Mountain bike chain has multiple links broken
That’s definitely a weird one. My suspicion if something like this turned up at work would be a problem with the batch of steel. It’s hardly your fault. Throw it away and buy a new one and forget about it. Unless you think the effort you were going to put in to get a $20 replacement chain is worth $20.
I'm just worried if something else could go wrong that caused this. This is actually very dangerous if happening while riding, guess I'm lucky it happened when I tighten the pedals. I worry if something is wrong with the bike, this could happen again.
Something like bike setting, shifting, cassettes or chainring. Could some other parts of the bike potentially cause something like this?
I read in some other online posts that mentioned bent cassette teeth. I never crash my bike on the cassettes side, but still would like to know if anyone has any experience in this area.
Yeah, going to get a new chain anyway. I'm also going to ask my local bike shop where I bought the bike for advice as well.
Likes For cpach:
Bikes: n, I would like n+1
Quoted: 127 Post(s)
Liked 133 Times
A bent up cassette tooth might eventually through some bad luck result in a mangled side plate, or one popped off of the rivet. Neither of those are what you have here. Your issue is likely isolated to the chain, and from what you have said so far was likely introduced during manufacturing.
Bikes: Trek Domane SLR 2019, Trek Trek Madone 5.1 (2011), Trek 1400 (1991)
Quoted: 47 Post(s)
Liked 74 Times
Not an metallurgist, but I did some QA work for a chain company, this could have been a problem with heat treat.
Likes For Buzzkill53120:
Quoted: 6269 Post(s)
Liked 4,863 Times
You should contact KMC and see what they say about it. Send the pic to them in an email to info@kmcchain.us and ask them about it. They need to see it as it does look to me that it might be the result of a bad batch of chains.
Here is their contact page if you are in the USA.
https://kmcchain-us.3dcartstores.com...tion=contactus
If you are in another Country or region you should probably should find the KMC site for your region and use that contact information.
Unless you pedal at 20-40 rpm putting out massive amounts of power standing on the cranks, I can't see how that happened.
You should contact KMC and see what they say about it. Send the pic to them in an email to and ask them about it. They need to see it as it does look to me that it might be the result of a bad batch of chains.
And yeah, I'm quite new to mountain biking. Don't ride that hard at all.
SE Wis
Quoted: 2751 Post(s)
Liked 3,409 Times
I wonder what Papa Ado has to say about this.
Update: Went to the bike shop today. They also agree that this is a chain defect. They offer to file a warranty as well. I decided to buy a new Shimano chain and keep the breaking chain. (this is my first real mountain bike and first mtb chain)
So I can prove to people I have 10000W legs.
I will also contact KMC to let them know if there is a potential defective batch of chains.
Thank you for the help everyone!
Updates from KMC. They first ask me what I use to fill the park tool cleaner. I told them I used Park Tool CG-2.4 Chain Gang Chain Cleaning System with 8 oz. bottle of Bio ChainBrite
A few days later, they replied this:
Well, I'm not sure about this. I have replied again. Stating I used muc-off dry lube each time after cleaning. And if that will cause harm...
Anyway, just for reference, I really don't think product from parktool would do harm to the chain. But anyway.
After reviewing the Park Tool Bio Chainbrite Cleaner used with Chain Gang Chain Cleaning System, we find that it is a natural plant based degreaser. This causes the chain to lose the injected lubrication.
Below is the screenshot for the Bio Chainbrite Cleaner for your reference.
We do not recommend using degreasers to clean our chains as it strips the injected lubricate out of the chain.
We do recommend using soap (non-degreaser type) and water.
Let us know if you have any other additional questions.
