Whoa! Just calculated my on-ride accessories (inc. pedals) weigh nearly 2kg
Bikes: bikes
Quoted: 2622 Post(s)
Liked 1,429 Times
How are pedals an accessory? They're a fundamental part of the bicycle. You cannot ride without them.
Might as well say wheels are accessories.
Bikes: bikes
Liked 1,429 Times
It’s to get a common baseline for comparison. If you included pedals in the weight, which ones would you use? The lightest possible titanium ones or regular mid-price ones? It would add doubt to the real weight of the frame etc.
What is pretty certain is that any manufacturer who quotes weight will have stripped the bike down to the absolute minimum - probably leaving the air out of the tires :-)
Wheels, tires, stems, bars, seat: all of that varies significantly from bike to bike. They're all essential parts, just like the pedals.
Non omnino gravis
As for wheels, tires etc. these are generally a defined part of the build for a particular model of bike, so it's fair to include these in the weight. They will sell all bikes of that model with the same spec. You normally can't change this unless you have a custom build.
In an ideal world, every single major component (wheels, groupset, frame, bars, pedals etc.) would have its weight listed so you can see how it is distributed.
As it stands you just know that you have to add the weight of your chosen pedals - which can vary quite a bit.ou
It becomes a moot point when you add a bottle or two of water and the usual bike electronics!
Quoted: 1743 Post(s)
Liked 1,281 Times
I weigh my bikes with just pedals because I could ride them just that way if I wanted to. Then I weigh them with all the "junk" that I ride with. I find the difference is about 1 1/2 lbs.
Quoted: 7653 Post(s)
Liked 3,479 Times
Quoted: 539 Post(s)
Liked 44 Times
On my commuter I consolidated all my bags into only one racktop bag. It wasn't for weight savings, it was because I lock up my bike outside and don't want to leave anything on it, but it did stand out that you have a lot of bags and bag adapters.
I also use a simple wired speedometer, for any more sophisticated tracking etc I use my cell phone. I always bring my cell phone with me so it might as well do double duty.
I'm not paranoid about weight past that, since I carry my ulock with me any additional weight is tiny in comparison.
That said, if I were going anywhere remote, where there would be little possibility of support or alternative transport, I would take everything I needed to keep the bike going bar major catastophes (broken wheel, frame etc.)
I can alsosee the possibility of having a minor crash and needing to realign bars, saddle etc. so at having at least the appropriate allen key is probably a good idea.
It’s pretty easy to get the weight down once you have a scale. There’s about a third of the weight each in wheels, frame, components. I did the weight weenie thing both because I enjoy a light and responsive bike, and because as I get older, it gets harder to heft the bike up on top of the car (shoulder injury). So when I built a bike a few years ago, I worked with a builder locally to do a custom stainless steel frame and got the bike down to 16lbs (sans pedals). What I discovered is that there is a lot of weight hidden in wheels that can be trimmed (tubeless is a good start), saddles are all over the map (A brooks is a monster in terms of weight, for example). But by being careful, you can get the weight down and while it’s more expensive it doesn’t have to break the bank either.
J.
J.
Liked 3,479 Times
over the course of decades, I have had a crank loosen, a seat post, a stem, bars .... hit a big bump or had a wreck and torqued stuff .... I have had cables break and needed to lock the derailleur with the limit screws .... have had chains break ... all kinds of stuff. And on more than a few rides i have found myself loaning a tool to a rider who "never needed one before."
But i cannot say my way is the right way. Some folks have never had a flat and are sure they can always get a ride. Some folks have never needed tools. Their experiences dictate their choices, same as mine do mine. So ... we are doing the same thing in different ways.
i have also had bottom brackets seize, or wheel bearings ... and I am not about to carry parts and tools to service those things. Whatever.
The least I like to carry is a Y-allen wrench (I think it is 5,6,7 mm---it is the three common allen sizes) and a two-ended screwdriver. I always carry a tube, usually two, and a pump. I have talked to people who said they carry CO2 and if they got more than one flat they 'd walk .... but I have yet to see anyone try that halfway into a 50-mile ride, and walking in cleated shoes hurts the cleats and the walker. Those are the guys asking if I have any glueless patches, and oh, the nozzle on that CO2 cartridge was cross-threaded (never that they cross-threaded it) , can i use your pump?
But hey ... they made it home same as i did, so who's to say what's best?
Non omnino gravis
I've given up on QR levers, strongly favoring the ControlTech Race Skewers-- hey, saves a watt, right? Those need a 5mm hex to take a wheel off, and if I'm going to carry a 5mm, might as well carry an assortment.
When I was umm... heavier, I had to raise my saddle up pretty much daily, as it would slide down about 1/4" on every ride. So I've just gotten used to having tools. I feel weird without the tools. Started using this guy around the beginning of the year, no complaints:
Quoted: 1814 Post(s)
Liked 923 Times
My bike ready to ride with all except water weighs 16.75 lbs.
Including bottle cages, Bolt & mount, front & rear blinkies, bell, power meter, 11/34 cassette, & bag w/
spare tire, pump, tire levers, 3 allen keys, pliers, chain tool, quick links (10 & 11sp), patches & glue, tape, bandages, gauze pads, money, pencil & paper, needle, thread & thimble
knife, zip ties, valve cores, valve extension, valve core tool, & poky tool.
Maybe less w/ different wheels but that's what's on there now.
Shoes with cleats also weigh 18 ozs for additional 3/4 lb saved.
What happened?
Quoted: 1835 Post(s)
Liked 292 Times
See Tempest in my avatar? She has a rack made with rebar, a washing machine panel angled steel L rods custom welded and two frames from old fiberglass motorcycle panniers I replaced with Saddleman saddlebags, a taillight, it has gothic fenders and a tank.
Just relax. I can never get it fully other than you race.
Curious as to why you have links for both 10sp and 11sp - for the spare chain? :-)
And, I don't expect to be doing any sewing on my ride....but I guess you might rip your clothes after a fall, and it's a small weight penalty.
Probably good advice :-) It just seems a shame to spend a lot on a CF bike, and then load it with excessive weight.
Ultimately, we need what we need for our given circumstances, and it's just a question of working out what this is. But I'd rather make sure that every item carried has some utility, rather than just lugging it around "just in case"...
Liked 923 Times
2008 Tarmac. It's 10 speed, but also carry an 11 sp quick link for samaritan purposes- it's light.
The needle & thread is for repair of the tubular tires that I run, 'tho odds of doing that out on the road are small- more of a nod to BITD.
The thing that I'm always promoting is to bring a small roll of 1st aid tape- useful for a range of issues.
Liked 1,281 Times
Actually I carry one of those 3-way hex wrench tools but it's in my back jersey pocket. I also carry my cell phone, some Hammer gel in a flask, and a couple bucks. On a short ride I don't usually carry any edibles.
Liked 1,281 Times
Saw your follow up and tried to delete my post but the site won't let me.
johngwheeler
Road Cycling
55
03-14-18 04:51 PM
loimpact
General Cycling Discussion
33
06-30-16 01:23 PM
