Robin Hood Lenton Sports?
Well, you mentioned touring. If you plan on packing a lot of stuff for a big trip, hit it with all the aluminum that you want. If you're just going to ride it near-by, under 20 miles, think about leaving the steel. In my opinion, the steel components have a smoother function. In '67, Britain was making some nice alloy brake sets, bars and stem, so you can have authenticity and performance, too.
1991 PBP Anciens
Bikes: 1954 Robin Hood, 1964 Dunelt, 1968 Raleigh Superbe, 1969 Robin Hood, 197? Gitane, 1973 Raleigh SuperCourse, 1981 Miyata 710, 1990 Miyata 600GT, 2007 Rivendell Bleriot
Quoted: 65 Post(s)
Liked 307 Times
You might be surprised how well a 50 year old bike does on a long ride.
A little update on the RH Lenton Sports. I pulled a decent set of aluminum rimmed wheels with quick-release axles from a parts bike. I had to file the dropouts a bit to fit the larger axles, and I snipped the front fender stays open so they slip over the axle since the fork has no fender-mount lugs. Dia-Comp levers replaced the steel originals, and D-C side-pull calipers replace the Raleigh steel ones. I sourced a nice B17 saddle since the owner said "it came with a leather saddle but got wet and warped". I replaced the Huret Allivit RD with a Svelto from the same parts bike. Not a real upgrade I know, but it looks a bit lighter and is of the same period so I thought I'd try it. During a test-ride I noticed the pedals seem to be slightly bent. They are the common rat-trap types (Lyotards?) and I have another set from a bike I'm upgrading. I'll keep the steel bars and stem, as well as everything else stock. The frame is comfortable and rides nicely.
I know it's nothing historic, but it's still pretty unique and a good, vintage bike for my modest "collection".
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,055 Times
A little suggestion, next time file parallel flats on the axle instead of the frame. Axles are replaceable, frames less so.
Likes For clubman:
I had considered filing flats on the axles, but I really didn't have to take much out - maybe 0.5 mm at most - to get them to fit. Getting the flats 180 degrees opposite on the axles and then having to line up the flats to mount wheels every time was a bit more daunting.
Phyllo-buster
Liked 2,055 Times
It's actually simpler than is seems with a handfile and vice. Then if you find an original set of wheels you like you won't have any orientation problems or slippage.
Next time.
Next time.
Friendship is Magic
Bikes: old ones
Quoted: 26427 Post(s)
Liked 10,383 Times
You can probably see what I replaced with alloy just looking at the photo. I found the original wheels to be vexatious, so once I replaced those with something a little lighter/newer, I just decided to go with what felt right.
original
original
original
original
original
How it eventually turned out. I have since mounted fenders on it, but they are far from authentic originals.
Likes For 3alarmer:
Friendship is Magic
Bikes: old ones
Liked 10,383 Times
Likes For swampyankee2:
1991 PBP Anciens
Quoted: 65 Post(s)
Liked 307 Times
Right. I read the Raleigh LS was last sold in 1962. The Robin Hood version came later (mine's a '67) and is a Lenton Sports in name only, built on a standard Hi-ten Raleigh Sports frame. In fact, when I posted a pic on the Lenton Sports and Variations FB group, no one had ever heard of it. I imagine it was only marketed it as a Lenton Sports outside of England where the name wouldn't have such an expectation of performance.
Phyllo-buster
Liked 2,055 Times
England was blessed with high quality rides so of course, the faux LS's weren't made available. I think.
My first LS...wrong bars I think.
