Getting the most value out of your rotors
Quoted: 44 Post(s)
Nailed it. He was also able to finish the ride albeit with somewhat reduced braking.
Obviously more aggressive (Downhill MTB) a rider than I .. (JRA around town)
I note the Avid disc is thinner than the Magura Disc.. and so Shimano may be more like A, than M..
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
"I CAN'T HEAR YOU OVER THIS TERRIBLE NOISE THAT IN NO WAY IMPLIES SOMETHING IS TERRIBLE HORRIBLY WRONG"
-Bike owner
-Bike owner
Quoted: 44 Post(s)
Bikes: ...a few.
Quoted: 2012 Post(s)
Liked 409 Times
Minimum thickness 1.50 mm is what it says on mine. I changed them at 1.60. If that was the front it could have been castastrous!
Quoted: 4227 Post(s)
Liked 2,488 Times
Some of my rotors are 11 years old. I never measured them yet. Mine are used mostly for commuting and a little bit off road trail riding.
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
I blow through XT/Ultegra rotors about once per year. (I replace them following the Shimano wear recommendation.)
Non omnino gravis
Clark W. Griswold
Quoted: 4367 Post(s)
Liked 4,006 Times
Gotta love cheap people, they run their equipment into the ground and can get hurt but don't want to pay a cent to fix anything but somehow want it to work.
Quoted: 44 Post(s)
The truth is that he had the replacement rotor on his shelf and just hadn't gotten around to swapping it. Nevertheless, his rear brake continued to work and didn't pose an injury risk despite your chicken little comment.
Callipygian Connoisseur
Quoted: 564 Post(s)
Liked 350 Times
Organic pads FTW. I like the modulation much better and they feel better in the grip with mechanical discs. With organics, the pads wear more, rotors less. True, organics aren’t the best for every application, but for my purposes they’re the pad of choice. Also, I’m not a big fan of stainless/aluminum sandwich rotors. I suppose a laminated rotor tests better under lab conditions but in the real world I doubt they provide any tangible benefit.
-Kedosto
-Kedosto
Clark W. Griswold
Liked 4,006 Times
Gotta love hysterical, judgmental people who assume that his rotor wore out because he was too cheap to pay a cent to fix it.
So maybe he wasn't too cheap to buy the rotor but certainly too cheap to get it installed or just too lazy to do it himself and allowed it to get to the point of being unsafe. That rotor was worn down past the limit for a long time or they did almost nothing but braking that entire ride and wore it down in an afternoon. Sure his rear brake was functional at the time but that doesn't change much. A person has two firearms in their hand they shoot one person with one hand but didn't use the other. "but Officer, this hand didn't shoot anybody".
If you don't take care of your equipment you can end up hurt pretty easily. Your title was "Getting the most value out of your rotors" not something about a defective product so I responded as I did because I see this all the time. People too cheap or lazy to think about their own safety and in some cases the safety of others and it is wrong. We can all make excuses but in the end this is not a smart thing to do, letting your rotor wear down to the point it breaks apart. Luckily it seems nobody was hurt but things can happen and people can get hurt or die because their brakes don't work.
Though again for reinforcement I am quite calm, chewing some delicious tropical fruit flavored bubble gum and posting about bikes. I also have youtube playing in the background, Rick and Morty clips actually.
Non omnino gravis
i've ridden several other bikes with "regular" rotors, and they definitely had a sweet-spot where they worked the best, while the IceTech feel the same at the lever just all the time. Hot, cold, wet, doesn't matter.
I wouldn't be buying rotors that cost 5x as much and weigh 3x as much if they didn't work better.
Quoted: 44 Post(s)
Clark W. Griswold
Liked 4,006 Times
Also people do get hurt and one of the former owners at my shop's son died because the shop she took his bike to didn't properly fix the brakes and he slammed into a semi truck. I have also seen the effects of people not having safe brakes and getting less majorly hurt. You can face palm all you want but I should be the one face palming you.
Quoted: 44 Post(s)
Yes. People do get hurt. While I am typing right now thousands of people around the world are getting hurt. Also, the Sun rises in the East.
His rotor was safe. He continued to ride safely, without getting hurt, as described above.
Most folks aren't so Glum.
Clark W. Griswold
Liked 4,006 Times
https://youtu.be/uqALm_rmM1g?t=29
I cannot believe you are trying to argue that rotor is safe. You or your friend are literally holding fragments of rotor in your hand that had collected by the caliper. How is that safe? Y'all are running off the rails on a crazy train.
Quoted: 44 Post(s)
I get it. You're a super fearful person. That's ok. Hopefully some day you'll understand that many folks don't go into hand wringing mode when something harmless happens during a ride.
His rotor was safe? What about being worn and broken is safe? Being able to finish a ride and being lucky to have done so, does not equate safety. I don't know what sort of Bizarro world you come from but that rotor does not look safe. I took a lighter and a can of hair spray and didn't get hurt so it must be safe, no?
Quoted: 5224 Post(s)
Liked 3,585 Times
impressive!
There was still half of the clamping area left. He continued to ride safely and was uninjured. He even continued to have fun. So yeah, it was safe. Luck had nothing to do with it.
Brakes on a bike are probably the most important part and should be 100% in working order 100% of the time, for every ride. Glad your buddy made it safely home. He might not next time. You're hard headed. Relax for a change.
Quoted: 44 Post(s)
Boy, you've made quite a debut here on the forum. 26 posts and they are all rather instigating. Just imagine what the future holds for you....Glad your buddy made it safely home. He might not next time. And there's no arguing that point as you have.
0%
