Handlebar stem removal
Bikes: 2013 Cannondale Caad 8, 2010 Opus Fidelio, 1985 Peugeot UO14, 1999 Peugeot Dune, Sakai Select, L'Avantage, 1971 Gitane Apache Standard, 1999 Specialized Hard Rock
Quoted: 548 Post(s)
Liked 473 Times
I've decided I don't want this light on the front stem any longer (batteries pop out over every bump) and don't want to put back the original reflector on it so I attempted to take it off. I unscrewed the hex nut keeping the reflector mount in and then unscrewed the quill stem(?) but it would not come out.
I don't really have any way of using leverage to give it a good pull and I gave it a few taps with the rubber mallet but that did nothing.
Any thoughts?
Any thoughts?
Quoted: 4513 Post(s)
Liked 6,388 Times
Any thoughts?
Any thoughts?
That being said, if you don't have a brass hammer or the like you can use a piece of aluminum to lessen the potential damage.
Assuming you knocked the wedge loose with bolt?
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3890 Post(s)
Liked 6,488 Times
Stem could be stuck. After you loosened it, did the stem bolt (and its wedge or expander) fall down when you hit it with the rubber mallet? If not, then there's your first problem. And do you have a dedicated headset wrench so you can adjust the headset after you have loosened the headset lock nut?
merziac ,
merziac ,
Quoted: 932 Post(s)
Liked 1,309 Times
Exactly what did you tap with the rubber mallet and in which direction did you tap? Do you realize that you should loosen (not remove) the bolt on top of the stem and then give it a sharp whack (not just a tap) downwards with a hammer (use a piece of wood to protect the finish) which should cause the expander wedge or cone on the bottom of the stem to release from the steerer tube. Pulling or hammering upwards on the stem before doing this will do exactly nothing.
If the above doesn't work, then you should search the forum for the many threads on freeing stems that are stuck due to corrosion.
Also, something that is of concern is that your photo shows a stem that appears to not have been inserted far enough into the steerer. This can cause the threads at the top of the steerer tube to become deformed and then to fail catastrophically, a very dangerous situation. Once you get the stem out you should check to ensure that the expander is located below the lowest threads on the steerer and if not you should get one of the available extended stems (Nitto makes a couple).
Likes For davester:
Quoted: 548 Post(s)
Liked 473 Times
Uggh, no and no. I didn't hit the stem to loosen the stem bolt because I don't have a dedicated headset wrench to adjust it. I'm too worried of damaging anything because I don't really have a collection of parts to replace it and most bike shops around here don't carry older stuff.
I guess I'll take it to the LBS and see if they have a good technique.
thanks
thanks
Liked 6,388 Times
merziac ,
merziac ,
Quoted: 932 Post(s)
Liked 1,309 Times
Likes For davester:
Quoted: 548 Post(s)
Liked 473 Times
I'm trying to learn how to work with these vintage bikes but damn, they are all unique and don't come with much of an owners manual ha ha
Quoted: 932 Post(s)
Liked 1,309 Times
The Park Tools website and Sheldon Brown's web pages have extensive descriptions and often videos and photos of pretty much anything you might want to do on a bike, vintage or otherwise. Way better than a manual. ...or, you could just ask here at bikeforums.
Likes For davester:
Quoted: 548 Post(s)
Liked 473 Times
I appreciate it Davestar and just thought maybe it was simpler than this. I'll check out the videos on youtube, RJ the bike guy is another good source. When this pandemic ends, hopefully I can get into the coops to get some hands on experience working on my older bikes.
señor miembro
Liked 6,488 Times
señor miembro
Liked 6,488 Times
Look at online pictures of a quill stem, its bolt, and its wedge/expander, so you will know how this system works. Sheldon Brown shows pics and all the information you need. Likely what happened is you pulled the bolt out, but the wedge/expander is still in place. I would thread the bolt back in place a little ways and then hammer it down with something soft like a wooden mallet, so I could remove the wedge/expander from the bottom of the stem.
Likes For SurferRosa:
Liked 6,388 Times
señor miembro
Liked 6,488 Times
Quoted: 1641 Post(s)
Liked 831 Times
Stems can definitely get as badly stuck to a steerer tube, just as bad as seatppsts do in seat tubes.
So, you could be in for a big, long fight to get it out.
Worst stock stem I had, took about a month to remove from my Vitus Carbone's steerer tube.
Tried all sorts of penetrants and chemicals the forum suggested and it never budged, even after soaking and pounding with a dead blow mallet, for weeks........
Till I tried CRC's Freeze-Off as a last resort. Magically, with very strategic application of the ultra cold penetrant, it came off just about a minute and a half, after spraying it on. The cold temperature literally cracked the corrosive bond between the aluminum stem and the steel steerer tube. Same went for the also stuck BB cups on the frame.
That's why I always recommend trying Freeze-Off to remove stuck stems and seatposts.
Quoted: 548 Post(s)
Liked 473 Times
Ok, just watched RJ the bike guy and he goes through this grueling video on "removing a quill stem, worst case scenario" Holy crap, that looks like hell! I don't think it's frozen because I don't see any signs of rust along the edge of the stem into the head tube and can even see a bit of grease (being optimistic here).
I was worried the stem bolt acted like a tent pole bolt, where you tightened it one way, and it expanded into the stem to tighten further. Glad to say I'm wrong.
I have an adjustable wrench that I can use to remove the hex nut and will try tapping the stem bolt to see if that loosens the wedge.
SE Wis
Quoted: 2747 Post(s)
Liked 3,401 Times
If you remove the reflector bracket you often find out you need to replace it with a spacer or the locknut bottoms out on the top of the steerer tube before tightening to lock in the adjustment.
Friendship is Magic
Bikes: old ones
Quoted: 26425 Post(s)
Liked 10,381 Times
Friendship is Magic
Bikes: old ones
Liked 10,381 Times
Quoted: 3811 Post(s)
Liked 6,716 Times
I recently had a stem wedge that was really stuck in the bottom of the stem. Took a few rounds of penetrating fluid and many whacks with a large hammer on the bolt itself to knock it out. I didn’t see any obvious corrosion. Stuckage happens.
señor miembro
Liked 6,488 Times
I usually have to do that with every stem I have. That's the way this works.
I like putting something soft on the top of the bolt and then hitting it with something hard. Sometimes, I'll just grab whatever is close by, like the spine of a hardback book.
Liked 6,716 Times
I used to just use my thumb, but after a while that seemed like a bad idea.
Likes For nlerner:
Quoted: 3464 Post(s)
Liked 2,831 Times
A super recalcitrant stem is one where the cone expander had bulged the steerer…
infrequent but can happen
gorilla mechanics are out there.
usually 3-4 revolutions of unscrew then tap will free the works. On these old bikes the stem and the headset are independent…
if one has removed the long bolt- re-engage it finger tight, back it out 4 turns and “ bang bang Maxwell’s brass hammer came down upon its head…”
that said there are exceptions “headclip”
stem and headset assemblies- thankfully rare and uncommon.
Likes For repechage:
Friendship is Magic
Bikes: old ones
Liked 10,381 Times
...reported to the library.
Likes For 3alarmer:
Friendship is Magic
Bikes: old ones
Liked 10,381 Times