Quoted: 1837 Post(s)
Liked 1,711 Times
Your chain cleaning and lubrication regime have nothing to do with the failure mode of your chain and KMC said nothing to claim that it did
Likes For alcjphil:
This sounds like a sort of BS reply. They don't address anything about the obvious failures of your chain and fluff you off by not recommending that you degrease the chain without actually saying that the product you used could damage the chain the way it was in your excellent photo. Shame on them for blaming the victim. At a minimum they should have at least sent you a new chain and gained some good will. And guess what? You have already bought a Shimano chain and if it serves you well, may not buy another KMC chain. At the manufacturer's level, a new chain might have cost them less than $5, pretty cheap good will
I guess I will keep using KMC chains on commuter / cheap bikes. But will use Shimano for my sports bike...
Comparing the KMC X11 and Shimano XT HG701, it does seem X11 is a lot more fragile from the looks of it...Maybe it's a trust issue...
Quoted: 1122 Post(s)
Liked 1,216 Times
KMC gave a total BS reply to the OP's inquiry. There is no way that the OP's method of cleaning his chain had anything to do with the multiple plate fractures. KMC did not address the issue at all. I'm hoping they reply with a meaninful analysis of this failure. I hope that Papa Ado sees this and contributes to this.
FWIW, I will personally avoid KMC chains at least until someone replies with a satisfactory response, not nonsense.
I have been duped into buying a cheap 9-speed KMC chain that turned out to be counterfeit. But I never had problems like the OP did. I even took it up a brutal climb similar to Muro di Sormano on a road with cobblestone quality surface and did not have any problems at all. The worst problem I got is rust when I got caught in rain.
Quoted: 854 Post(s)
Liked 1,084 Times
Yeah, I'm also a bit disappointed. I don't think a park tool product could damage a chain...They have decent reputations.
Agree KMC's response was BS. Most people degrease their chains at some point and not a rash of failures. You have enough posts to contact Papa Ado directly (KMC rep in Taiwan and BF member) Bike Forums - Send New Private Message or Bike Forums - Send Message I'm guessing he will give you a better answer.
Likes For martinori:
I actually also bought a few 7/8 speed KMC chains from amazon or aliexpress. They don't have any issue at all.
This is the first time I use a chain from KMC that is above 10 speed.
Maybe KMC is better with 6-9 speed chain....
Quoted: 4846 Post(s)
Liked 3,976 Times
Simple Green doesn't corrode the steel. With long immersion it changes the grain structure (as I recall reading; I took a metallurgy class 50 years ago but we covered neither bicycle chains nor Simple Green). So cracks can happen in metal that looks perfect. I've been reading about posters having cracks like these in Simple Greened chains for years. (A quick cleaning and good rinse won't hurt anything but days in the full concentration and watch out.)
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,572 Times
We can debate the concentration and soak time, but the standard Simple Green can cause hydrogen embrittlement in steels, leading to this sort of failure:
https://www.doi.gov/sites/doi.gov/fi...SA_2000-01.pdf
Quoted: 854 Post(s)
Liked 1,084 Times
I'm wondering if some of the citrus cleaners may actually have the same issue but don't normally get used on aircraft so don't get the urgent attention that SG does. Just guessing though.
Liked 3,976 Times
Off topic - hydrogen embrittlement is very real. The bike of my avatar was built with a Columbus SL fork that was nickle plated but not heat treated afterwards. At 8000 miles with a 160 pound rider and no crashes, the blades developed cracks around the bottom of the fork crown, 2/3ds circumference on one side, 1/3 on the other. Learned later that nickle plating high strength steel drives hydrogen atoms (molecules?) into the alloy and that a light heat treat was required to drive them out. And those atoms/molecules act like gravel in mortar; not what you want in your house when a small earthquake happens.
The cracks we are seeing here aren't that different from what I had. Now, granted, I didn't spend a lot of time investigating them. Way too close to home for me! (I lived through (barely) a Lambert fork breaking. I'd just ridden that fork down 2000' of descents.
Yeah, the chain that broke in the picture is a 11-speed KMC X11. It comes in stock with the bike.
Admittedly, I have never used "proper" degreaser on my chains. I tend to use diesel to degrease my chains. But only once during the entire life of the chain to remove the factory grease. After that, I never degrease the chain again.
