Tell me about lightweight steel road/tour bike performance models
Veteran, Pacifist
Quoted: 3901 Post(s)
Liked 4,847 Times
Many British brands offered sport/touring models (aka 'clubman') that would take wider tires for light touring while retaining sporty handling with a skinny tired wheelset.
This is a rebranded Holdsworth - but many made a similar style. Will take a 32mm tire with knobs.
In 2nd pic with 32mm knobbies front, 33mm (Racing Ralph CX) rear
At that budget you can and should get a top shelf bicycle. There are endless options in that range. If you are serious about getting more into cycling, I'd suggest skipping the middle and go straight to a high end bike. It will be cheaper in the long run, IMO. Once you get into that range there really isn't going to be any reason you can't keep up with people on carbon bikes. The difference will be trivial as compared to fitness, which is really about 99% of it.
I suggest looking for a vintage road bike with Columbus SL/SP, Reynolds 531, Tange 1/2/Prestige, or Ishiwata 022. Realistically these will all perform about the same. I realize I just contradicted what @noglider said, but it's not a bad first filter in picking a bike. When you have some candidates, then start looking at geometry. For general recreational use, an audax or old style road geometry is a good bet. 73º parallel, neutral trail, reasonably long chainstays. Size and TT length that are right for you. The Competive Cyclist fit calculator works really well. I fit people professionally for years, and I used it on myself when I got a custom bike. It spit out exactly what I had come to find worked best for me over decades of riding.
What I'm saying is figure out what size you need first, then start hitting Craiglist, the for sale board here, ebay, whatever. There really are endless options. You might narrow it down a bit by deciding if you want to go Italian, English, French, Japanese, American, or other.
When you are at that point, then start thinking about components. Can't go wrong with Campy NR/SR, or Superbe, or Dura Ace 7400 or later, or Ultegra tri color, or a mix of good parts. Don't rule out old Frenchie stuff either. It can be more of a hassle to work with, but it's right up there.
Yeah, there are lower and midrange steel bikes that ride nice, but in Los Angeles, lighter is better. You will probably be riding up and down hills most of the time, whether you're doing trash truck or the climbs in the San Gabriels. This is no place for a UO8.
Do you have an idea of what size you are?
Do you want modern indexed brifter shifting?
How many speeds?
You also need to pay attention to the drop out spacing? is the bike 126 or 130 if you are doing 8 speed and above you want 130 (if it is steel you can either cold set a 126 to 130 or just hand spread when putting the rear wheel in)
Lot's of options....One is find a bike that is your size and equipped the way you want.
Another is find a frame, then if you want modern gear get a full group from a uk bike shop. The C&V for sale section and a WTB gets really good results
Look for double butted tubing and forged dropouts as a basic indicator of mid level or higher
Personally I like the mix of steel frame with modern gear...... at a rough estimate of a really nice build, Frame and fork ...$300 to 500 so call it $400 for what ifs. 105 group from uk bike shop...varies think $450 to $550, call it $500, wheel set $300 ( right now velomine has 5800 105 hubs, mavic open pro, 36 spoke for $219 (works 8 to 11 speed) Mavic 36h Open Pro Black Rims Road Bike Wheelset 8-11 sp Shimano [741117] - $219.00 Velomine.com : Worldwide Bicycle Shop, fixed gear track bike wheelsets campagnolo super record vintage bike)
so $1200 at an estimate, plus head set if needed and cockpit (seat, seatpost, stem and bars) which can varie widely depending on what you want but call it $1500 for really nice bike that is all your spec
How many speeds?
@Wildwood thanks for showing me so many different bikes I am unaware of.
ambulatory senior
Quoted: 1956 Post(s)
Liked 3,662 Times
In my neck of the woods we run into Miyatas a lot. 3 series through 9 series all have great frames. With your height you may want to consider different stem lengths. Small bikes often have relatively longer top tubes for the frame size. I usually get 60mm reach stems just because I like to be upright but they could help you make a bike fit.
Veteran, Pacifist
Liked 4,847 Times
[QUOTE=MegMC;20566060]@Wildwood thanks for showing me so many different bikes...…
It's what we do. ……………..Caught me on a rainy morning.
These sites will be your inspiration if you plan a little fixing-up and light wrenching.
Lightweight Classic Vintage bicycles
Classic Lightweights
If you do want your fixed up bike to shine - go classic as well as vintage.
Here's 2 examples with modern components and triple chainrings.
Nice Pinarello paint from 90s (atmo), and
classic Dutch orange late 70s.
Bikes: 1978 Bruce Gordon, 1977 Lippy, 199? Lippy tandem, Bike Friday NWT, 1982 Trek 720, 2012 Rivendell Atlantis, 1983 Bianchi Specialissima?
