Frame to Accomodate 700c X 43 Tires?
Bikes: Indeed!
Quoted: 1514 Post(s)
Liked 3,489 Times
Bikes: Indeed!
Liked 3,489 Times
Tektro R559s are often recommended, there are others.
I have a pair lurking somewhere out in the shed, hoping to be re-used for such a conversion.
Brent
Quoted: 469 Post(s)
Liked 2,445 Times
I'm facing the same dilemma. I bought a pair of Rocknroads recently, hoping to squeeze them into a Peugeot.
The only way I can see them working is without brakes, or going with no front and a rear kick brake hub.. The clearance is real tight all around.
I tried to fit them on a Miyata 1000 and that was a no go.
Spin Forest! Spin!
Bikes: I used to have many. And I Will again.
Quoted: 7 Post(s)
Liked 11 Times
I would suggest an early to mid 90s hybrid. I know the 94 Schwinn Crosscut I had, came with 38mm and could take a 45mm tire.
A Trek 700 series I had flipped also had ample clearance. Plus, it is claimed the geometry was patterned after Trek's 80s touring bike.
Not all hybrids have a too long top tube.
The Trek 700 had an entry level quality frame with only the seat tube being Cro-Moly, and the rest hi-ten. The higher models up to 790 used Tru-Temper DB Cr-Mb.
I know where you're coming from, since I've got similar trails out here that wouldn't work with a 35mm tire. Rocky, unforgiving terrain. I'm doing another drop-bar hybrid to replace my Crosscut, and will be cramming a pair of Vee Rubber Flying Vees in 29x1.75". That's 45-47mm. They just clear on my Ross Signature Minotaur XC hybrid.
That clearance is less than I would feel comfortable with. If you really want to do it though, you could run Sturmey Archer drum brakes. they are a little pricey but pretty awesome.
Brent,
I just measured the chain stays on my three early 70's bikes and they all come around 44-45mm clearance. If you get one that has Weinmann 750's in the rear (or the equivalent Dia Compe) you most likely will not run into the brake bridge problem Roger has above. The three bikes I measured were a 73 Lygie (44mm), 72 Moto Grand Record (45), and a 74 Nishiki International (44). If by chance you want to run an IGH one could slide the axle all the way back in any of those drop outs and probably get to 47-48mm. I bet an early 70's Motobecane Grand Touring would fit the bill for you. Unfortunately I do not have one to measure.
Bikes: 1966 Paramount | 1971 Raleigh International | ca. 1970 Bernard Carre | 1989 Waterford Paramount | 2012 Boulder Brevet | 2019 Specialized Diverge
Quoted: 129 Post(s)
Liked 78 Times
My 1971 Raleigh International handled fenders and 700 x 38 tires. Without fenders, I have little doubt the 43's would fit.
Still learning
My XO-5 with 38s. Just added fenders. I think the photo shows you can go wider. For a bike that would be ridden less than an hour at a time as a grocery getter, drop bars seem like a moot point.
Bikes: The keepers: 1958 Raleigh Lenton Grand Prix, 1968 Ranger, 1969 Magneet Sprint, 1971 Gitane Tour de France, 1973 Raleigh Tourist, 3 - 1986 Rossins, and a '77 PX-10 frame in process.
Quoted: 221 Post(s)
Liked 237 Times
I'll suggest a Schwinn CrissCross. I'm running 700x35 street tyres on mine, with Planet Bike fenders, and I'm still looking at the width of my index finger at the first knuckle (13/16" or approximately 20mm) clearance on top and each side of the tyre. Rear clearance appears to be a bit more.
Syke
“No one in this world, so far as I know — and I have searched the records for years, and employed agents to help me — has ever lost money by underestimating the intelligence of the great masses of the plain people. Nor has anyone ever lost public office thereby.”
H.L. Mencken, (1926)
Syke
Quoted: 90 Post(s)
Liked 137 Times
I have a early 80's Japanese built Bianchi Touring bike that I am building into a townie of sorts, I have had 700 x 38's on it which it looked like I could just fit a set of 40's in there, but of course there wouldn't be enough room for fenders & I am not sure about what if any brakes would work. I settled on 32's which I can fit fenders on and use a set of 600 dual pivot brakes with no problems. I have also toyed with the idea of adding canti/V brake braze on's so I can run a 40 or bigger tire on it, without fenders of course.
Only Pic right now with 32's,
Quoted: 5892 Post(s)
Liked 3,479 Times
Phyllo-buster
Quoted: 2299 Post(s)
Liked 2,059 Times
I find old roadsters make great town bikes. Slow but they'll haul anything with a huge Wald basket up front. This puppy has 700 x 45 Conti top touring rubber with lots of room to spare. Although I don't think I've seen many bigger tires.
