Is it normal wheels go out of true after a fall?
#101
Mad bike riding scientist
Quoted: 6222 Post(s)
Liked 4,222 Times
You think we are going off topic? We are not off topic, we just dipped down to lower grade level. How are you going to understand grade 8 physics when you don't know grade 7 physics? Now you are complaining about wanting to go back up to grade 8? Is this a joke?
I've tried to child-explain these concepts to you six different ways to no avail. When at first you didn't get it, I dropped down to lower grade level material. Now I have realized you don't know the lower grade material either. Do I have to start dipping into elementary school territory?
Yeah, I'm done. As I said to Sonofamechanic above, if you don't get it any now, you're never going to get it. Unfortunately you are just not there mentally. Dialogue with you is like trying to SAT tutor a kid who skipped grades 7 to 11. He is simply not equipped. Yet somehow he is convinced he is college material. You are a total farce.
Maybe check out some adult re-education courses on www.coursera.org. Since it's a robot taught web course with no human behind it, it will have infinite patience with you, unlike me. Good luck. You're a chemist? Do us all a favor and stay with chemistry.
This article is about car cornering but it does use a two wheel “bicycle” model for discussing the lateral forces on the wheel. It discusses “lateral forces” on the wheel extensively throughout the paper.
Here’s a Slow Twitch article that illustrated exactly what I’ve been saying all along. This graph in particular illustrates my point
Notice the big red arrow marked “ground lateral force”? The article is discussing climbing out of saddle but the same physics applies in a corner.
Here’s a calculator that will tell you have much lateral load a wheel will take.
I look forward to you telling me how stupid I am.
Stuart Black
Stuart Black
#102
Go Ride!
Bikes: Klein Quantum Pro, Klein Attitude, Azuki SS, Merckx AXM, Klein Quantum Race, Klein Quantum
Quoted: 109 Post(s)
Liked 155 Times
….but under the two wheel modeling it clarifies “The model will not consider explicitly the effects of roll movement and camber change”….and (to Yan’s point) it is exactly camber (what we’d call ‘lean angle’) that cancels out lateral force (as the angle of the wheel ‘re-orients’ the forces to be parallel to the rotation of the wheel, or ‘downward’ relative to the wheel. There is no lean in a 4 (or 3) wheel system—in those cases there is absolutely lateral force on a wheel when cornering.
#103
Liked 4,222 Times
hysteresis (indentation), that means the appearance of a force in the contact patch due to the supplementary energy loss in the rubber as it deforms to cover the road irregularities (in the range of 10 μm to 1 mm) when a (driving or braking) torque or a lateral force are applied to the tire or when the wheel is steered (changing its orientation with respect to its displacement direction);
In the tire–road contact surfaces of the front and rear wheels act the tangential forces Xf and Xr, the lateral forces Yf and Yr, and the normal forces to the path Zf and Zr.
In the hypothesis of a non-violent cornering (with the transversal acceleration an smaller as 4 m/s2), it can consider that the tires’ lateral forces are proportional to the corresponding slip angles:
Yf =Cf αf Yr =Cr αr.
Figure 6 shows such an example. The upper plot presents, versus time (s), the steering angles (deg) of the driver wheel (blue) and of the front wheels (green) – in this case, the simulation took into account the compliances of the steering shaft and linkage. The middle plot presents the lateral acceleration (m/s2) versus time (s) – the two plots correspond to the driver’s steering input presented previously (25° max. angle) and to a weaker input (20° max. angle). The lower plot shows the vehicle’s successive positions at equal time intervals (in this example, with the presented driver action on the steering wheel, the avoidance maneuver fails).
In the fictional film world, you can see examples of lateral forces on the tires in numerous…actually countless…movies and TV shows. Any time a car slides a corner, spins, slides off the road, etc. so dramatically (!), that is an example of the loss of friction due to the lateral force on the tires. In the real bicycle world, numerous people have experience this limit of friction due to the lateral force and have the road rash and bruises to prove there is lateral force during cornering.
Stuart Black
Stuart Black
#104
Go Ride!
Quoted: 109 Post(s)
Liked 155 Times
First, we are all in agreement there is lateral force on a wheel in a ‘4 wheel’ configuration where there is no lean angle, or ‘camber’ (in the author’s words). This is what the study is covering. For the few paragraphs of the study that discuss his calculation tool applied to a two wheel application, author specifically says that he is NOT including any factor of camber, so , yes, there will be lateral wheel force in that circumstance as well (although purely in theory because as Yan pointed out much earlier, ANY uncompensated (or matched) lateral force in a two wheel application is not possible…for long…because you fall over. If it helps, think of the bike rider—going into a heavy corner they lean themselves into the turn so that the force of gravity matches the lateral centrifugal (lateral) force….so all the rider feels is a downward pressure parallel to the bikes lean angle….if the rider had ANY unbalanced (unmatched) LATERAL force they would fall in that direction (left or right). If that makes some experiential sense to you (not saying it will) then think that the same is true of the bike…and the wheels as well. Leaning the bike over lets gravity’s downward pull effect a lateral counteracting (“matching”) force to the lateral centrifugal force of a vehicle in a turn. Its why bikes and motorcycles must lean into turns where cars (and tricycles) do not.
#105
Quoted: 514 Post(s)
Liked 451 Times
#106
Liked 4,222 Times
The lean is the lateral force. There is also a bit of twisting of the rim upwards because of how the rim/spoke interface works which is a small amount of vectoring of the lateral force into vertical force but, overall, the force of the turn is a lateral force. Take that lateral force away and the bike goes back to a straight line or, alternatively, don’t apply a lateral force and the bike stays on a straight line. Basic first law of motion stuff: “A body remains at rest, or in motion at a constant speed in a straight line, unless acted upon by a force.”
Stuart Black
Stuart Black
Likes For cyccommute:
#107
Quoted: 514 Post(s)
Liked 451 Times
I should have specified, vertical relative to the axis of the wheel. Which is partially lateral relative to the ground.
Likes For oldbobcat:
#108
Liked 4,222 Times
By the way, I find these kinds of discussions (mostly) useful. Although some think I’m dumb as a hammer and totally uneducable, I do learn things from these discussion. If nothing else, it makes me do some research. It’s kind of fun to blow out some of the cobwebs.
Stuart Black
Stuart Black
#109
Liked 4,222 Times
That is what I mean by the rim bending upward during a corner as the center of gravity leverages the contact point. The graph I included from slow twitch illustrates what I’m saying, although they are talking about side-to-side movement of the rim during out of saddle effort. There wouldn’t be an oscillation of the rim like in that example but there is nothing to preclude the rim from responding in the same way while cornering.
Stuart Black
Stuart Black
#110
Go Ride!
Quoted: 109 Post(s)
Liked 155 Times
Exactly. “Vertical” parallel to the lean angle of the bike. And exactly— there is some remaining lateral force (centrifugal I’m referring to as it “pushes” the bike “outward”) which is what the friction of the tire on the road then counteracts—much less than a car tire which has no compensating lean/camber.
Likes For Sonofamechanic:
#111
Go Ride!
Quoted: 109 Post(s)
Liked 155 Times
To be clear, the exact same lateral centrifugal force is in play, undiminished, but by angling the bike that becomes more vertical (relative to the bike and, importantly, to the wheel structure.) Its a similar concept to building banking into the curve of a road or even a plane “banking” into a turn. In fact a plane is a great example—the structure of a plane does not have to be engineered to handle significant lateral force nor is it even constructed with sufficient vertical structure to get enough “traction” in the air to make a corner…because it can instead angle into a turn and utilize its structure and surface area to in effect take that corner “vertically” relative to the plane. In an extreme corner you’ll put a small plane almost fully ”over” to 90 degrees and take the full lateral force of a turn as a vertical force. Bicycle wheels are structured similarly in that they rely in a lean to re-orient the bulk of the lateral force of a turn into a ‘vertical’.
#112
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
Likes For Kapusta:
#113
Over the hill
Quoted: 998 Post(s)
Liked 1,206 Times
So Ev0lutionz , are you satisfied with an answer yet?
It's like riding a bicycle
Likes For urbanknight:
