Do the dry (silicone based) chain lubes build up after a few applications?
Quoted: 45 Post(s)
Liked 12 Times
I've always been a light oil guy, or even WD-40 on chains. I've just got everything in the drive train spotlessly clean for biking season and was thinking....should I switch to dry lube?
How do you remove silicone lube from a chain if you want to?
Quoted: 5849 Post(s)
Liked 2,683 Times
To my knowldege, there are no silicone based chain lubes out there. While there might be some I don't know about, most dry lubes are a dry agent, commonly Teflon, suspended in a solvent to help carry it into the chain. Then the solvent evaporates leaving the lube i place.
In diect answer to your question, they don't build up because the newly applied solvent tends to lift and flush old stuff in the process.
The real issue isn't lube build up because that can't be a bad thing, but dirt buildup, and the tendency of lube applier to a dirty chain, carrying dirt deeper into the chain where it causes wear. (Dirt on the outside doesn't matter, except to the extent that it migrates into the wear zone)
FB
Chain-L site
FB
Chain-L site
Bikes: With round 700c & 26" wheels
There is many silicone lubes. I just saw few at Lowes and Home Depot. Not interested in testing them since I'm very happy with what I'm using. Many silicone based lubricants are used...for very intimate uses
Liked 2,683 Times
BUT
The OP asked a specific question about dry (silicone based) chain lubes, and I chose to give him an on-point answer.
FB
Chain-L site
FB
Chain-L site
Liked 2,683 Times
Yes, SILLY.
Or are we to assume that Gasoline and a reference to intimate lubrication were serious answers?
Maybe your laughing emoticons confused me. I guess you see his question to show off how funny you think you are.
So, yes, in the absence of an alternate word, silly it is. But if it makes you feel better, you can consider yourself the funniest man since Seinfeld.
FB
Chain-L site
FB
Chain-L site
Remember to choose your chain lube to riding conditions. I ride in Midwest, North East states, so a lot of mixed conditions, I never liked dry lubes. I use Prolink which is not attracting dirt /when not over-applied/, and it's wonderful in wet conditions. If you are a mtb biker and ride a lot in muddy condition - I would stick to dry, wax based lubes, and I would clean chain after each ride.
WD40 is also an "OK" lube/cleaner. About 1/4 of it are oils, and many oil based bicycle lubricants have similar ingredients. It won't last long though , but I use it a lot for cleaning some components when not too dirty, and when I don't have time for playing with gasoline.
Yes, SILLY.
There is many silicone based lubricants used in intimate settings.
Now...you tell me who is silly. If I'm not up to your standards - it's your problem. Don't be a grumpy old man...Did you ever smile, or you always like that? It's a bike forum, and about fun outdoor activity, NOT military base...
Bikes: '07 Salsa La Raza Campy build, '09 Fuji Absolute 3.0, '86 Raleigh Capri Fixie Conversion, '91 Specialized Hardrock Fixie Conversion
We've used Sunlite's Dry Lube with Silicone in the shop in the past and it works well enough. I've never experienced any kind of build up on the chain from repeated use. Although if you would like a suggestion I don't recommend dry lubes like that except in very dry dusty conditions, and I've found that such lubes do not last very long between applications.
I use a silicon spray on stanchions , does not build up or stick around very long either for that matter. Tried it under a clean mower deck for mowing in the rain, it failed there.
Quoted: 2026 Post(s)
Liked 1,096 Times
Yes, gasoline is an excellent chain cleaner but it's also dangerous as all hell. It's toxic and extremely flammable (its flashpoint is -8°F). There are other far safer but equally efficient chain cleaners such as Kerosene and Odorless Mineral Spirits. If you insist on using gasoline I hope you work outside and well away from all sparks and flames.
Liked 1,096 Times
Bikes: '17 Access Old Turnpike Gravel bike, '14 Trek 1.1, '13 Cannondale CAAD 10, '98 CAD 2, R300
Quoted: 1571 Post(s)
Liked 12 Times
Before I oil the chain I like to get it clean... and allow it to dry. In a pinch... I have used WD-40 as a solvent followed later with a little fresh oil. Or even WD-40 to thaw frozen parts.
+1
We also got so dangerously close to the moment when we discuss which chain lube is the best, and why WD40 is "bad" for chain.
Liked 6 Times
OP, silicone-based lubes are not effective/efficient on bicycle drivetrains. I have tried to use silicone lubes on my bicycle pulleys (reasoning they are made of plastic and won't result in build-ups), but found out they are not as effective as the regular bike lube and don't last as long.
I have used LPS and also Dupont silicone lubes.
Bikes: '04 LeMond Buenos Aires, '82 Bianchi Nuova Racing, De Rosa SLX, Bridgestone MB-1, Guerciotti TSX, Torpado Aelle, LeMond Tourmalet 853, Bridgestone Radac
Quoted: 101 Post(s)
Liked 46 Times
I can't comment on silicone, but I used White Lightning for awhile. I found that it did accumulate between cogs on my cassette and the derailleur pulleys. The waxy stuff doesn't dissolve easily so cleaning was a pain.
I don't want to start an argument about gasoline, but it sure does clean well. I haven't used it in years but it used to be the standard degreaser in the garage when I was growing up. If it weren't for the smell I'd probably still drop my chains in it.
I know it's volatile, but how many times have you heard of gas station explosions, where careless "amateurs" handle gasoline every day?
Liked 2,683 Times
It's this risk of accumulating and forming explosive fuel/air mixes that makes gasoline so dangerous. So used outdoors, with reasonable care it's not outrageously dangerous. Used indoors without positive, spark proof ventilation it can be very risky. I'm not saying use gasoline and die, just saying it calls for some understanding and management of the risks.
FB
Chain-L site
FB
Chain-L site
Quoted: 101 Post(s)
Liked 46 Times
Point well taken. As well as it dissolved gunk on chains, I always hated the smell on my hands for the next couple days. Never mind the flammability, that alone is enough reason not to use it!
Really Old Senior Member
Liked 7 Times
Gasoline is extremely dangerous and should never be considered as a cleaner or solvent. And it has no place on a bike forum.
