Will GRX handle a 11-46 cassette?
Quoted: 1975 Post(s)
Liked 232 Times
Do I misunderstand what power means? Isn't it true that for a given hill, you need the same amount of power to get up that hill, regardless of what gearing you have? I suppose the limiting factor is speed you're going and if you can keep the bike upright at eg. sub 3mph speeds or whatnot.
Probably a large majority of people who ride any kind of mountainous stuff. In my area, we've got plenty of gravel climbs that average 12% or more over a mile at a time. And check out this gorgeous road that one of my friends recently found:
I suppose "need" is a strong word, but if it's a question of what's optimal, I actually think that most road bikes in hilly areas should come with ratios of 1:1 or lower, whether intended for gravel or otherwise. Even in the paved lowlands around here, I see tons of people badly bottomed out on their gearing during climbs, and people avoiding very fun roads simply because the gradients get steep. That's awful.
Ideally, common chainring combinations would span a much wider range than they currently do. From what I can tell, a majority of people on road bikes have very little use for the top-end on modern road bikes. For the weaker riders, a 42-26 or even 40-24 would offer adequate top-end in a 1x-plus-granny scheme, while permitting a comfortably tight-spaced cassette.
*or simply make mtb and road parts cross compatible.
Likes For Racing Dan:
Likes For avg:
As it turns out the Evil Chamois Hagar uses an 11-46 so I think I'm good.
Quoted: 850 Post(s)
Liked 344 Times
Likes For smashndash:
Yes, you need a certain number of posts before you can post links, they do that to cut down on the forum spam.
Here's the link to that sweet MAP (More Adventure Please) bike: https://bikepacking.com/bikes/corvid-cycles-map/
