Schraeder "valve creep"
Quoted: 5224 Post(s)
Liked 3,585 Times
Quoted: 7351 Post(s)
Liked 2,478 Times
I predict you won't have the problem. Most of the valve creep comes not from riding underinflated tires but from wheeling the bike when the tires are uninflated. You can get a ton of creep rolling it a short distance. Try not to think about the problem.
Likes For noglider:
Quoted: 18378 Post(s)
Liked 4,512 Times
Just epoxy the tire to the rim. Never have to worry about it again.
Likes For CliffordK:
2-Wheeled Fool
Bikes: Surly Ogre, Brompton
Quoted: 1385 Post(s)
Liked 677 Times
Its funny how we all get restless this time of year. Its funny how we'll discuss anything, and even the most rudimentary topics become a hotbed of discussion. At least we're all amicable!
For what its worth, I won't even add air to a customer's schrader-tubed tires if its gotten crooked. I'll always deflate all the way, break the bead, and rotate the valve into the correct position. I'm pretty OCD about that sort of thing. Hey, I would notice it if an LBS mechanic did that to my bike, so why would I taint my reputation. If its not right, it doesn't leave the shop (customer idiosyncrasy's notwithstanding)!
Quoted: 3464 Post(s)
Liked 2,831 Times
Totally forgot that in the early 70's at least there were Rim Locks for motorcycle tires- a hard rubber oval piece that caught the beads on both sides, held in position with a bolt through a hole that looked a bit like a schrader valve.
Not sure how the mass was accounted for, maybe near opposite the valve? Balanced later? If at all, these were for off road bikes, where low inflation could help, like sand dunes.
Quoted: 765 Post(s)
Liked 660 Times
www.redclovercomponents.com
--Ogden Nash
--Ogden Nash
Likes For jonwvara:
2-Wheeled Fool
Liked 677 Times
...Because they always have a buddy sitting in a tree going, "CAH CAH CAH!"
Likes For J.Higgins:
Liked 4,512 Times
Liked 3,585 Times
Liked 3,585 Times
"SURE!"
Quoted: 65 Post(s)
Liked 56 Times
Schwalbe sells fully threaded Schraeder tubes w/a retaining ring like on Presta tubes: https://www.schwalbetires.com/bike_tires/tubes/finder. Those hold pretty well.
Liked 4,512 Times
The Conti tan sidewalls seem somewhat fragile. The squeeze and drag will fuzz them up.
I can't tell for sure if it structurally damages the tires, but it sure looks ugly.
Oh, plus a tight fitting tire may take more work than other brands to force them to slip.
Liked 3,585 Times
yeah I have some tires that don't rotate on the rims, after both beads are on. so I'm sure to get everything lined up nice before getting the 2nd bead on. guess that's a good thing tho
Mr. Anachronism
Quoted: 526 Post(s)
Liked 256 Times
Passista
Quoted: 868 Post(s)
Liked 721 Times
In my experience valve creep happens mostly by low pressure, but one of my friends had this problem on his front wheel and the only way to fix it was replacing the rim. It always happened after some heavy braking downhill with a loaded touring bike, not on flat ground with the same unloaded bike. We tried more pressure, changing the tire, degreasing the rim, etc., but the valve kept creeping to a 45º angle.
