Quick question about chainline and bottom bracket length
Method to My Madness
Quoted: 1981 Post(s)
Liked 1,501 Times
Quoted: 1572 Post(s)
Liked 1,745 Times
The OP specificallly said " my intention is to use it as a triple", so I did not want to bring in that complication.
But if you intend to use this triple crankset as a double, then you can use a significantly shorter spindle.
Liked 1,501 Times
Got it. The OP is not doing this, but I am effectively doing something very similar, i.e., using this crankset for a 1X front setup with the chain ring mounted on the outermost position.
Quoted: 1948 Post(s)
Liked 2,181 Times
It can be difficult to visualize, but even though all of that additional 4mm width is coming from a wider freehub body only 2mm is further out on the DS. The other 2mm is pushing the hub toward the NDS which results in no change in chainline, center of the freehub body, due to the wider dropouts. The wheel has to be re-dished to compensate for this movement.
Think about the perspective from the DS dropout.
John
Edit Added: This is also why there is a change in chainline going to 135mm using the “same” freehub.
Liked 1,501 Times
Not if you are going from a 126mm 7 speed freehub body to a 130mm 8-10 speed freehub body.
John
John
Liked 1,501 Times
Summary: I ordered a Tange Seiki LN-3922 (made in Japan!) bottom bracket with a spindle length of 107 mm to replace the cheap stock VP bottom bracket with a 121.5 mm spindle length in order to (theoretically) move the crank arm and chain ring 7.25 mm inward.
Tange LN-3922 Bottom Bracket | - Ben's Cycle (benscycle.com)
The same bottom bracket is also available with a 115.5 spindle length, so hope one of the two works out for Piff .
Liked 2,181 Times
So the center of the cassette (regardless of the number of cogs) stay at the same position relative to the centerline of the bike regardless of whether the OLD is 126 mm, 130 mm, or 135 mm? But OLD 130 mm road bikes generally have a 45 mm chain line, while OLD 136 mm hybrids (at least the inexpensive ones using the previously ubiquitous Tourney triple crankset) have a 47.5 mm chain line.
130 (8-10) to 135 (8-10) basically just moves the same freehub out 2.5mm. I believe it was to add chainstay clearance.
Note: There are some 7 speed on 130 and 135 that push the centerline out. And I’ve also seen some freehub bodies that are set a little bit farther from the dropout.
John
Likes For 70sSanO:
Old fart
Quoted: 3597 Post(s)
Liked 3,421 Times
Quoted: 801 Post(s)
Liked 754 Times
Thanks everyone for all the help, I went ahead and purchased a 113mm spindle as well as the cranks. I'll report back once they arrive and are installed!
Liked 1,501 Times
Liked 1,501 Times
Actually, just a cheap spindle. This one here.
Liked 1,501 Times
Piff Achtung! Note of caution regarding the Dimension Cyclocross crank arms.
110 Crankset | Dimension Bike Products
If the drain drops toward the inside, the 74 BCD mounting nubs make it super difficult to extricate the chain. I learned this during a test ride of my 1X setup before shortening the chain. I have not found a 74 BCD chain guard. Hopefully, shortening the chain reduces the possibility and frequency of dropping the chain.
Likes For SoSmellyAir:
Quoted: 801 Post(s)
Liked 754 Times
As for the chainline....well I actually have decided to put the crank on a different hike, a 1988 Miyata Valley Runner. The chainline works great as a double with a 110mm un55 bottom bracket. But, it has to be said that the 110mm is asymmetrical, the NDS is longer by 3.5mm. The drive side length of the spindle is more equivalent to a symmetrical 107mm un55.
Liked 1,501 Times
Gusset Lil Chap chain device, 34.9/31.8mm - Modern Bike
I ordered the $20 Amazon version.
Would you mind giving us your thoughts concerning the quality of the spindle you ordered, as well as a follow-up in regarding same in a few weeks? I'm considering getting one or more of those for future use, and would like to know whether they're worth the $$$. IMO I'm likely not the only one, either.
