Friction shifting with 11 speed Campagnolo
Overdoing projects
Quoted: 784 Post(s)
Liked 1,238 Times
As many have said already, don't use vintage shifters with modern 9+ speed cassettes. Modern shifters have a larger diameter barrel so they both pull more cable (for the wider cassette) and often have longer levers that make precision shifting easier.
Quoted: 57 Post(s)
Liked 41 Times
I suspect it has to do with how clunky shifting from the cassette/chain combo is and personal tolerance for clicks is. A very slick shifting chain/cassette combo shifts quietly and shifts easily, then wants to shift out of gear easily at the shift gate, and overall doesn't give very positive feedback. Some people also don't notice the ticking every wheel revolution when the chain moves off center slightly at the shift gate and touches the next cog and don't feel it's worth trimming if they even notice. Even on index systems you see a lot of people that need a half turn of the barrel adjuster but they don't notice the ticking.
Curious what the lever throw in the biggest cog is though.
Quoted: 237 Post(s)
Liked 83 Times
I have a musical ear/recording engineer ear/trained ear. I have physical challenges, my cadence is very unusual, and I own one bike with indexing, one without. I listen to my body, my bikes. My legs move imperfectly. I never miss a shift with friction shifting, I sometimes miss one indexed (even adjusted to the nines). I never forgot how to friction shift. Friction shift, I can get it to work at the right moment, and around how I pedal. SIS muffs the low gears unless I'm moving in sync. Maybe, I am a spastic retrogrouch. If so, then I may get a second C&V and be done with life. Your mileage and legs will vary.
For the front di2 can't be beat but for the rear have a friction bike and like it it's almost flawless just sucks having to reach down over having it on the bars but the shifting on friction is nice on hills give a little tug and u shift 4 or 5 cogs if u want
Quoted: 1873 Post(s)
Liked 692 Times
You can do that with electronic too. And still not have to reach down.
2019 Salsa Warbird
2019 Salsa Warbird
Disciple of St. Tullio
Bikes: Ciöcc, Bianchi, DeRosa, Eddy Merckx, Frejus, Hampsten, Kondor, Losa, Magni, Pegoretti, Pelizzoli, Pogliaghi, Scapin
Quoted: 267 Post(s)
Liked 334 Times
These are shifting a 10sp cassette....
Bikes: 82 Lotus Unique, 86 Lotus Legend, 88 Basso Loto, 88 Basso PR, 89 Basso PR, 96 Bianchi CDI, 2013 Deda Aegis, 2019 Basso Diamante SV
Quoted: 943 Post(s)
Liked 172 Times
09box
Classic & Vintage
29
04-27-19 10:28 PM
onespeedbiker
Classic & Vintage
4
01-30-13 08:05 PM
