Are bike shoes really necessary?
contrarian
Bikes: 80's ross road bike/commuter, 80's team miyata, 90's haro mtb xtracycle conversion, koga mitaya world traveler
You at least need a stiff sole shoe (no matter what kind) for you are going to put some miles in. It took me 8 months of riding before I went clip-in.
Higher ground for the apocalypse!
Work hard, Play hard
Bikes: Cannondale super V 500, Bianchi Piaggio(hopefully getting a new road bike when I get some money)
Originally Posted by Rowan
You've obviously been lucky first up.
Cycling shoes, as a generic term, are *not* a solution to hot-foot or hot-spots and can actually cause them. I speak from PE.
My old tennis shoes and platforms used to give me hot-spots. Hurt like hell after 15miles.
I know that the shoes can cause hot-spots if they aren't the right size/shape for you're feet. Your probably right, I just got lucky
Friar
Bikes: Mutant Huffy six speed, Garage Sale Deluxe Cannondale HB-200 Modified Glintmaster
I have an old six speed bike with platform pedals. I ride for exercise and to lose weight, etc. About 16 to 40 miles a day when I can ride.
Discovered I needed better shoes when reading about solid soled shoes here on forums. Being a cheap bastard by nature I deccided to make my own stiff soled shoes.
Scrounged around in shed and found some 3/16 inch aluminum plate.
Dug up old Dr. Scholls shoe inserts and used those for a template.
Cut out nice stiff shoe inserts with handy dandy sabre saw.
Did some custom hammering to get foot 'arc' just so and some fine tuning with hammer later and now have some spiffy FIRM soled tennis shoes. I tossed a store bought foam pad on top of the inserts for a bit of cushion. WOrkie great.
Added bonus I can remove the inserts if I desire in case I need to flee the scene on foot.
Likes For UziBeatle:
LOL Nice work Uzi.
You should try and make something so you can bolt on cleats. Thats another advantage of the clipless pedals, you can pull up so you get a bit more energy out of every pedal stroke.
SPD = Shimano Pedaling Dynamics. It refers to Shimano's proprietary clipless system but every manufacturer has their own clipless system.
Bike shoes are not necessary but I love mine. I love riding clipless and I also like the stiffness of the sole which is far more comfortable (less foot fatigue). I have a pair of "casual" cummuter bike shoes w/SPD but even on my commute I prefer my MTB shoes which are far stiffer. I haven't purchased roadie shoes though, because they are pretty useless off bike for walking around in. My MTB shoes have the right amount of stiffness and I use them on my road bike as well.
Bikes: Trek Fuel 98
For serious road cycling and XC riding, clipless is the only way to go, in my opinion. Which means you need bike shoes, of course.
I used to ride on platforms for several years and I cannot tell you how many times I got bounced off the pedals in rough, technical climbs, only to bang my shins or calfs. With clipless, I can spin like crazy while bouncing all over rocks and roots.
I'm made of earth!
Bikes: KTM Macina 5 e-bike, Babboe Curve-E cargobike, Raleigh Aspen touring/off-road hybrid.
Quoted: 10 Post(s)
What's an example of a clipless system?
Specialized Member
Bikes: 2004 Specialized Allez
i currently own a set of shimano frog pedals and a 2003 pair of specialized mountain shoes but because of the amount of commuting i do vs the amount of riding i do i had to take the clipless pedals off and replace them with toestraps so i could ride with normal shoes. when i go on rides i just use the cycling shoes in the toe straps and that seems to work out pretty good.
You can never be too Specialized
Click here if any of the following apply to you:
1 You dont like Specialized, 2 You drive a SUV, 3 Your name is George Bush
Usually when people say clipless system they are talking about pedals + shoes + cleats. Atleast I am anyway...
Edit: Chanman, you mean speedplay frogs? Shimano makes SPD's, speedplay makes frogs, zeros, x-2, x-3 etc.
Bikes: Trek Fuel 98
My "clipless" system is: Shimano SPD shoes, Eggbeater Candy SL pedals and cleats. The Candy SL cleats that come with the pedals are SPD compatible, of course.
Brick Snotshoulders
Originally Posted by Dahon.Steve
Does anyone know of a pair of SPDs that don't make noise every time you walk on the sidewalk?
Chairman of the Bored
Bikes: 2004 Raleigh Talus, 2001 Motobecane Vent Noir (Custom build for heavy riders)
my SPDs make a grinding noise on uneven pavement, but oh well. I just try to make sure I dont walk with em on wood floors though, that's just rude.
Bike shoes will definitely help you to be a much more efficient rider for many reasons, but in the interest of keeping things simple most biking shoes have a much stiffer sole than your tennis shoes do. This makes them transfer energy to your pedals more efficiently, particularly if they are used in conjunction with a clipless pedal. Additionally, I would encourage you to buy your shoes on the small side (not painfully) to reduce the amount of "slop" that you may feel if your shoes are too big.
Mountain bike shoes have the cleat mount recessed so that the cleat does not scrape the ground when you are walking around, so unless you are a high level road biker you may want to consider those as an alternative. There are road cleats from Shimano that have pontoons on them for use on road shoes that will make them a little easier to walk around in.
Hope that helps.
Hope that helps.
Just like to ride!
Bikes: TREK and Gary Fisher
I think they are worth it but I just had my first serious accident using them so be very careful. I haven't been on them since but will try it again because I estimate you're about 15% more efficient. I'm still looking for shoes where the cleat doesn't hit the street with every step. Does anyone know of a pair of SPDs that don't make noise every time you walk on the sidewalk?
https://www.mtbr.com/reviews/Shoes/product_86571.shtml
These are light weight MTB shoes. I have been using a pair for road cycling for 3 years. They are comfortable and have a recesed SPD cleat. I also have road shoes but typically wear these most of the time. Not as asteticly pleasing as high end road shoes and lace up vs straps.
Bikes: Road, MTB, Folding, Commuting bikes...
I'm surprised no one has brought up weight issues. Is the clipless system lighter?
Also I thought there were a bunch of bones in your feet - my feet don't flop up when I push down on my pedal!
I'm guessing for recreational type riders clipless (and 95% of the other stuff that's out there) won't make a noticeable difference but for those of you that are good enough to have found the limits of their equipment it probably will.
senile member
Bikes: 1 mtb converted for commuting (actually, collecting dust in the garage), a LHT with "durable components"
lighter than wearing hiking boots and using plateforms.
it does make a big difference, i´m not a pro nor anywhere close, but i do find it greatly improves my paddling efficiency.
Immoderator
Bikes: Gary Fisher Simple City 8, Litespeed Obed
Is paddling really a cycling term that I'm unaware of, or do tons of people on these forums mis-spell "pedaling"? Not bein' a smartass, just wantin' to know.
Originally Posted by Bikeforums
Your rights end where another poster's feelings begin.
senile member
oops, my mistake, sorry.
as far as my "system" goes: performance ForteII shoes, SPD single-release cleats, Shimano M-505 pedals. Very low-dollar, yet very effective.
On my around town bike, I have toe clips...I find those wear out shoes very quickly...Since platform pedals are just for around town, guess w/o clipless-I would not get very far..
Can't imagine getting good traction on a serious climb with just platform pedals... If limited to platform pedals, sure my annual mileage would go from over 6000 miles to under 250 .
oddly most of my yearly mileage this year was on platforms with half-clips. But clipless made me capable of doing harder things without as much drama, that's for sure....I wouldnt try to climb anyhting as steep as some of the SJ, cali overpasses without them.
Living in states' as flat as Florida, I can understand why one would be able to get by w/0 clipless...No challenges unless you are speeding like 20 plus mph...But, then hurricane force gale winds can add a need to speed up the cadence due to resistance.
Now, climb 1200 feet in less than a mile and with platform pedals,the feet would be slipping off the pedals on the uptake.
In my little town , just to do an errand downtown I have to climb couple hundred feet...For my around the town errand bike I have "Powergrip" toe clips to get better traction on the climbs.
I used to live in sj cali, I moved here two weeks ago
I know climbs
I know climbs
Funny, Catonic..I lived in Sarasota, Fla. about 20 years ago...I would not have known climbs.. Hope you have some really , light weight jerseys...Heah, you are near some eally dedicated Bike Forum members...Can give you some direction to local bike culture.... Anxious to get your impresssions about bike paths/facilites for cyclists in California versus Florida.
