I bought a bike for commuting. What upgrades should I make?
A summary of this thread is as follows.
The OP should get:
underseat bag
spare tube
patch kit
two tire levers
size 4 & 5 Allen wrenches
one of those Park Tool bicycle multitools
lights (front and rear)
a bell to warn pedestrians
reflective clothing
well-fitting helmet
a very secure lock.
a used bike maintenance book
10mm wrench
screwdriver
chain break tool
small saddle bag
frame pump
lock suitable for where you are parking
rear flasher
solid white front light
puncture-resistant tires such as the Scwalbe Marathon Plus
CST Salvo tires
leatherman
good fenders
any schwalbe/continental tire that is smooth and says PLUS on it
selle italia slr
handlebars
a 5cm shorter stem
a lot of steerer spacers
a nitto dirt drop
vision time trial base bar in aluminum
nitto north road
a bottle of Chain L chain lubricant
floor pump
good lights
dyno hub and lights
rear view mirror
mudguard/splashguard
bigger (40mm+) tire
CO2 pump
a $12 steel rack from Amazon
rear rack & matching clip-on trunk
strobes
cpl tools
all new clothes
-Tim-
The OP should get:
underseat bag
spare tube
patch kit
two tire levers
reflective clothing
well-fitting helmet
a very secure lock.
10mm wrench
screwdriver
chain break tool
small saddle bag
frame pump
rear flasher
CST Salvo tires
leatherman
good fenders
selle italia slr
handlebars
a 5cm shorter stem
a nitto dirt drop
nitto north road
floor pump
good lights
dyno hub and lights
rear view mirror
bigger (40mm+) tire
CO2 pump
strobes
cpl tools
all new clothes
-Tim-
I just wanted to give the OP as heads up. for some it down matter for some it does.
I had two flats within a month of installing my Continental GP 4000S II 28mm last year. I then added Mr. Tuffy liner and was flatless the other 6 months with these tires. I'm about to reinstall them this year (I use Marathon Plus 35mm during Fall and Spring season), hopefully I haven't jinked it...
https://www.schwalbe.com/en/tour-rea...n-supreme.html
best road tire ever produced.
get marathon supremes
Quoted: 20 Post(s)
You’ll figure it out on the road. Odds are the only upgrade you’ll need is fitness and your road awareness (keeping yourself safe from cars). Don’t believe the noise. Bikes have been good enough since there have been bikes, it’s the riders that need work.
Quoted: 7391 Post(s)
Liked 2,548 Times
Liked 2,548 Times
If you want dynamo powered lights, there are a few wheels or hubs you can get, and they make life so much nicer, as you never have to charge your lights. You just roll. Busch & Müller make the best dynamo powered headlights. They bolt onto your bike, so you don't have to take them when you lock your bike.
Quoted: 212 Post(s)
Liked 83 Times
Commute essentials (for me):
- Tires that aren't likely to flat on my commute -- I go with 28mm, having moved up from 23s and 25s in the past.
- A rack and a pannier -- I carry a laptop, and don't want to put anything on my back.
- A bottle cage -- Water is nice.
- A beefy lock.
- A minimal toolkit: tire levers, wrenches, tube patches, spare tube, and either a pump or co2.
- Lights front and rear if there's any chance you'll get stuck at the office late. (A really bright one in front)
Everyone has a favorite tire for commuting, just like everyone has a favorite lube for the chain. As tires wear out you get the chance to replace them with tires of your choice and will experience what tire you like best and works best for your riding needs. There is no single tire that is better than the rest as everyone's riding environment is different. I have commuted El Cheapo tires that never got flats, but wore out very quickly. Continental Ultra Sports are good cheapo tires that seem to wear well for me. I weigh in at t 230 pounds, and the rear tire gets rotated to the front at 1000 miles. About 2500 miles to a set is what I get.
FYI: Tires do not need to be replaced as a set nor do they need to match. Anyone who tells you it is best to ride a matched set is selling a lie.
Schwalabe Marathons are well respected in the touring market, and it is hard to go wrong with them. My current long distance commuter/touring rig has Continental City Ride tires on it. Been on them for 4 years without a single flat. Not bad in my book. They still have a ton of tread left, too. Not as fast as the Ultra Sport, but they are wearing much better and are likely to see 4-5 thousand miles before replacement. A touch slippery in the rain, but who is hammering corners in the rain on a commuter bike anyway?
Quoted: 212 Post(s)
Liked 83 Times
You will get as many opinions on that question as there are answers.
What I have:
Front: Light & Motion Urban 900
Rear: Cyglolite HotShot 150.
Both are USB rechargeable. Both are the brightest I've ever had mounted on my bikes. They both last long enough to outlast my night rides with plenty of breathing room. They're light and mount easily.
But there are a lot of good models out there. Just consider: ease of mounting, battery life, brightness, weatherproofing, size/weight, ease of recharge, lower-output settings for longer battery life where absolute brightness isn't needed.
Don't waste your money with cheap lights if you commute.
To add to what feature @daoswald said, get a light that won't blind incoming traffic. My CatEye 800 has a mode called 'HyperConstant' where the light is constantly on but also blink at an higher intensity. Attracts attention and allows you to see at the same time Depending on how long your ride is, you might also want a light where the batteries can be swapped.
Bikes: Nashbar Road
Quoted: 2934 Post(s)
Liked 341 Times
I use something like these https://www.amazon.com/gp/product/B006QQX3C4 ($18-$25 generic light) for commuting headlight. A couple are over 4 years ago, two are two years, one of the four has burned out. Bright and reliable for commuting purposes.
