SS gravel = is it a thing?
Quoted: 586 Post(s)
Liked 612 Times
As for Surly, if 4130 Chromoly is not good enough for you, they go into the details https://surlybikes.com/info_hole/spe...bout_our_steel
I love my SS Steamroller and here are the frame spec's and geometry
https://surlybikes.com/bikes/steamroller
FRAME COMPATIBILITY Tubing: Surly 4130 CroMoly steel. Main triangle is double-butted. TIG-welded Rear dropouts: Investment cast Surly track dropouts, 120mm spaced Brake compatibility: Standard reach post-mount road calipers, but there are no stops for housing Braze-ons: Seat tube water bottle mounts cause we’re not camels. Eyelets at rear dropout. Change is eternal Seatpost diameter: 27.2mm Seatpost clamp diameter: 30.0mm Surly stainless, included Headset: 1-1/8˝ threadless Bottom bracket shell: 68mm wide, threaded English 1.37˝ x 24t Chainring clearance: Heavy manipulation of the chainstays gives room for a 50t ring while maintaining chainline. Track crank-compatible Fork: 4130 CroMoly, lugged and brazed flat crown that is drilled to accept a standard mid-reach (47–57mm) caliper brake. It has clearance for 700c x 38mm tires. Tire clearance: Room for tires up to 700c x 38mm. Individual tire and rim combos affect tire clearance, but figure on being able to use tires up to 32mm with fenders (p.s. use clip-on fenders) HEY YOU surlybikes.com
FORK COMPATIBILITY Stem clamp: 28.6mm Tire clearance: 700 x 38mm, individual tire and rim combos affect tire clearance Crown race: 30mm Brake compatibility: Standard reach post-mount road calipers, but there are no stops for housing Front spacing: 100mm Axle type: 9mm QR Braze-ons: None. Go home.
2k miles from the midwest
Quoted: 525 Post(s)
Liked 931 Times
This one sees gravel, single track, MUP, and dirt access trails on most of it's rides.
Likes For Dylansbob:
OwainGyndwr
"SS Gravel = is it a thing?
Yep, sure is.
Yep, sure is.
OwainGyndwr
Nothing you do can fully prepare you for that ride. Train hard. Especially your upper body and core. The hills are so true they're truth. They'll expose every pedal stroke you fudged. lol
Not lost wanderer.
Quoted: 890 Post(s)
Liked 1,011 Times
None of the above bikes look the least bit dirty, here in my Pure-Fix Cleveland
All my bikes end up on gravel sometime.
meh
Quoted: 1111 Post(s)
Liked 1,013 Times
Here's a pic from the 2021 DAMn - I rode with this group all morning, the rider on the front of this pic and rear are both SS, I'm off course the second rider, and the third rider is on a geared gravel bike (what a goofball?!?).
Footnote: Trenton (creator of The DAMn) test rode the Double DAMn course (495 miles in under 48 hours) on a SS bike
Edit: After a scroll through, SS gravel bikes are either old frames custom built, or a Minnesota brand of bike (Twin Six, Surly, All City ... )
Likes For Hypno Toad:
Likes For IAmSam:
Likes For thehammerdog:
Not lost wanderer.
Quoted: 890 Post(s)
Liked 1,011 Times
Likes For bwilli88:
I'd post mine, but having never posted here since 2015, I can't upload pictures.
The Walmart carbon Viathon G1 makes a nice singlespeed bike and can almost fit 50c tires (48s to be safe). The 425 chain stays allow for multiple different gear ratios without a tensioner. Maybe after 9 more posts, I'll put up a picture.
I also just built up a Factor Ostro VAM that fits 32s and I run that as a SS with 52/18 without a tensioner. The bike is butter smooth but doesn't offer the versatility of the ratios that the Viathon does. It's primarily going to be a all-road bike or race gravel bike.
if there's a SS category, i'm "IN"
after
before
after
before
Likes For sgtdirt:
I look forward to being able to post pictures after a few more posts but I bought a Wabi Thunder just about a year ago which has now seen about 2500 miles and quite a bit of ‘gravel’ mixed in there. As long as no loose steep climbs it’s all good and handles it like a champ!
Quoted: 2432 Post(s)
Liked 641 Times
i love Wabi frames. Before the Thunder I rode a classic for years and have nothing but good things to say about them. The only issues I’ve had has been corrosion in the free wheels and cranks (on the Classic) which might be expected considering I live on the coast and ride though the winter in New England.
Liked 641 Times
Likes For Lazyass:
I have to correct my post. I said I was going to buy a Special but I already have one. I meant a Thunder. And I just checked their last FB post and it's Special's and Lightning's they're expecting to get this winter, not Thunder's. I guess they expect those to arrive this spring so I'll have to wait awhile
Quoted: 7050 Post(s)
Liked 11,097 Times
Go to dannychew.com and check out The Pittsburgh Dirty Dozen. Long stated by Bicycling Magazine as the toughest sub 100 mile race in the world. 13 hills. 55 miles. The hills range from 21-38% gradient. Did it in 2009. Built a special Cdale SR300 1x8 38x12-30 w/dt shift. A guy named Montana Miller did it on fg. He was the first. Several others have done it since. 39×22 w/no freewheel decends. I rode with him and chatted a bit. Great guy and an animal on climbs. lol
Back on-topic: the gravel races around here often have 100+ feet of climbing per mile (e.g., 65 mile race with 7000+ feet of climbing), and there will always be a few people on SS bikes. One of my old riding buddies (much younger and stronger than me) sometimes races on a SS and clears climbs that force me to get off and walk alongside my 11sp bike.
Likes For LarrySellerz:
Liked 641 Times
So it appears the rear stays and fork and straight gauge. Heavier and rougher ride. I never looks at their specs before but given the price level and the weight of the bikes that sounds about right.
enginerd
set up for "gravel" but gearing was too high for the hills
same bike set up for cross
Likes For EnzoRWD:
Quoted: 2953 Post(s)
Liked 3,106 Times
Quoted: 1099 Post(s)
Liked 1,039 Times
https://www.poseidonbike.com/product...cross-frameset
They call it a tracklocross but the geometry is slacker then a real cross bike and it'll run a 40c tire in 700c so probably a stronger gravel than cross bike.
Quoted: 525 Post(s)
Liked 931 Times
That being said, it's looking like a perfect 650b fixed gear machine. I started out with some 650bx38, planning to run fenders and have a nice high bb. Just for fun, I installed some light 2.0 crosscountry tires and it looks awesome. tire clearance is a solid 4-5mm with the wheel in the middle.of the dropouts.
Oh yeah, at least on the new black ones the seatstay bridge isn't drilled. It's now a simple tube instead of the little cast number on the silver ones. Probably welded higher too.
