Power meter comparison (powerpod?) - what is best/easiest without spending a fortune?
#77
Quoted: 741 Post(s)
Liked 412 Times
#78
Perceptual Dullard
Quoted: 919 Post(s)
Liked 1,156 Times
https://www.dcrainmaker.com/2018/09/...e-edition.html
#79
Quoted: 741 Post(s)
Liked 412 Times
Ah. In post #66 above I mentioned a comparison "we" tried to do in 2018 of the Power Pod, the Notio Konect, and the Aerostick? That was with Ray.
#80
Perceptual Dullard
Quoted: 919 Post(s)
Liked 1,156 Times
Ray has a lot more patience than I have.
I've known Ray for years, and have worked on a few power meter related projects with him, including that one in the wind tunnel, but also a few others. I think he tries to figure out what the use case and value proposition are for each product he reviews, and then evaluate them from that perspective. That's wise, mature, and probably the right thing to do. I don't have to write reviews for a living so I don't have to be polite. One of the side effects of Ray's wise and mature approach is that his reviews can sometimes be like Rorschach ink blot tests: people see in them what they want to see. You read his short comments about the Power Pod and came away thinking "they're as accurate as other power meters!" I did the behind-the-scenes analysis for Ray's original review of the Stages where I laid out where it did well and where it did poorly. Later, people would cite Ray's review to me in defense of what they thought, not knowing that I did the analysis. I think that's kind of amusing.
Likes For RChung:
#81
Advocatus Diaboli
Quoted: 4739 Post(s)
Liked 1,533 Times
Remember the Arofly?
https://www.arofly.com/main/arofly-elite-en/
#82
Bikes: yes, i have one
Quoted: 1139 Post(s)
Liked 1,182 Times
#83
Quoted: 741 Post(s)
Liked 412 Times
Overall, I’ve found that the PowerPod can be solidly accurate in most situations, assuming you are aware of the limitations – or aware of changes to configuration that could impact it. Further, it’s ability to seemingly ‘heal’ itself does act as a bit of a safety net should the aerodynamic profile change significantly enough to otherwise impact power readers. I’d sum it up as: If you do a clean calibration ride – things are impressively accurate across a wide range of riding environments and positions.
#84
Batüwü Creakcreak
Quoted: 229 Post(s)
Liked 288 Times
"Accurate given the limitations" is a really nice way to say that something sucks but here's some silver lining.
He really is so diplomatic, eh?
Likes For ridethecliche:
#85
I use the PowerPod V3 on one of my bikes. It works as I expected and the Isaac software provides data other power meters don't like wind. My only con is Isaac only runs on Windows or Macs which requires me to take the PowerPod from the bike to the computer. This means the tilt setting changes each time and the PowerPod must adjust at the beginning of the ride after removal. There is an app which allows you to setup profiles but not extract data. 4 profiles are available and the PP switches profiles based on the wireless sensor ID's if you have more than one bike with different sensors.
The only drawback is that my Edge computer screen is more level, when I liked it a bit tilted up for easier reading.
I'm happy with my PowerPod, even if calibration was difficult. But the company has excellent support--I sent in my unit to be inspected after running into issues when I wanted to add a second bike, and they helped me with it for free even though I've had it for years. The main reason I use it is for the wind data--there is a steady, stiff afternoon bay breeze here, and I like having more accurate calorie burn/work output info than just the estimates on Garmin Connect or Strava. (Especially since it's almost a direct headwind for 25 miles when I ride home from work, about half of which is on a gravel path.)
#86
Bikes: Brompton S6R-X, Tern Verge X20, Moulton SST, BMC RoadMachine, Bianchi Infinito CV, Giant TCR Advanced Pro Disc
Quoted: 17 Post(s)
IIRC PowerPod is based in Lovely Flat Florida. In flat terrain doing TT/Triathlon type training, I’m sure it’s plenty good for steady state and interval training.
I live in a place with rolling terrain + some steep climbs. I started out with PowerPod and shifted to Quarq after 12 months. For my use case there is no comparison: Quarq wins hands down. PowerPods were definitely overstating power on downhill spin outs. Also would get insane transient power spikes when dropping outer pedal to corner at high speed.
Thinking about this more, another issue is simply road surface quality. PP has settings for this in the software, but bumps and thumps probably don’t just affect rolling resistance part of the balance of forces calculation ... also going to have transient effects on the ability of the system to determine whether or not one is (say) going downhill or level or uphill — suspect this caused transient power spikes as crank rotation when spinning out would then look like big power input.
Anwyay, if you really want to be *sure* and you don’t just ride flat good quality roads, buy a crank-spider type power meter and live happily ever after.
PS: If I were interested in my aero performance, I’d buy one for the CdA measurement feature. Absolutely. They’re a good company and provide good forum support. Just not for me for my use case.
