50+ Thoughts on going tubeless.
#151
climber has-been
Quoted: 3432 Post(s)
Liked 3,567 Times
1.) Nobody said you would get fewer punctures. What has been said is that the majority of small punctures that we get (usually the pin hole type caused by sharp rock, glass or small nail) would be sealed by the sealant...Meaning you can keep on riding or at a minimum you will have to stop and add a little air. Thus saving the hassle of stopping, pulling the tire and changing or patching the tube. <<<---Way more hassle than going tubeless.
#152
Quoted: 2976 Post(s)
Liked 1,182 Times
#154
climber has-been
Liked 3,567 Times
#155
Quoted: 4420 Post(s)
Liked 4,873 Times
Tubeless tyres are not so revolutionary, but have proven to be the evolutionary end game in most other applications, so why not bicycles? Anyway they work for me and I wouldn’t use them if they really were a hassle. For me flats are the main hassle with bicycle tyres, so I’m up for anything that reduces the chances of having them.
#157
climber has-been
Liked 3,567 Times
Progress is great when it solves a real problem.
#158
Liked 1,182 Times
You'll get there eventually. You either lead, follow or fall behind.
https://www.gearpatrol.com/outdoors/...er-going-back/
Then again...maybe you are still using downtube levers to shift gears, toe clips, cup and cone bearing systems, rim brakes and QR axles.
Generally speaking... The road cyclist consumer market is full of laggards when it comes to accepting new/better technology...
#159
Naaah...
Naaaah, not considering going tubeless - BUT I sure would like to lose my 'spare tire'!
#160
Tortoise Wins by a Hare!
Quoted: 1549 Post(s)
Liked 942 Times
The one reason I'm avoiding going tubeless is I never ever want my bike or myself sprayed down with sealant, or have it all over my hands, wheels, tires or garage. Or take on the extra maintenance of adding/cleaning goop. Running tubes is not a hassle in the least. Okay, at least three reasons.
#161
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4338 Post(s)
Liked 2,982 Times
Nonsense,
I have been running tubeless for ten+ years and have never had one fecking hassle. I have not even had a flat in the past four years of riding 5k miles per year.
Seriously dude. Just because a bunch of wanks cannot get their feces congealed is no reason to spray your own feces around the room and make such false accusations. Pull your head our of your lower intestine and the world won't look like poop to you anymore.
I'm glad the option is available; the objective is to determine how beneficial it would be for any particular rider and their riding. For lots of people, tubed tires are preferable; especially if going tubeless would require a new set of wheels that they don't really need. I'd like to help people determine what's right for them, and I offered my suggestions very early in this thread.
#162
Liked 4,873 Times
#163
climber has-been
Liked 3,567 Times
Yes, bicycles tires go flat, which is a problem. But:
TUBELESS GUY: Tubeless solves the flat tire problem, dude!
ME: I'm pretty sure that tubeless tires aren't puncture proof.
TUBELESS GUY: You just don't "get it"!
#164
Habitual User
Quoted: 4957 Post(s)
Liked 8,100 Times
I have found that the hassle of setting up tubeless tires in the beginning easily outweighs the hassle of my average amount of flat tires in a year, and making those repairs roadside, either having been dropped from the group I was riding with, or forcing others to wait while I make my repairs. The one flat I have had on tubeless was a gashed sidewall that would have wrecked a tubed tire similarly. I booted the gash with a dollar bill, stuck a tube in the rim, hit it with C02, and finished my ride. For me, there's isn't a downside to tubeless on the road. The flats that I'm NOT getting is the bonus. (IMO, YMMV)
#165
Liked 1,182 Times
That's the part that SOME people aren't getting. Those pin hole flats would be sealed by the sealant so you can keep on riding or maybe just quickly stop and add a little air. It makes tubeless way less of a hassle than roadside repairs.
#166
Habitual User
Liked 8,100 Times
Other than bicycles and wheelbarrows, I'm tying to think of another inflated rubber tire vehicle that uses tubes....and coming up empty. Disc brakes and tubeless tires have been the standard in the car and motorcycle world for a very long time. Zero surprise that the bicycling industry is adapting to the same technology.
#167
Habitual User
Liked 8,100 Times
That's the benefit I see. I still have not had to do a roadside top-off, but was riding with a guy who did. It was so quick, part of the group never needed to come to a full stop.
#168
climber has-been
Liked 3,567 Times
I know, you don't have to say it. I don't "get it".
#169
Habitual User
Liked 8,100 Times
What does a tube and sealant gain you, except weight and rolling resistance?
#170
climber has-been
Liked 3,567 Times
They weigh about the same, and the rolling resistance is very similar.
Advantage: neither one.
#171
It's MY mountain
Liked 2,982 Times
#172
Habitual User
Liked 8,100 Times
Right. However, adding sealant to a tubed tire setup adds weight. The additional weight inside the tube increases rolling resistance.
#173
Habitual User
Liked 8,100 Times
#174
climber has-been
Liked 3,567 Times
But for the sake of argument, let's say that adding liquid sealant to the inside of a inner tube somehow increased rolling resistance.
Wouldn't this sealant also increase rolling resistance inside a tubeless tire?
#175
Habitual User
Liked 8,100 Times
Rolling resistance isn't caused by weight. It's caused by hysteresis losses from the flexing of the rubber in the contact patch and sidewall.
My thought is that the friction between the tube and the inside of the tire would be increased with more weight in the tube. You don't get that same rub between the inside of a tubeless tire and sealant.