Hogosha Sekai
Bikes: Leader 725, Centurion Turbo, Scwhinn Peloton, Schwinn Premis, GT Tequesta, Bridgestone CB-2,72' Centurion Lemans, 72 Raleigh Competition
Quoted: 70 Post(s)
Liked 21 Times
Most Low-Mid end 70's road bike should fit the bill for what you're looking for. I run 38's on a 72 Centurion with tons of clearance left.
clasher, thanks for the info about the Miyata 1000. Fenders don't matter to me so maybe that bike is a candidate. If you could measure for me when you get the chance I would appreciate it. I think that the distance from the dropout to the chainstay bridge may be a critical one.
Brent
Brent
I got 99 projects
Quoted: 42 Post(s)
Kenda K161
https://www.cyclocross.com/product/ke...FYNxOgodKisACg
My Peugeot UO-14 handles these tires in 37-630 (27X1-3/8) plus Velo Orange fluted aluminum fenders; the brakes are MAFAC Racers. With some long-reach Tektros and 700C wheels, you could probably go a little bigger. The horizontal spacing in the stays and fork crown is quite roomy.
Rides Majestic
Bikes: 1983 Univega Gran Turismo, 1970 Schwinn Super Sport, 2001 Univega Modo Vincere, Self-Built Nashbar Touring, 1974 Peugeot U08, 1974 Atala Grand Prix, 1986 Ross Mt. Hood, 80's Maruishi MT-18
Liked 7 Times
Not all 90's hybrids will take 43's. I have a univega activa and it maxes out at 38's. My Nashbar aluminum touring frame has tons of room, I'm running WTB pathways that measure 41mm with room to spare, I've even heard of people running 29er 2.0 tires on those frames. There is not room for fenders with tires that large though. My Miyata built 1983 Univega Gran Turismo would not be able to run those, and setting it up for 700c was problematic with the canti stud location. If you have to have lugged steel, what about the Singular Peregrine (disk only) frame? For a cheaper option, you could go for the Pake C'mute, it seems to have plenty of clearance from what I've read.
Quoted: 821 Post(s)
Liked 257 Times
I know the newer Bruce Gordon Rock 'n' Road bikes will accommodate the Rock 'n' Road tire and I have a sneaking suspicion your older frame will also. That would probably be my favorite solution, to find a used rock 'n' Road frame in a 58 to 59 cm at a reasonable price. I've been looking but they are few and far between. Patience is not one of my strong suits when I have a project in mind!
Brent
Brent
I was a complete idiot.
I sold my RnR for peanuts.
Here's another thought.
Try an older Stumpjumper. I have a BoB trailer that we use with my wife's for Farmers Market and grocery runs.
Works great.
Fat Franks fit, so the Bruce Gordons should as well.
It's worth a though I think.
I think some of us are ignoring the OP's specifics, myself included. He wants a vintage non mtb frame that will accommodate 700c and has canti brakes. I think an early 90's hybrid is the right track. If he is willing to run center pull brakes (and if they will work with tires that wide) then an early/mid 70's frame (possibly 60's as well) of some sort might work too.
Quoted: 821 Post(s)
Liked 257 Times
Quoted: 469 Post(s)
Liked 2,445 Times
Brent,
Bikes: Indeed!
Liked 3,489 Times
Thank you all! You've given me a lot of options and a lot of good useful information. I'm overwhelmed with your willingness to help me out!
Special thanks to Clasher, a coffin, and CO_Hoya for taking measurements for me.
I realize I'm probably being a little too insistent on drop bars. I know it seems a little strange that I want drop bars for a grocery getter but my nearest grocery store is 9 miles away, as is the nearest hardware store. The other grocery store I use is 12 miles away. The flattest route entails about 1,200 feet of climbing in a round trip. I have made the trip into town many times on my hardtail mountain bike and the flat bars weren't a big deterrent. if an old Stumpjumper comes my way before the right touring bike or hybrid I'll probably give the flat bars a try.
Brent
Brent
I like that idea (other than the fact that I already own a couple pairs of perfectly serviceable 700c wheels and would have to buy new rims and spokes at a minimum), but what brakes would I use that would accommodate both the longer reach and the increased tire width? Cantilever bosses would be in the wrong place for the 650b rims and I don't know of a center-pull or side-pull that will open wide enough to allow a fully inflated 38mm tire to pass through. Suggestions?
Brent
Brent
