For the love of English 3 speeds...
www.theheadbadge.com
Quoted: 2425 Post(s)
Liked 4,407 Times
Thanks Mike and Neal - I suspect, based on some more reading I've done on the S5.1, is that "super low" or first gear was a persistent problem with the original double shifter and also with the trigger shifter. SA had issues with this hub in its various editions.
I'm wondering if I should try one of those modern Sturmey thumb/bar end shifters - it would likely be a lot stronger/hold the cable in tight suspension versus the weak trigger shifter 'indexing'
Maybe I'll try and find one. I'd rather not open up the hub at this point since the bike is my winter commuter, and low (2nd gear) is more than enough for the small hills I encounter on my ride.
Pic is old - hadn't hooked it up here. Yet.
-Kurt
Likes For cudak888:
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
Local flipper (whom I call "white truck guy") has this neat one for $300.
https://www.facebook.com/marketplace...16880587133158
Bikes: 1951 Sun Wasp, 1953 Armstrong Consort, 1975 Raleigh Competition, 1980 Apollo Gran Sport, 1988 Schwinn Voyageur, Mystery MTB
Quoted: 360 Post(s)
Liked 473 Times
Hey all, Happy New Year. Somebody had a 26 x 1 3/8 wheel for sale here with a 'frozen hub' and I picked it up thinking I might find a good parts source.
Here's what I got:
PXL_20230104_195409565
A '53 dated AW laced to a Raleigh rim with the raised matte centre, and 'R' branded stainless spokes (or at least, I think they are). The hub was indeed frozen, with the driver only moving back and forth a little when inserted into the clutch. I thought, oh boy, this thing must be rust city inside if the staining of the bearing spaces is any indication. I applied PB Blaster liberally and it started to wakeup, and now I can hear one or two pawls ticking. I'm hoping to remove the assembly from the shell and take it down to the sun gear for a cleaning and inspection of the mechs, fresh bearings, and rebuild. I was thinking of sending my 1980 S5.1 to Rat City bikes in Seattle for a rebuild because its slipping in super low (they specialize in IGH services, and they make their own shift cables to avoid the pinch bolt!), but if I can do the full job on this AW, I should be able to manage on the S5.1, though I may need parts. Once back up to snuff, I'm planning on running this AW wheel on the Triumph while I do the same job for the S5.
PXL_20230104_195357949
PXL_20230104_195416740
Here's what I got:
Otherwise its an interesting ride.
With that frame style, and what looks to be steel rims, I wonder if it has either 28 x 1 1/2" rather than 700C wheels? I don't recall seeing many steel 700c rims over the years.
I've run into a few Dutch built bikes that were similar, one a burgundy colored, Union badged bike that looked similar but sans the rubber fender end and modern saddle.
The bike I had here was too far gone to fix but I saved the fenders, rear rack, CG, bars, and other small parts but its wheels and hubs were trashed, both had loose right side spoke flanges, and both rims, (28"), were rusted through. The rims however were an odd rounded profile with spoke dimples with Semperit 28x1 1/2" Super Elite branded tires.
I happened on that bike over 20 years ago in a huge lot that I bought up in NY. I've yet to find another just like it, but that same lot of bikes and parts also included several of the same headbadges and several more of the same style drum brake hub with similarly damaged flanges.
Liked 4,407 Times
The toe overlap clearance does look minimal though, so I wouldn't put it past it for having crinkles behind the headlugs and below the fork crown. Given that this will be a hi-ten frame though, it'll probably pull out with cold setting and show no evidence once straightened, provided it is done properly.
-Kurt
Liked 2,446 Times
Quoted: 360 Post(s)
Liked 473 Times
I soaked a rusted, partially seized 1953 AW from the Pacific Northwest (seller was located in BC's lower mainland) in PB Blaster for a day or so and tried the hammer and punch to crack it open. It took some whacks, but the penetrant did its work and it started to loosen up and I removed the assembly for inspection. I think all of the internal rust is the result of operating through the decades in a very damp environment, and the lower mainland of British Columbia definitely qualifies as damp, humid in winter, rainy - without regular service internals and drops of oil, I think rust up inside an IGH is inevitable. A little work and it spilled its guts! Looks to have never been serviced, with the bits and bobs of original grease hardened into chalky gunk.
As is often reported elsewhere for this era of Sturmey Archer hub gear, there are no indications of wear on any of the internal parts after a good scrubbing. I expected some worn parts, as the hub (given the state of the wheel), must have thousands (maybe tens of thousands?) of kilometers under its belt after 70 years. I know what you're thinking - did he drop a pawl spring? - yes, I did, but I found it!
I'm going to clean up the wheel as best I can, install the bearings and fresh marine grease, apply some synthetic oil on a few moving parts as per instructions, and put it back together. Its going into service on my '64 Triumph while the S5 is out of commission for its own inspection and rebuild.
