The "Before And After" Thread
#2951
Quoted: 2367 Post(s)
Liked 1,757 Times
I've posted this on a couple other threads, but it fits here as well. 1995 Univega Alpina 5.1
Snatched in the nick of time from the bed of Fred G. Sanford's truck, along with a 2001 aluminum frame HardRock that I later flipped.
I think I actually got the chain and freewheel de-rusted, although this ^^^^ is a different freewheel and rear wheel. And the rear derailleur still works. Tires are a mismatch; the front is a cheapo Kenda, but it makes for a marginal visual match.
#2952
Merz rescue
An old Merz randomly showed up in the next town over. The seller was maybe the second owner. He purchased it in the 80s and rode it quite a bit, but it was still in good shape. When I got it home, I realized that the driver side rear drop out was cracked. I tried to have it repaired locally. When I sent it off to Franklin Frames for paint, Jack wasn’t satisfied with the drop out repair and redid it himself. As for the parts – I went with all of my favorite things. It’s generally period correct but I am honestly not a stickler for such things.
Cracked dropout!
Cracked dropout!
Likes For gravelinmygears:
#2955
Edumacator
Quoted: 2514 Post(s)
Liked 3,287 Times
What did you use?
1987 Crest Cannondale, 1987 Basso Gap, 1992 Rossin Performance EL, 1990ish Van Tuyl, 1985 Trek 670, 2003 Pinarello Surprise, 1990ish MBK Atlantique, 1987 Peugeot Competition, 1987 Nishiki Tri-A, 1981 Faggin, 1996 Cannondale M500, 1984 Mercian, 1982 AD SuperLeicht, 1985 Massi (model unknown), 1988 Daccordi Griffe , 1989 Fauxsin MTB, 1981 Ciocc Mockba, 1992 Bianchi Giro, 1977 Colnago Super, 1971 Raleigh International, 1998 Corratec Ap & Dun, 1991 Peugeot Slimestone
#2956
blahblahblah chrome moly
Quoted: 1206 Post(s)
Liked 2,644 Times
Too bad because they're small and light and elegantly shaped, so I wanted to like them.
Here's one I repaired a while back, on a circa 1980 Glenn Erickson custom that he made for a 6'6" cat 2 racer, but on his touring bike. The repair is easy, just fill in the big semi-triangular window, fully or partially. Shimano could have made these never break if they'd just done this smaller window originally in the forging. Oh well.
The crack can also be welded, after Vee-notching from both sides, but on this one the crack ran very close to brass from the original braze, and you can't weld right next to brass. The brass vaporizes and gets into the weld, making it brittle. I brazed it with nickel-silver, which is stronger than brass, about the same strength as the steel of the dropout. Stronger than any feasible way to weld it.
The Franklin Frames repair looks excellent. Congrats on bringing a worthy frame back from the not-quite-dead.
Mark B
#2957
Quoted: 1150 Post(s)
Liked 1,780 Times
I hit it with water and sprayed turtle wax tire & wheel wash. Let set for 30 seconds, work it in lightly with a bristle brush, rinse and repeat. I find that stuff works leavening a supple feel. It's like scrubbing bubbles. Better than Dawn and toothbrush, that can leave your hoods feeling sticky.
Works wonders on encrusted alloy, I use it on brake calipers and pads. I recently used some on a pair of derailleurs, it's not a grease cutter but if all the solute is evaporated it makes them sparkle.
I use gloves, its harsh stuff chemically.
#2958
Bikes: '85 Schwinn Madison, '46 Higgins Ultralite, 1950s Wally Green, '85 Trek 660, '82 3Rensho Export, '90 Trek 970, '91 Schwinn Paramount, '78 Dawes, '78 Trek 730
Quoted: 80 Post(s)
Liked 280 Times
'46 Higgins Ultralight
I bought this bike in Dayton Ohio. I suspect it came back with a serviceman after WW2. I stripped and repainted it with SprayBike products. Tried to get to more period correct parts. One challenge is the frame bottom bracket has no threads, it required a Bayliss Wiley Oil Bath Bottom Bracket. The idea was it could be oiled thru a port rather than disassembled. The bb is held in with compressive force.
#2959
Quoted: 4538 Post(s)
Liked 6,455 Times
Likes For merziac:
#2960
Wheelman
Bikes: 1982 Holdsworth Avanti (531), 1961 Holdsworth Cyclone
Quoted: 300 Post(s)
Liked 692 Times
1961 Holdsworth Cyclone (22" seat tube)
Before is March 2023
After is from earlier today
(original colour was flamboyant red, now it's red with metal flake)
Likes For bOsscO:
#2962
Wheelman
Quoted: 300 Post(s)
Liked 692 Times
Cheers,
Hardest bit was getting the paint right, it's supposed to look like Holdsworth Red pearl
Edit: Hand painted with a brush or three.
#2964
Quoted: 100 Post(s)
Liked 436 Times
Before/After …
Just finished a restomod on this 57cm 2002 LiteSpeed Arenberg. Had lots of fun with the cosmetics …
JD, Dallas
Given away by an Old Biker-Before
Restomoded 2002 LiteSpeed Arenberg -After
JD, Dallas
Likes For jim dandy:
#2966
Quoted: 100 Post(s)
Liked 436 Times
I see what you mean. I bought a new decal set from LiteSpeed and they do install flush. In this picture, all the decals seem raised. Pictures taken by my iPhone7. So, don’t know how to explain it … The headstem badge is slightly raised due to the 3M automotive grade double sided tape I used on it. It will never fall off again.
JD
#2967
Liked 6,455 Times
#2968
This is a 3 month resto-mod project that I did. Picked up this 1993 Trek Antelope 830 on Craigslist for $50. Knowing it had some potential, the bike was stripped down, cleaned and rebuilt with some upgrades and modifications. Mainly, changing the drivetrain from the original 3x7 to a 1x9 and using trekking handlebars really made the bike different. Some before and after shots:
Likes For clarkbre:
#2969
Quoted: 2340 Post(s)
Liked 5,188 Times
I guess I can add some of the latest bikes.
Picked up this 84 Raleigh Racing a week ago. 23 lbs 14 ozs as I picked it up.
Saddle and seatpost swapped, new cables. housings, full clean, frame polish, new tires, latex tubes, headset and BB serviced, degreased, lubed, and temp Mavic wheels has it down to 20 lbs 8 ozs. Oh and pedals swapped and a bottle cage installed.
Last winter I picked up the Raleigh Technium Supercourse that was 24 lbs 14 ozs with heavy Exage parts and a rear rack.
A full teardown then rebuild with nice Dura Ace/Ultegra parts gave me a real beauty the now comes in at 20 lbs 12 ozs. This rides so nice and all the parts work great!
Then I also picked up a Cilo locally as a project. Sorta rough but some nice Shimano 600 parts on it.
Another full tear down, paint touch up, lots of parts polishing, consumables replaced/upgraded, etc. This was donated to the local bike collective once I finished with it.
And one more.....
This is still a work in progress but here's a Merlin bike I also found locally. Came to me with a Dura Ace build, the FSA crank and the Deore Long Cage RD and some not so good wheels.
Swapped on some nice Fulcrum Racing 0 wheels with GP 5000 tires and latex tubes. Thomson seatpost Avocet Saddle, Zipp stem, new cassette and chain matched to some sweet Wickwerks 53/34 chainrings. New cables and housings, pedals, full service, etc.
And one more.....
Steel is real...and comfy.
Likes For jamesdak:
#2970
Quoted: 63 Post(s)
Liked 277 Times
Daywood,
JD
JD
I forgot to mention with my earlier note that it’s a great looking bike and I really like your upgrades.
Likes For daywood:
#2971
Bikes: Focus trash find commuter, Eddy Merckx Corsa, BP Stealth TT bike, Leader 720 TT bike, Boardman Comp Hybrid drop bar conversion, Quantec CX budget cyclocross build, SerottaNOS frameset ready to build up!
Quoted: 129 Post(s)
Liked 105 Times
Does it shift nicely?
#2972
Liked 5,188 Times
Oh yeah! Wickwerk's chainrings have ramps that lift whole sections of the chain up vs just a pin. I've had 3 or 4 sets on various bikes and they shift really well and quickly. Especially when going from small to large. Wickwerks is a huge player in Europe for the Pro CX crowd.
Likes For jamesdak:
#2974
This ended up being a very long term project due to various life events, still a few odds and ends to work out but completed for the most part.
Before:
After:
Before:
After:
