Disc brakes in road racing
#151
Quoted: 693 Post(s)
commu*ist spy
12 speed? oh god please no...
rim wear is a real thing, especially when it's wet. also, downhill braking in carbon rim brakes is scary AF for me. disc is so much better in that regard. i understand that's really only a small part of the whole picture. in most racing situations, rim brakes will work just fine. but considering most of my rides are training rides, and I live in pretty hilly terrain, I will gladly take any small weight or aero penalty, in order to be safer in my rides.
#155
Nonsense
Bikes: Affirmative
Quoted: 880 Post(s)
Liked 541 Times
Anything that makes it easier to go up hills while either keeping an 11t or letting me switch back to a 53/39 is fine by me.
#156
Quoted: 842 Post(s)
Liked 469 Times
I think the next iteration of Cannondales (and probably a few other companies) will be disc only. I'm really leaning towards the new Cannondale Aero bike and unless the brakes are near the bottom bracket its going to be disc only.
I wish I could just fully convert and sell off my wheels while they still have value, but I can't really afford to replace my TT bike as well. Luckily I just have HED Jet 4's and Flo 60's, so its not like I have thousands invested.
#157
commu*ist spy
#159
commu*ist spy
what's interesting is that they used a rim brake rim for a disc brake wheel..
#160
Cat 2
#161
Quoted: 842 Post(s)
Liked 469 Times
I've kind of swayed towards being pro disc. Before I used to think they were dangerous sawblades of death and the pro's have a point, but after watching some videos of people trying to cut themselves and failing, it doesn't seem that bad. Even if I'm wrong, you could easily throw a lightweight cover on it.
I mean, if there was a real concern about safety, they'd do something about the sawblade that's in between the two pedals. Chainrings have been slicing riders for decades.
#162
Cat 2
That and you can cop some really good deals on new disc brake bikes if you know where to look.
#163
Quoted: 693 Post(s)
Anyone deal with wheel swaps on 2 (or more) MTBs or 2 CX bikes?
#164
commu*ist spy
i think if the wheel follows the shimano standard, the discs should be centered every time. is this not the case?
even if the calipers rub, adjustment is a 5 minute job tops, no more time consuming than changing out pads on rim brakes.
first world problems right?
#165
Quoted: 1851 Post(s)
Liked 679 Times
Presuming the rotors are actually straight, you don't need to bleed the brakes, and you don't accidentally grab the brake while there is not a rotor in there, then sure, it can be quick.
#166
No matches
Bikes: two wheeled ones
Quoted: 1398 Post(s)
Liked 444 Times
They should sell lockout devices you can install on the levers to prevent pulling them accidentally while the wheel is out. I guess they already have those tabs to put in the place of the disc though.
#167
Liked 679 Times
But, I can see someone trying to make a quick wheel change during a race accidentally grab or knock the brake while the wheel is removed -- and then it becomes a question of do you have another bike available?
#170
Hydraulic disc calipers "self adjust." When you squeeze and release the lever, the calipers back out a little from the maximum squeezed position they got to, not back to where they were before you squeezed the lever. This is kind of neat in that the brakes can do things like automatically tighten themselves as the brake pads wear and get thinner.
But if you squeeze them with no rotor in place, the two calipers come all the way together in the middle, and are basically stuck together until you pry the pads apart.
#171
commu*ist spy
i don't see how that's a problem with fast wheel changes. just don't touch the levers, and grab the handlebars by the tops instead of the hoods. if one's competent enough to do fast wheel changes, then one can do it without screwing up the pistons.
#172
Cat 2
I still think the positive out weigh the negatives here, but it's just a fact of how disc brakes will be implemented.
#174
Cat 2
This is the fastest I've seen, but it would mean ANOTHER standard having to be adopted.
#175
The fastest QR I've seen is on my road bikes where you simply flip the lever and the wheel falls out. As Tullio Campagnolo designed it to work.
What is the point of any system where you have to waste time by spinning the QR lever?
As far as compatibility, I have at least 20 road wheels that are plug and play. You take one wheel out and install another with no fussing with brakes or gearing. Why would I want to waste time and frustration in having a system where it is difficult to swap wheels between bikes?
