Need flat handlebar advice
Quoted: 1873 Post(s)
Liked 692 Times
I have a new bike for the wife that we're turning into her get-around town bike. She can stand over it but it's a little long with dropbars. I'm thinking a flat bar conversion would be appropriate.
Bike in question:
So you can see what I'm working with. Canti brakes, ~100mm stem. What's the cheapest way to get what I'm after?
Can I find a flat bar that fits the quill stem, and then turn the brake levers sideways and use them?
Also, the schrader valves are the pits. How can I use presta valves with these wheels?
Bike in question:
2019 Salsa Warbird
2019 Salsa Warbird
That's a nice bike and great for the purpose. I use porteur/moustache style bars for my get-around-town bike they've got a nice sweep back to them so you can use the drop levers on the curved part. That being said I use flat bar levers on it anyway since then I can sit fairly upright and keep my hands far back on the bars (near the bar-end shifters) while I ride. You should be able to use presta valves with wheels drilled for schrader no problem.
Cheapest (aside from just rotating bars back ) would be swap in a used cockpit. I have this one- unfortunately 3x9.
I.C.
I.C.
Bikes: Bianchi Volpe, ANT 3-speed roadster, New Albion Privateer singlespeed, Raleigh One Way singlespeed, Raleigh Professional "retro roadie" rebuild, 198? Fuji(?) franken-5-speed, 1937 Raleigh Tourist, 1952 Raleigh Sports, 1966 Raleigh Sports step-through
Quoted: 248 Post(s)
Liked 27 Times
Alternative option: shorter stem and compact drop bar
If she wants drop bars, but the reach is too long, why not just swap to a shorter stem?
If she doesn't want drop bars, why does the bike have drop bars?
Bikes: 1984 Miyata 310, 1986 Schwinn Sierra, 2011 Jamis Quest, 1980 Peugeot TH8 Tandem, 1992 Performance Parabola, 1987 Ross Mt. Hood, 1988 Schwinn LeTour, 1988 Trek 400T, 1981 Fuji S12-S LTD, 197? FW Evans
Quoted: 533 Post(s)
Liked 1,009 Times
You can get a Schrader to Presta adapter that fills the space around the valve hole for a few dollars.
Extraordinary Magnitude
Quoted: 2608 Post(s)
Liked 1,703 Times
Why do people dislike Schrader valves?
I don't care about Schrader vs. Presta- neither seems better or worse- if anything the Presta valves are more of a pain in the ass because you have to close them up after you're finished pumping, heck- they probably weigh more. I've read that people don't like the "larger hole" required for Schrader- but then are perfectly fine putting in Presta adapters... Is it that the "professionals" use Presta? or that boom bikes came with Schrader?
I just don't like having to switch my pump head over on my Leszyne pump.
Commence to jigglin’ huh?!?!
Quoted: 1136 Post(s)
Liked 650 Times
What's wrong with Schrader valves?
You're going to have to spend money to make the bike rideable and safe, so I would just accept that and not try to get away with kludges like drop bar brake levers on a flat bar. The bike will need new tires and brake pads at the least. New cables and housing to get the best function from the shifters and brakes. So might as well plop down a little money for some decent short pull flat bar levers.
If you search "Dia Compe flat bar levers" on eBay you'll get quite a few $20 options. I'm assuming that's a 26mm stem clamp so find a swept back flat bar with that clamp diameter. Velo Orange makes some good ones that are cheap.
If you got a 60 or 70mm long stem and compact drop bars like the Soma Highway 1, and swapped the brake levers for Tektro or Cane Creek ones, that would drastically reduce the reach and drop and make the brake hoods a viable hand position, allowing you to keep it a drop bar bike.
Liked 692 Times
The cheapest, easy route to flat bars would be to swap in a flat bar and a pair of brake levers. The current levers won't work with straight flat bars, since the curved levers will hit the bar before applying any significant braking force. If she also wants the shifting to be on the bars, then you would need a cable stop on the down tube and appropriate shift levers. Cable stops for mounting on that type of boss are hard to come by, but you could get a down tube clamp-on cable stop.
I have a pair of crosstop levers, the kind that run inline for cyclocross bikes, would those be appropriate by themselves on a flat bar for this bike? Not sure if the cable pull is correct for cantis..
2019 Salsa Warbird
2019 Salsa Warbird
Liked 650 Times
I dislike Schrader valves because they're incredibly hard to use with my pump. It could just be a bad valve/pump combo but it's literally almost impossible to air up the tires.
The diameter of a drop handlebar where brake levers mount is 23.8mm. The diameter of flat bars is 22.2. Your cyclocross inline levers probably have a 23.8mm clamp for drop bars, too big for the 22.2 of flat bars.
As far as cable pull, there are two kinds:
-Short pull: works with cantis, sidepulls, centerpulls, u-brakes, roller-cams, and "road"-labeled disc brakes.
-Long pull (aka "linear pull" or "direct pull"): works with V-brakes and "mtb"-labeled disc brakes.
