Addiction LXXVIII
Addiction LXXVIII
Old 07-29-20, 01:29 PM
  #15801
Klaatu..Verata..Necktie?
genejockey's Avatar
Quoted: 10477 Post(s)
Liked 11,995 Times in 6,143 Posts
Another thing to know about the Hwy 1s - there's no flare to the drops, which makes old second generation Ergo levers feel like the brake levers are almost pointed inward. Not a big problem and I got used to it within minutes. But it will probably feels strange going from the R7000 105s on the Canyon to these and back. If you're putting 105s on Hwy 1s, the outward pointing levers will probably feel fine.
genejockey is offline
Likes For genejockey:
Old 07-29-20, 01:31 PM
  #15802
genejockey's Avatar
All this bar talk got me motivated to finally put these flared drops on the Lemond. Bar tape tonight, and possibly a short test ride. Still gonna be 105° at 10pm, so no serious test ride 'til tomorrow morning.
Oooooo!! Pretty!!! Dang, that looks like fun!!!
But if you don't mind my asking, how do you get the tires through the brakes?
Old 07-29-20, 01:35 PM
  #15803
cowboy, steel horse, etc
LesterOfPuppets's Avatar
Bikes: everywhere
Quoted: 12843 Post(s)
Liked 7,763 Times in 4,118 Posts
They slide in fairly easily at 25 psi, takes a little coaxing at 40psi. Would be even easier if I'd reset the caliper width to the width of these rims so that I could release the calipers, but some other day
LesterOfPuppets is offline
Old 07-29-20, 01:41 PM
  #15804
mvnsnd's Avatar
Bikes: Factor O2, Caad10, Caad2
Quoted: 365 Post(s)
Liked 122 Times in 78 Posts
Originally Posted by MoAlpha
Any you old crumbs ever put stick-on + lenses on your cycling glasses? Wondering if they survive sweat and daily cleaning.
I have often wondered this myself.
mvnsnd is offline
Old 07-29-20, 01:46 PM
  #15805
genejockey's Avatar
Hmmm. Maybe I'll see if the 28s can be fitted to the Battaglin that way. The old Ergo levers don't give you a lot of opening. I figure there's MAYBE 5mm chainstay clearance on each side with 25s, but the wheel has to be PERFECTLY aligned. The front's no problem - ever seen a MAX fork crown?
Old 07-29-20, 01:52 PM
  #15806
Bikes: everywhere
Originally Posted by indyfabz
The bridge timbers are likely wood.
Think this is the bridge:
https://www.google.com/maps/place/Te...4d-111.9276565
The relatively new, double track bridge to the right is the light rail line.
Oh Yeah, I've been looking at more footage and leading up to the through-truss section from the north it looks like all timber trestle. Folks on the local anti-masker FB group figure it was Antifa
And yep, that's the light rail to the east, I've ridden those rails a few times.
Old 07-29-20, 02:23 PM
  #15807
Administrator
BillyD's Avatar
Quoted: 11983 Post(s)
Liked 6,703 Times in 3,504 Posts
Heavens no. No, sir.
BillyD is offline
Old 07-29-20, 02:24 PM
  #15808
Quoted: 18468 Post(s)
Liked 15,735 Times in 7,397 Posts
Wonder if there is a viable detour.
The bridge that became the Walkway over the Hudson, in Mr. D’s neck of the woods, was torched by vandals. Think it was in ‘73. I’ve ridden across it twice. Quite nice.
Old 07-29-20, 02:50 PM
  #15809
LAJ
So it is
LAJ's Avatar
Quoted: 11425 Post(s)
Liked 4,794 Times in 2,786 Posts
Stick-On Cheaters. Whoda thunk.
LAJ is offline
Old 07-29-20, 03:54 PM
  #15810
Bikes: Shmikes
Quoted: 10188 Post(s)
Liked 5,892 Times in 3,175 Posts
Originally Posted by BillyD
Heavens no. No, sir by cracky!.
MoAlpha is offline
Old 07-29-20, 04:13 PM
  #15811
serious cyclist
Bah Humbug's Avatar
Bikes: S1, R2, P2
Quoted: 9334 Post(s)
Liked 3,679 Times in 2,026 Posts
Whelp, ordered up new windows to hopefully help with the noise issue. Think the current ones weren't doing much in that department.
Bah Humbug is offline
Old 07-29-20, 04:39 PM
  #15812
smelling the roses
seedsbelize's Avatar
Quoted: 7081 Post(s)
Liked 901 Times in 612 Posts
Originally Posted by Velo Vol
Inner screw counter clockwise? I turned it some and nothing seemed to happen.
Yes
seedsbelize is offline
Old 07-29-20, 04:52 PM
  #15813
genejockey's Avatar
It went great, till I got to the bend. For a while, I was afraid I was just plain stuck. I think these are more square, that is the tops are longer and straighter before the bend, so it's more acute. If I had my druthers, I'd have used the 3T Motus, if the clamp part hadn't cracked.
