Best way to remove chain grease from white socks?
Pennylane Splitter
Bikes: Yes
Quoted: 1807 Post(s)
Liked 1,446 Times
I wear white socks and can honestly say I've never had a problem with grease or oil getting on them. I use 80/90W manual transmission oil as a chain lube, and I wipe off any extra after putting fresh oil on the chain. Maybe the oil's thickness prevents it from flying off ?
FWIW: I ride a lot in the early morning darkness, so white socks and shoes help me keep visible. Shoes are tennis court shoes used with MTB 'pinned'-style pedals, which are somewhat stiff compared to other non-cycling-specific shoes. The shoes do pick up road grime, but that's easy to wipe off with a rag.
rebmeM roineS
Quoted: 653 Post(s)
Liked 347 Times
My socks seldom get dirty from cycling. Or, maybe I just don’t look at them very closely. Plus, I don’t wear white socks when I ride.
52psi
Quoted: 790 Post(s)
Liked 802 Times
Leave it and ride on. This is cycling, not a formal dinner.
Bikes: 1969 Peugeot PX10, 1992 Della Santa, Linus Roadster 8, Biria 700C ST-8
Quoted: 794 Post(s)
Liked 508 Times
You’ve discovered why bike shorts are traditionally black. Change your flat tire, wipe your dirty hands on your shorts. Weeks later think about it and wash your shorts. Enjoy.
Quoted: 590 Post(s)
Liked 445 Times
Look at what the bike mechanics wear in the pro tours (and probably at your LBS), typically black from head to toe. Guess why.
Quoted: 3352 Post(s)
Liked 1,056 Times
Strangely enough if you rub in the stain a good high detergent synthetic motor oil like Mobil 1, and then a good detergent soap the stain will come out. The motor oil will remove oil based paint stains to if they are not too dry.
Liked 1,056 Times
BTW I wear short cotton socks like Gold Toe year around. I would have to try real hard to get grease on them.