Modern Campagnolo integrated brake/shift levers are short pull but have a slightly different cable pull ratio. They will work with any short pull brake but they will work better with Campagnolo-specific brakes. For example, Paul Components short pull disc brake is offered in a regular-short pull or Campagnolo-short pull version.
Liked 692 Times
Hmm, time for a new pump! My Park floor pump has no problem with either valve type.
2019 Salsa Warbird
2019 Salsa Warbird
Likes For shoota:
Liked 650 Times
Issues I see- you have a 130bcd Wolf Tooth ring. That triple on the Focus touring bike is probably a 110bcd or something smaller. So no go with that ring.
The Avid levers on the Salsa bars are probably long pull if they are from a fat bike with long pull disc brakes. So no go with the short pull cantis on the Focus. You would need to switch to V-brakes (long pull) to use those levers.
Liked 692 Times
I agree. I have a 1x setup on a city bike, also with a Wolf Tooth chainring. It works well
2019 Salsa Warbird
2019 Salsa Warbird
ambulatory senior
Quoted: 1956 Post(s)
Liked 3,662 Times
U can use ur cross levers on origin8 tiki bars, or use the original levers on the curves. The leverage with them mounted on the curves is awesome.
ambulatory senior
Liked 3,662 Times
ambulatory senior
Liked 3,662 Times
Tiki bars with drop levers.
Tiki bar with cross levers
Nitto's Mustache bars , have a wrist friendly slight downslope bend ,
where adopting 'northroad' bars like above are intended for as shown.. curving upward more steeply from the stem,
they're 22;2 diameter so Straight bar levers and grips will work too
A Trekking Bar setup can take road levers on the front too , or straight bar levers on the back, (open end)
Change stem to suit your comfort needs..
Bikes: 30's Speedwell Club Racer, 40's Speedwell 'Z' racer, 50's Unknown Aussie with nice lugs, 50's Speedwell Roadster, 50's Repco Roadster, '63 Raleigh DL-1, 70's Raleigh Sprite, Puch Promenade with Nexus 8
Quoted: 149 Post(s)
Liked 30 Times
I bought some alloy wheels from the local recyclers recently and they came with presta valves. There are 2 reasons that I know of why they might be preferred - one, they can hold more pressure, secondly they use a smaller sized valve hole that would suit a narrower rim. Once I've sold the bike I've put these on I'll have zero presta valves in my stable. Not because I don't like them, they just haven't been in the wheels I've usually come across. I do have a few sets of woods/dunlop valves in 642, 635 and 630 sizes. I only found out a couple of days ago the following piece of trivia: the tiny little rubber tube you used to/sometimes still do get in a patch kit, is a replacement valve tube for a woods/dunlop inner tube . Which means I'm kinda glad I didn't throw away the inner tubes I have with these valves, but I don't think I have any replacement tiny little rubber tubes coz I didn't know what they were for and have probably thrown them away. End of story.
Bikes: Indeed!
Quoted: 1508 Post(s)
Liked 3,481 Times
I have a pair of levers for 22.2 flat bars you can have. Send me a pm with your mailing address if you decide to go that route.
Brent
Brent
Quoted: 2364 Post(s)
Liked 1,751 Times
I'll bet the first thing she'll want is a relocation of the shifters. Nothing wrong with downtube shifters with drop bars, esp. if you're accustomed to them. But we tried a FBRB (flat bar road bike) setup for my wife a while back, retaining the DT shifters. I just didn't work out; we're reverting to a drop bar. There's another recent thread featuring a bike with this type of symmetric shifter boss, and a bolt-on adapter for extending cable housing upward. In that case, it was for stem shifters, but it could just as easily be used for bar-clamp or bar-end shifters.
In any event, save the original parts, in case you opt to sell it in the future.
Liked 692 Times
2019 Salsa Warbird
2019 Salsa Warbird
Quoted: 8 Post(s)
An old donor mountain bike of the rigt vintage have everything you need, stem, handlebar, levers and shifters. You can even go 6/7 speed indexed. The only thing extra needed is a clamp on cable stop to work around the downtube shifters.
Quoted: 8 Post(s)
An old donor mountain bike of the right vintage have everything you need, stem, handlebar, levers and shifters. You can even go 6/7 speed indexed. The only thing extra needed is a clamp on cable stop to work around the downtube shifters.
Bianchi Goddess
Quoted: 2938 Post(s)
Liked 2,934 Times
The actual drop section aside, will simply putting a set of wider flat bars actually change anything? I suspect she will be in better much the position on the grips of a flat bars as being on the hoods but maybe with her arms spread wider.
IMHO switching to flat bars or a bar with modest rise but leaving a regular road stem on the bike is almost pointless in most cases.
Sugar "Kane" Kowalczyk
Overdoing projects
Quoted: 784 Post(s)
Liked 1,238 Times
I'm building a bike with inverted North road bars in mind. They can be used for a shorter reach because they bend backwards more than moustache bars or they cane tilted down for a more aggressive stance. For shifting I plan on using Sunrace M9 friction thumb shifters. Very sturdy and affordable at $20 for a single one.
Otherwise I echo what other have said, mountainbike parts with a trigger shifter and matching derailleur.