So, while I was looking to see if others had the same problem with Motus stems, I stumbled across a thread on that very topic. And on that thread, I read that Salsa's CroMoto SUL stems had been recalled. Well, hell! My Ritchey has had one of those, for the last 12 years!!! I guess I'm lucky I had other bikes! I had no idea they'd been recalled! It gave me the retroactive willies!
Now I have to thread one end of the bar through the Ritchey stem I took off it because the black Salsa stem looked better with the rest of the bike. And rewrap the bar.
Poop.
Old 07-29-20, 05:07 PM
  #15814
smelling the roses
A positive side to the cut off finger presented itself this afternoon. My DeWalt drill driver slipped off the screw and poked a hole through the base of my fingernail, drawing blood. I hardly felt it.
Likes For seedsbelize:
  #15815
serious cyclist
Bah Humbug's Avatar
Bikes: S1, R2, P2
I guess?
Likes For Bah Humbug:
Old 07-29-20, 05:22 PM
  #15816
Silver Comet Fred
DougRNS's Avatar
Bikes: 1
Quoted: 8871 Post(s)
Liked 3,023 Times in 1,756 Posts
I spent 7 hours on Saturday, refitting my Battaglin MAX bike. New cables, new rear derailleur, new cassette, new tires, new handlebar, new bar tape. It took so long because I was trying to make a short cage Centaur derailleur work rather than swap in the medium cage Veloce I'd bought for the job. So after a lot of time spent fruitlessly, I swapped in the Veloce and voila! It works. Now I'm running 53/39 and 12-30.
The frame is so old, it doesn't take a regular cable guide under the BB. No, it's got a plate with two holes in it. And for years, I've been tolerating the sub-optimal shifting from all the added friction it causes. I threaded some shift cable liner through the holes, and fed the cables through that, heavily greased.
New bar, because the Cinelli Nerve I had on it is 1) real old, and 2) a LO--O-ONG way down to the drops, compared with what The Cool Kids are using these days. I used a SOMA Highway One, which is the right shape, and unlike nearly every other bar, it comes in 26.0 and silver. Finished it all off with white Fizik tape. Even got some white gloves just for this bike, so I don't foul the tape as quickly.
I thought about getting 28s, but the 25s I've been running barley fit though the calipers as it is. And the chainstays are pretty close to the tires. SO instead I just replaced the old Ultra Sports with new GP's, pumped to 100/105.
Today was the 'shakedown cruise'. The new bar fits well, in fact it might need to drop a cm or so - at the same stem height, I feel more upright. Or maybe turn the bar down a hair. Shifting was MUCH better! AND the 30 works well! And I think that the tires made a big difference, even though they're the same size at the same pressure. Felt much less rattly. I'm in love all over again!
Oh to have a red bicycle again.
DougRNS is offline
Likes For DougRNS:
Old 07-29-20, 05:26 PM
  #15817
Silver Comet Fred
DougRNS's Avatar
Bikes: 1
See, confirmed, although I’m waiting for the DougRNS endorsement. lol
He's legendary for sure. A legendary what? You decide.
DougRNS is offline
Old 07-29-20, 05:28 PM
  #15818
Silver Comet Fred
DougRNS's Avatar
Bikes: 1
Happy Birthday Geddy Lee!
With those "guns" he could be a serious cyclist.
DougRNS is offline
Old 07-29-20, 05:30 PM
  #15819
Bikes: everywhere
We've had these paper towels for weeks, and I just now noticed they've got bikes on 'em. Weird.
Likes For LesterOfPuppets:
Old 07-29-20, 05:32 PM
  #15820
Bikes: everywhere
In other weird news.
No. Not even gonna try it.
Old 07-29-20, 05:33 PM
  #15821
Silver Comet Fred
DougRNS's Avatar
Bikes: 1
Apparently you're a glass-half-full kind of guy. who knew?
DougRNS is offline
Old 07-29-20, 05:39 PM
  #15822
Administrator
BillyD's Avatar
Yup.
BillyD is offline
Old 07-29-20, 05:41 PM
  #15823
Administrator
BillyD's Avatar
Look, forget about it, you’d have to damn near kill yourself in order to catch up with trainsnorter.
BillyD is offline
Likes For BillyD:
Old 07-29-20, 05:46 PM
  #15824
Super Modest
Trsnrtr's Avatar
Quoted: 10982 Post(s)
Liked 4,652 Times in 2,138 Posts
I’d take it personally if it wasn’t true. It’s almost daily that my wife points out that I’m bleeding and asks me if I’ve been near sharp things again. The funny thing is, I hardly notice anymore.
I’ve got a gash on my left shin at the moment and have no idea where or how or when it happened.
Keep the chain tight!
Trsnrtr is offline
Likes For Trsnrtr:
Old 07-29-20, 06:09 PM
  #15825
serious cyclist
Bah Humbug's Avatar
Bikes: S1, R2, P2
Mustard is disgusting. Beer is disgusting. The fruit of this unholy union can only be an abomination.