Quoted: 346 Post(s)
Liked 175 Times
Thanks for the thread recommendation! I do take your point about brands models but Craigslist results in my county of 10 million can be so overwhelming, I thought it might help to narrow things down a bit or think of certain eras or families of bikes that might serve the purposes I have outlined.
Maybe slightly OT, but you shouldn’t have much trouble finding an 80’s Santana Sovereign for just a few hundred and you’ll stick right with your husband. They can be great fun and very fast.
I a man a Trek fan so that is what I would look for. In your price range look for any 700 (710, 720, 770, etc.) and modify to make it what you want!
What you're asking is is what mid-high-level bike is a good bike for commuting/rough roads/bike paths... One 'problem' with your question is that GENERALLY, the higher up the particular brand hierarchy, the more you end up in race bike frame geometries and very little tire clearance. Exceptions are the touring bikes that, again GENERALLY, have longer rear chainstays and more tire clearance between the chainstays.
I really don't mind riding a comfortable, heavier frame bike. My '75 Fuji S-10S is straight-gauge hi-ten steel, and yet only 26.1 pounds bare (according to the catalog), and 30 pounds as measured last year equipped with rear rack, bottle cage, lights and triple crankset, but lighter wheels than it had stock. Originally 27x1-1/4" / 32mm tires, I generally ride it with 27x1-1/8 tires/ 28mm. Plenty of room for fenders, too.
Only in the last couple of years have I 'upgraded' to slightly lighter steel-frame bikes -- about two-three pounds lighter for the bare bike. My '84 Univega Viva Sport has double-butted cr-mo frame and Manganese-alloy front fork. With lighter components than stock, I got that one down from 25 to 24.1 pounds. It still wears 27" wheels, but newer narrow rims fitted with 1-1/8" tires (28mm) but has room for 1-1/4" or 32s, easily.
A bit higher up the 'foodchain', my '86 Miyata 710 was originally equipped with 25x700c and < barely > has room for 28s -- in the front! The 28s fit fine on the back, but there is barely 1mm clearance between the bottom of the steerer tube (underside of the front fork, if you prefer) and the top of the 28mm tire. It has a much more 'sporty' frame geometry - what they used to call a 'triathalon' style. It has triple-butted frame tubes, CrMo fork and weighs 23.5 pounds. From what I've learned, earlier years had more tire clearance...
ON Touring bikes.... Fuji, Nishiki, Centurion, Miyata, Univega, Bridgestone, and the rest of the '80s Japanese touring bikes are a bit heavier than the 'sport' models and will have longer rear chainstays making for a longer wheelbase and clearance for wider tires and fenders.
My '84 Univega Gran Tourismo and it's step-sibling the Miyata 610 have double-butted CrMo frames and were specced out to weigh in the neighborhood of 27 pounds.
I followed the advice of @Salamandrine and entered my very comprehensive measurements into the fit calculator at Competitive Cyclist and here's what I got:
I made my husband measure my inseam/PBH multiple times because I could not believe it was 32" and my height was only 5'5"! Thus I am being recommended a seat tube length that is considerably longer than top tube, which does not seem to be how most frames from this era are built. Most geometry charts I've looked at for frames like Bridgestone, Centurion etc show top tube within 1 cm of seat tube c-t, and I understand the Italians may have an even more stretched out ratio.
So I'm assuming I can use quill stem and seat post adjustments on a slightly shorter frame to achieve good extension and more moderate/relaxed geometry while keeping my top tube more in the optimum range?
Today I have become intrigued by Bridgestone and the cult of RB-1, and my husband has proposed a plan by which he will upgrade his group set and sell me his Ultegra group for a very fair price :-) not sure about that. There is currently a 54cm 1988 RB-1 for $500 on Craigslist, which I think @Salamandrine posted here above, and a 1989 RB-1 frame - to my eye the only one with a somewhat cool paint job - for local pickup on eBay for a Buy Now price of $429 ( which seems pretty high. I would be willing to pay a bit of a premium for the paint, the cult and the smaller size but not sure how high - also not sure if the 80s RB-1 are quite as sought after as 90s). Also a very nice looking Miyata 912 which is also ovepriced at $425 - how would a Miyata of that level compare to the RB-1. I assume there is limited potential for tire width. At these prices I'd probably be better off buying a brand new Soma Stanyan frameset from Velomine for $350. But then I wouldn't be C&V!
still much research and looking to do. Have not even dived into European bikes ....
