can heavier bike be faster,?
Newbie racer
Bikes: Propel, red is faster
Quoted: 1575 Post(s)
Liked 1,569 Times
no mountains for that thing.....but I have done neighborhood rides on it at about 85ft/mi at 20mph+ before. My double setup is a 56/42. 42/30 is more than enough for most hills here. 56 means I can do 95rpm downhill at a solid speed.
Likes For burnthesheep:
Quoted: 6974 Post(s)
Liked 10,975 Times
A few years ago, a European bike racing magazine lent 1980s-era steel racing bikes to three strong young racers and asked them to compare those bikes to their own high-end carbon bikes. The riders reported that they enjoyed the way the bikes rode except for descending the local passes, where they found the bikes to be too difficult to control at speed.
Bikes: 2019 Specialized Diverge, 2021 Cervelo Caledonia
Quoted: 258 Post(s)
Liked 378 Times
I'm no physicist, but... a body in motion tends to stay in motion, so once up to speed, and on level ground, you're pedaling just to overcome the rolling resistance of the bike plus the air resistance. The weight of the bike (and rider) is irrelevant.
you may want to look a little harder at rolling resistance.
try riding an old track bike with chrome handlebars and stem and steel cranks. when you get on it from a dead stop that darn thing moves,
theory is ok, experiments are better, if you like to climb out of the saddle, then a stiffer frame is going to be an advantage.
been there with the vitus on old la honda road, moody road to skyline, rather have a steel frame or those hills,
phyisics? i was alright, was better at calculus,
Quoted: 4806 Post(s)
Liked 3,933 Times
Are the fits identical? If not, and the ti bike is indeed faster, you now have real info on what works for your body. Think about it. Bike weight differences matter to the tune of the bike's weight plus your weight. 2 pounds of bike weight is 2 pounds in what? say 190 pounds of you and bike or barely over 1%. But slightly different position on the bikes? That could be like slightly tweaking the stroke on a race car engine and the difference could be a lot more. There could also be an aero difference if the two bikes have different levels of comfort..
another benefit of a stiffer frame is you can launch an attack on a steep climb without false shifting.
with the vitus carbone, there was no way i could climb out of the saddle on redwood gulch rd where it is 18 percent i had to use a smooth pedal stroke to keep from dogging down into a bigger gear. if someone goes by you have to let him go til you reach hwy 9. then you could put the hurt on them with the weight savings.
i saw a guy enter the cats hill criterium on a vitus, and i am thinkin to myself, good luck buddy, i did not see him cross the finish line.
so i avoiding mis-shifts can be considered faster, then a heavier frame can sure be faster.
Likes For cjenrick:
Bikes: Nashbar Road
Quoted: 2934 Post(s)
Liked 341 Times
He's surely referring to the basic equation for rolling resistance, which is proportional to weight.
On topic I think there is a specific case where the heavier bike - other things equal - may be faster on a closed loop course. It might be too much a can of worms to go into here though.
Everything equal a heavier bike would be faster on downhill, but slower uphill and flat since there is more mass to move. if things weren't equal, it would depend on rolling resistance, drag, and other factors.
Bikes: Nashbar Road
Liked 341 Times
Speed will also depend on the angular momentum of the wheels which complicates your otherwise correct description.
Quoted: 258 Post(s)
Liked 378 Times
Is this true? Gravity certainly assists when going downhill, but doesn't gravity have the same effect on objects regardless of their weight? Gravity accelerates falling bodies at 9.8 meters per second per second regardless of their weight (in the absence of air resistance). Is this any different for a bicycle rolling downhill? Wouldn't gravity have the same effect on lighter bikes as heavier bikes?
Over the hill
Quoted: 998 Post(s)
Liked 1,206 Times
A bike is only as fast (or slow) as the rider on it.
It's like riding a bicycle
Liked 10,975 Times
tl;dr: you have hypothesized a ride that has never happened in the history of bicycles.
Over the hill
Quoted: 998 Post(s)
Liked 1,206 Times
This assumes that you are maintaining a perfectly constant speed...Which is impossible. Even a ride such as the one you describe is a series frequent deccelerations and accelerations. It happens due to your pedal stroke, shifting, drinking, the wind, changes in posture, tiny changes in terrain and grade, etc etc etc.
Liked 10,975 Times
Quoted: 3957 Post(s)
Liked 7,310 Times
Liked 7,310 Times
Yes, but the gravitational force on a heavy bike is greater than the gravitational force on a light bike. A heavy bike and a light bike accelerate under gravity at the same rate initially, but they (usually) start to deviate once the speed is high enough that air resistance comes into play.
Over the hill
Quoted: 998 Post(s)
Liked 1,206 Times
Of course no ride would be PERFECTLY constant, but the question is if it is constant ENOUGH to make weight negligible. I know that time trial setups often favor aerodynamics over light weight, but yeah I guess the added weight itself wouldn't be considered an advantage.
Quoted: 2490 Post(s)
Liked 2,960 Times
Likes For Trakhak:
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
