When we fall, is it 50-50 to the left or right?
I think tyrion got it right a few posts back. Assuming the chances of falling on either side are equal, I would definitely consider the fact that most "hits" by automobiles would be on the left side (in right-side-driving countries). But if you DO get hit this way, chances are anything in your right pannier is going to get damaged anyway, so there's not much that packing your camera in either side is going to do to protect it.
One other thing I would consider is, if you use a kickstand that protrudes to one side (usually the left), the chances of your bike falling to that side from a parked position are greater than the chances of it falling to the right.
Quoted: 603 Post(s)
Liked 285 Times
Unfortunately I seem to be adding data on an all too frequent basis. The last good one was when I was racing in a time trial 2 years ago, I took a turn too hot and there was loose gravel where it shouldn't have been, destroyed my bike, cracked my helmet (thank goodness it wasn't my head) and shredded clothing and skin AND of course it was my left side.
Macro Geek
My guess is that the likelihood of falling on one side or the other is more luck than anything else. I don't fall often, but when I have taken a tumble, the circumstances were unique: Wiped out on a gravel path: right. Wiped out of a rain-slick road: left. Couldn't unclip in time: left. Front brake failure while cycling downhill: over the handlebars. Sideswiped by a pickup truck driver who turned sharply into the bike lane: managed not to fall. Sideswiped by a passing motorist who didn't bother to stop: kept my balance.
just another gosling
Quoted: 3907 Post(s)
Liked 1,956 Times
Falls I've experienced and seen have been all to the left. Couldn't say why.
Results matter
Results matter
Macro Geek
Murphy’s Law says the side you fall on will be the side you put your camera in.
Bikes: 2016 Novara Mazama
Quoted: 3640 Post(s)
Liked 81 Times
All of my "falls" (assuming that means no speed topple overs) are to the right. Why? That's the foot I normally put down and lean towards, and if I am falling, it means something went wrong with my foot and the bike is already going that way naturally. I tend to pack clothes and soft stuff in the right pannier as such.
Crashes? Crapshoot, depends on what is going on when I crash.
Quoted: 5233 Post(s)
Liked 3,601 Times
Bikes: Nashbar Road
Quoted: 2934 Post(s)
Liked 341 Times
I was thinking only of moving falls. Stationary falls, that makes sense that it would be to the side you put the foot down.
Another reason for left-side falls occurred to me. When you fall into a rut, that rut is reasonably on the right side of our riding path. Gutter area, or off the edge of a paved path. If you try to bounce back out - towards your left - you will fall to the left when that doesn't work.
aka Timi
Practice, practice, practice!
If in doubt, don't fall into the lane, go for the ditch!
I always try to laugh after a fall ... at myself ... which 99% of the time is the cause of the fall.
I walked in to my bike shop recently and before I got 10 feet the owner was scolding me for my right forearm and knee being all scabbed up, telling me to try falling on the cheap (left) side next time. The right side has all the expensive stuff on it.