Find yourself a higher end Miyata frame-set from the late 80’s or early 90’s. Put a 9sp Dura-Ace group and lighter modern wheels on it. Find a seat that is comfortable for you(the hardest, yet most important part of biking?). Get it in a color you like and get cables and bar tape to match or color match a color on the frame. Bam! Beautiful riding, sexy vintage steel that you’ll fall in love with and be amazed at how much faster you go. That should be Well under your budget cap, too.
I had a 90 Miyata 914. I Think it might only fit 700x26ish tires. It might have fit 28s. That will be the one thing to watch out for.
There’s a modern retro thread or something like that. Give it a look through.
I am running Panaracer Pasela 28's on my commuter bike currently, which I understand are small for 28's even and I think as long as I can go up to 28mm on the road bike I should be fine.
There is something about the precision yet non-fussiness of the Japanese bikes that appeals to me ... but then again since I already have a Japanese-made Univega I fear I may always feel the lure of the unknown glamorous Europeans ...
Friendship is Magic
Bikes: old ones
Quoted: 26427 Post(s)
Liked 10,384 Times
...it's not unusual at all for a woman to be anatomically designed with legs up to here and down to there, with a shorter overall torso. this is why the "women's specific"designs from Terry and other makers had a brief surge of popularity. With a smaller front wheel, the frame could maintain classic angles, but still be built with a shorter top tube relative to the seat tube length.
This is, after all, a hobby. You need to stay loose in the initial stages, or you're at risk of not fully grasping what it has to offer.
I see some very fine bikes on my local CL here in NorCal in smaller sizes that would fit you at bargain prices in the 350-500 range all the time.
There was a very sad thread a few years ago where some woman had bought the C+V dream bike at a fairly hefty price. Her thread centered around fit issues, and it became abundantly clear after a short time that the real issue was that she was not comfortable on the bike because all her riding had been done on a cargo bike, with flat bar and an upright stance. She was uncomfortable with a drop bar bike, and had spent a great deal of cash on something that was not going to be much fun for her to ride without considerably more riding experience. Yet the thread went on and on and on with suggestions for adapting fit, and a lot of changes to components that would make the thing much more difficult to resell without losing substantial monies.
Don't be that person. It's a learning experience, and your ideal classic road bike will take shape over a period of years and months. It might even change with more experience, longer rides, and increases in fitness and flexibility. I know mine has over the years.
You are so very very right! It's so hard to keep that perspective while in the throes of it and getting egged on with forums haha.
Bikes: '84 Miyata 610 ‘91 Cannondale ST600,'83 Trek 720 ‘84 Trek 520, 620, ‘91 Miyata 1000LT, '79 Trek 514, '78 Trek 706, '73 Raleigh Int. frame.
Quoted: 685 Post(s)
Liked 370 Times
He’s right, one year earlier and the 710 has diacomp gp 500 long reach brakes, the ‘86 switched to the GP 400 short reach calipers.
If you want a good sports touring frame I’d look for Trek 510’s and 610’s also the Trek Elance. Not steel but Cannondale ST frames are super light, and you can run 28mm tires (barely) on them. They have every braze on for touring, long chainstays, low rider mounts, three bottle cage mounts, and come in under 22lbs. in the smaller sizes.
Pre ‘85 Miyata 710’s and 910’s will fit a rear rack but the stays are short for panniers. You can use a top trunk and a bar bag though, for some carrying capacity.
As much as I love my Miyata’s my “bike of the summer” has been my ‘84 Trek 610. Same bike as “Seymour Blueskys” on Lovely Bicyle. She pegs it as a sporty race bike, but it has the chainstays for panniers, and clearance for 32mm tires with room to spare. They came with 27” wheels, but the switch to 700c is super easy to make and the stock brake calipers absolutely reach.
The Cannondales are straight up awesome, but only if you dig the aluminum. Lighter and stronger than the steel frames, with the lugged Tange fork that helps with compliance. Also the clearance on the rear maxes out at 28mm but you can fit a 700x41 up front! This gets you into gravel grind territory! The front end floats over everything, and the narrow back keeps momentum up.
Ok... I’m done now.
The 27lb weight was for the 57cm size, it won’t be quite so heavy in the smaller sizes. They also ride nicer than that weight would make you think. (Totally subjective, I think Miyata’s have the nicest made frames.)
Ok... I’m done now.
I'll have to look up that section of Lovely Bicycle. After coming across the blog endlessly in random searches I have been attempting to read it chronologically as it's instructive to see her evolution. I think I'm still in 2010 Lovely Bicycle Land. Weird to think how long ago that was with all this 10-years since financial crisis stuff we're talking about today.
The Huffmeister
Bikes: '79 Trek 938, '86 Jim Merz Allez SE, '90 Miyata 1000, '68 PX-10, '80 PXN-10, '73 Super Course, '87 Guerciotti, '83 Trek 600, '80 Huffy Le Grande
Quoted: 1227 Post(s)
Liked 3,561 Times
A small front wheel is also useful if a low stack height is desired, so that you don't need to do silly things like attach your bars to the fork.
