Steel fork dropouts damaged in shipping - can I pry it back?
Quoted: 6256 Post(s)
Liked 4,860 Times
Well if the guy builds steel bikes from the ground up then he should probably know better about your specific issue since he was able to see, touch, feel and smell it in person. With us here at our keyboards, all we can do is look at a picture that gets grainy and unfocused when we try to zoom in.
Though being apprehensive, you should do what makes you feel good. Though based on his recommendation, I'd probably ride it. Though I would check on it often at first, and then as time goes by, probably check a little less often, but still check on it every now and then regardless.
This probably will have been better posted in the Bicycle Mechanics sub-forum as I see more of the members that also hang out in the Framebuilders sub-forum in there. I'm not certain if any of them have responded here, and I seldom see the ones I know build frames in this sub-forum.
Quoted: 988 Post(s)
Liked 1,653 Times
Well... I have cold bent, heated, drilled, hammered, forced, jammed, kicked, and sworn at so many parts of my bikes I should be very, VERY, afraid to ride any of them...
Duh... Call the lawyers?
Man that's just what I need...
Look Stud... Get out that bike and ride! Its not proven till its proven...
Quoted: 1119 Post(s)
Liked 1,214 Times
Any failure of the fork can kill you pretty quickly as a close acquaintance of mine found out (RIP). Failures on other parts of the bike are much less likely to be catastrophic in that sense. I would tread very carefully on any fork-related damage, including the dropout.