PXL_20230106_000729017
Quoted: 360 Post(s)
Liked 473 Times
I thought you folks might find this interesting - a '50s Raleigh for sale locally. If it had been the men's model, I'd already be meeting the seller...look at that blue! I've only ever seen this colour in period advertisements as posted by a few keepers of the flame in this forum. Nice bike - complete with the B66L, the Superbe lamps, AG hub...
Likes For Ged117:
Ged117, For what it's worth, Sturmey Archer asks that you replace the 4 pawl springs at every service. In the couple that I have worked on there was a difference in the spring tension, before and after. The best deal I found for springs was a 10 pack from SJS cycles in the UK. Takes a couple of weeks for shipping though.
Likes For Macguyver909:
On the road
Bikes: Old Schwinns and old Raleighs
Quoted: 373 Post(s)
Liked 880 Times
A tired pawl spring is certainly one place to look if you have a slipping hub and simpler repairs like cleaning or the various external adjustments to the hub and shifter will not solve it. And all the more so if the hub hasn't been serviced in 50+ years. But I will admit I think replacing all 4 springs at every service if the hub is working is a bit much. I can see it as a preventative measure if the hub is ridden every day as a commuter in all conditions, or ridden a lot and on very long rides, but it seems like a lot of replacing springs to me for a vintage bike that is more sparingly ridden. My two cents at least when working on these hubs.
Classic American and British Roadsters, Utility Bikes, and Sporting Bikes (1935-1979):
https://bikeshedva.blogspot.com/
Quoted: 360 Post(s)
Liked 473 Times
Edit: I just realized that two pawl springs are missing - the ones for the planetary gearset assembly, and that the clutch spring and cap are missing too. I think this hub was used as a parts source to keep another hub going.
Likes For Ged117:
Liked 2,446 Times
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,057 Times
Likes For clubman:
Phyllo-buster
Liked 2,057 Times
I'd think it's CF9...Royal Blue, fitting for the Aristocrat of bikes
Likes For clubman:
Failure wise, I've seen more chewed up pinion gears or worn planet gear pins then broken springs over the years.
Likes For oldspokes:
Quoted: 360 Post(s)
Liked 473 Times
Quoted: 360 Post(s)
Liked 473 Times
This Robin Hood is posted locally, looks to be have been in a crash. I asked the seller about it, but they're ignoring me, trying to cash in on a 'vintage bike' that has been sitting and needs pretty much everything serviced to be ridden.
Quoted: 478 Post(s)
Liked 634 Times
My 1949 (or 50?) Humber was also that blue.....very fragile paint as it appeared to have been applied over top of the normal glass black. I repainted it in as close to the same colour as I could.
Quoted: 478 Post(s)
Liked 634 Times
$250 for a clearly crashed bike is a bit of a stretch, given the servicing it will need. The serial number (32635RC) and the brazed on pulley mount sort of point to later 50s; too bad the seller didn't show the hub. Chainring is interesting and I wonder if the dynohub works?
Liked 4,407 Times
There is, of course, the approach of showing up with cash and then mentioning the damage. But if they're trying to ask top dollar and are also ignoring the fact that someone's pointing out it has damage, well, those people can't be reasoned with.
-Kurt
Quoted: 360 Post(s)
Liked 473 Times
I assume it's not priced well, right?
-Kurt
-Kurt
Quoted: 887 Post(s)
Liked 335 Times
Raleigh Choppers
Found this article at "The Guardian".
https://www.theguardian.com/lifeands...-chopper-rides
Found these in a box from a recent clean out:
They were covered in cosmoline and wrapped in brown paper in a wooden box marked Made in England.
They are 'lightly chromed' at best, with limited coverage around the crown area. They appear to have been meant to be partially painted.
The fork blades are 14" long, the steer tube is 8" (203mm) long, they appear to be universal replacement forks as they are threaded long enough to be cut down to fit either a 21 or 23" frame size.
The dropouts are stamped, with a single fender attachment point.
I was told the place closed in 1970 and had signage for Raleigh, Royal Enfield, Rollfast, Mossberg, and Philips.
Old fart
Quoted: 3599 Post(s)
Liked 3,424 Times
Likes For JohnDThompson:
Just checked them, they have 24tpi threads.
A few of them are stamped Royal Enfield, a few are plain with only a few un-legible numbers written on the steer tube.
All were dipped in heavy brown cosmoline which I washed off with mineral spirits on a rag.
They appear to have been dipped in it as the fork tubes and steer tube appear to also be full of the stuff.
I have one soaking in a parts wash tank to completely remove the stuff.
The box they were in was in rough shape. At first sight I sort of just figured it was an old military box from something.
It appears that it was being used as a step to reach the top shelf for years. It was still nailed shut and almost got left behind.
It was made completely of 1/2" thick wood planks nailed together, no plywood, no sealing or special joinery.
Each fork was coated in cosmoline and wrapped separately, every three were wrapped again were wrapped together.
The paper, inside of the box and forks were saturated with the hard waxy grease and the box seams were stained with it from where it
had seeped through over the years.
Likes For barnfind:
