Getting a Sticky Ride Number off of the Helmet
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,098 Times
You want to be careful with that refusal to wear a number:
Quoted: 4560 Post(s)
Liked 2,804 Times
EPS -- basically, Styrofoam -- is the thicker shock absorbing inner layer. Do keep solvents away from that.
But the outer harder shell is polycarbonate and/or Aramid/Kevlar, resistant to most mild solvents. A cotton swab moistened with Goo Gone won't cause any problems for removing stickers or adhesive residue from the outer shell. Goo Gone is sold in recyclable plastic containers.
Regarding the non-UV resistant paints mentioned by POC, it's almost certain powdered pigments mixed into the polycarbonate, not a surface layer. But some fugitive pigments will probably fade under sun exposure. I have a POC Omne Air Spin that's mostly white, with a hi-viz orange rear-facing shell. The orange will probably fade eventually. The white probably won't, or won't be noticeable.
Airplanes, bikes, beer.
Bikes: Road bikes, mountain bikes, a cx bike, a gravel bike…
Quoted: 398 Post(s)
Liked 788 Times
I would have just left the number on the old helmet and used it as an excuse to buy a new one. Mmmmmm, new helmet....
Liked 5 Times
Be careful with the alcohol near eps, it will melt that foam. believe it or not, lighter fluid has diluted naptha and it will take that glue off without damage.