Quoted: 685 Post(s)
Liked 370 Times
The Huffmeister
Liked 3,561 Times
If you do look at Miyatas (which are wonderful bikes...used to own a 710 myself and would welcome a old Miyata back in my stable at any point!), be aware that some of the higher end models that had internal cable routing through the top tube have had a history of cracking. I don't know how sporadic or common it is, but something to be mindful of.
Lots of great bikes and brands. Hard to give names, because I'd be leaving too many out! I can't remember who gave the advice (and at this point, I've probably heard it from many. Maybe it started with Randy Jawa?), but when trying to gauge the quality of bike from a picture, there can be a few good signs to look for -
-lack of 'turkey lever' brakes (the brakes with the extra lever for gripping in the upper grip position on road style bars)
-downtube shifters (vs shifters on the stem neck)
- lack of a huge shiny chrome 'dork disc' around the back freewheel (although, admittedly, my Fuji S-10S has one and it is an awesome bike and ride)
-forged dropouts
-aluminum cranks vs steel cottered
These are all indicative of a higher end bike, the more of these features the better, generally speaking.
Typically, the lighter, the higher end. It's a lot easier to make a 30lb bike than it is a 22lb, in 1970s and 1980s terms.
Sometimes, though, enjoyment will leave you baffled. I had a Zebrakenko (odd Japanese brand) and it was a higher end model. The bike was either around 23lb or sub-23lb...lightweight, higher end Suntour components, Ishiwata tubing, and I donated it in at the local co-op. Was very 'squirrely' to ride. In contrast, I've got the Fuji S-10S, with 27" wheels, 'hi-ten' frame, dork disk, and it weighs at least 26lbs...and the bike is a total joy...rides like a cadillac, tracks perfectly, super smooth, etc. Now, its not a quick ride per se, and I know that is your goal here, but the main point is that getting on a bike and riding it (assuming it checks out, safety-wise) is going to give you the best feedback. The bikes will start talking to you. Try to find a local bike shop that has a good selection of higher end older road bikes, and find some in your size and start test riding them. Or go to each LBS in your area and see if they even just have 1 in your size. Ride as many as you can. Start figuring out what you like and what you don't before spending a lot of money....
...is what I would tell myself if I was smart. Instead I buy up any old neglected project to bring home to the orphanage
-forged dropouts
Quoted: 502 Post(s)
Liked 466 Times
My ‘79 Miyata 912, brought new when it came with 27” wheels and tires, fits actual (measured) 700Cx28mm tires and fenders with about one cm of clearance between them. That’s before that model became a then-popular “triathlon bike”. Here’s what it looked like in its 3rd major configuration a few years ago, after I widened the rear dropouts to the current 130mm standard, with a 3x8-speed Ergo shifted drivetrain. It will take 700x32mm tires without fenders. I’m aware that a few years later tire clearances on this model tightened up and glad that I missed the internal cable routing era of better Miyatas.
It handled fine with a large rack bag or single pannier for commuting duties in this configuration, but it wouldn’t have been so nice with two full panniers and the relatively short chainstays.
I’ve since modified the fork with lower trail and mounts for front bag (shown) and low rider panniers. It handles fabulously with any load on the front now. It will be my travel bike for the future (trip to France next year!) as well as being the designated winter/fender and surprisingly capable shopping bike the rest of the time. I’m in love with it all over again! (Fenders hadn’t been refitted when this was taken.)
Friendship is Magic
Bikes: old ones
Liked 10,384 Times
..."standover" is when you put on the shoes in which you will be cycling (because sometimes they have soles that are a half to three quarters of an inch thick), and straddle the bike. It's a quick way to gauge the height of the top tube from the ground. The usual recommendation is to allow about an inch or inch and a half between your sensitive crotch parts and the top tube, but you should be able to safely ride a bike that has the to tube higher than that. And most of us can manage one where the crotch and top tube are separated by mere centimeters.
This will usually give you the max seat tube length. AS you are already aware, it will probably also give you a longer top tube, which in your particular case can be compensated for by moving your saddle forward in a zero setback seat post, and using a short stem. The two measurements you'r trying to achieve are your particular most confortable distance from the saddle to the bar, and of coiurse your particular most efficient saddle height from the pedals. Take a drawing of a road bike and sketch it out for yourself. You'll see right away.
Friendship is Magic
Bikes: old ones
Liked 10,384 Times
Each of these bikes is comfortable for me to ride, even if they differ in frame size
...because the distance from the saddle to the bar / from saddle to the pedal is consistent:
