, 52 Blondin, 57 Cattaneo, 68 CNC, 55 Dujay, 46 Herse, 76 Singer, 48 LeGreves, 55 Metropole, 62 Holdsworth Cyclone, 49 Carpenter, 55 Condor, 65 Masi Special, 81 Sequoia, 76 Eisentraut, 72 Proteus, 60 Paramount, 77 Trek TX700, 82 Ross
Quoted: 79 Post(s)
Liked 137 Times
For the stated frame weight of 4.25 lb, I would be surprised if the ID of the seat tube is not 26.8mm if you measure it about two or three inches down from the seat lug. Normally a seat post of 26.6mm would be used in this gauge of seat tube. The tubing is probably Vitus, which is usually indicated by a stamping in the steerer tube.
feros ferio
Quoted: 1393 Post(s)
Liked 1,329 Times
Another highly educational thread, and great solution to a mystery. My helmet is off to you guys.
Old fart
Quoted: 3590 Post(s)
Liked 3,401 Times
I can't explain the letters and numbers, but the divots on the drive side are likely staking to prevent the French-thread fixed cup from loosening over time.
Liked 3,345 Times
A La Perle road machine of 1953 as displayed at an exhibition -
Dating -
agree with Chas. that frame appears "'60's"
as Maurice mentioned, La Perle nominally folded tent in 1955 yet La Perle cycles continued to show up from the later 1950's and into the 1960's
perhaps CR list readers will be able to check on this and see if it has been discussed by Norris...
one of the features which makes me think '60's is the presence of the housing stops on the downtube for fingertip cables. the height of popularity for fingertips in road racing seems to have been reached in the mid-1960's.
Dating -
Thanks for the photos. I like that red and cream color, I think that is what I will try and replicate. Those pin stripes though??? Anyone have experience trying that? I have painted several frames now and have been happy with the results, but I have never tried pin striping. As for the dating, since no one will probably ever know for sure I am going to say 1963. That year is special to me.
Liked 3,345 Times
Here is another example of the red with cream livery; once again earlier than subject frameset.
As found by enthusiast -
Following disassembly, cleaning & refurbishment -
[pedals, saddle top and rear mech changed]
Reading this thread I realize again that every person posting on it had forgot more about bikes than I know.
New data and new photos
Sand blasted the fork today and found the words REYNOLDS BUTTED half way up the steer tube. It looks like the word REYNOLDS is proceeded by a fractional number starting with 16/ and the word BUTTED is followed by more letters that I can not quite make out, maybe HM or HV ??? I tried to photo it, but it was to faint to capture with my camera. I did get a few shots of those lovely dropout joints and fork crown though.
Liked 3,345 Times
Thanks so much for this update.
Wonderful to see things moving forward.
Lest readers think all La Perle cycles red I did come across a blue and a green...
Advert of 1950 -
Advert of 1950 -
Wow I really dig that blue La Perle, it even has cantilever bosses. Maybe my bike should be a nice French Blue with Cream color panels. Thanks for the photos.
Quoted: 79 Post(s)
Liked 137 Times
Likes For Duke7777:
Looks incredible. Did you do the lines around the lugs freehand? Is a zap strap the same as a zip tie? I would love to see more pictures of your actual process to make sure I understand. Thanks for the photos.
Quoted: 79 Post(s)
Liked 137 Times
I also invented this clever-looking little sled. It guides the pinstriping brush handle in a perfectly straight line along the tube, using the aluminum angle as a guide. Unfortunately, it utterly fails to make a straight or uniform pinstripe!
Likes For Duke7777:
