Please critique my setup
Go for a full size frame bag, lots of room, keep the heavy stuff low. As said, get a handlebar bag. Revelate, rogue panda or such. Check out the radavist for ideas.
Quoted: 3462 Post(s)
Liked 1,468 Times
If you consider getting a frame bag, if it is a bit small you can still use it.
I saw one on Ebay or Amazon that was REALLY cheap. I knew it was too small to fit in the frame, but rolled the dice and ordered it. Found it fit perfectly if I kept one bottle in the triangle, I had to add the strap for the headtube myself.
Quoted: 2236 Post(s)
Liked 1,314 Times
Re. the B17.
For bike packing I don't think it would be as beneficial as say, a long distance road trip. Generally I don't notice a big need until 50km's or so, often sitting in one position. Then the Brooks seems to feel better longer. My longest day (273 Km's) was on an more upright converted mtb tourer using a B67. But it is all subjective. The C17, supposedly a rubber equivalent to the B17, gives me friction burns if I stay in it all day.
Bikepacking usually doesn't put in as big mileage and you are up out of the seat more so you can use more options for seating, as long as the fit is there. To me, the only benefit of a leather type saddle like the Brooks line is comfort over long distances. Lots of other saddles feel ok over moderate ranges and are more durable an light weight. On my fatbike I run either the B67 or a Fabric Scoop saddle during the rainy season so I don't ruin the leather.
Liked 1,314 Times
And frame bags...
I bought a Blackburn Outpost frame bag (medium), not really knowing at the time how versatile I would find it. I would say it's mid range cost-wise and a bit over built but I like the adaptability. It turned out to be too small for full frame coverage but I learned to appreciate that defect/benefit and would now buy the same size if I had too for the range of bikes it fits and water carrying capacity it offers.
It has a zipper so you can make it full frame or more narrow to run along the top tube. Here it is narrow on my endurance bike (60cm) so I can still have two water bottles.
Here it is extended but doesn't fill the whole frame, allowing me to add a 1.5L naglene bottle in a cargo cage as well.
And it also fits my fatbike, that has a smaller frame. I think I could put a standard side entry water bottle cage on the seat tube and fit a tool keg in there to fill that small space if I wanted. with this water bottle configuration, adding another cargo cage to the down tube, I can haul 3L of water on the frame.
Liked 1,468 Times
I have tried two different C17s, a plain one and an all weather one. Initially I liked them but at about 15 miles I decided they were equivalent to a medieval torture device. But, I have met several rando riders that use them on brevets and are very happy with them, so they clearly work for some people but not for others.
Quoted: 86 Post(s)
Liked 51 Times
The B17 came stock on my Salsa Vaya Travel. I gave it 6000 miles and 6 years but it never broke in at all, not even the little dents/dimples you should get under the sitz bones. It wasn't a medieval torture device for me - but it wasn't good either. I got sort of used to sitting with all the anatomy on one side or the other, and the start of a tour would be a process of just riding uncomfortably until those spots got chapped and toughened up.
I'm a tall rider, 6'2", some XL bikes are even cramped for me. My tour bike has like 4" of drop from the saddle to the bars, and that's at max stem height on the fork. It's been discussed a little here and lot elsewhere, but pretty much everyone agrees that Brooks doesn't work for anyone with that much drop, even on the top and hoods. Certainly didn't for me.
Specialized Power saddles in 155mm work really great for me right out of the box (it was a long process to learn that though).
Quoted: 1188 Post(s)
Liked 1,154 Times
Coasting fast enough to need 110 inches on gravel would be fairly rare, on a regular touring bike I'd agree coasting sucks nearly as much as pushing, but on a gravel bike, if you had to choose between low end or high end, I'd pick low end. When I tour on gravel I've only used my Rohloff with a single speed front 14" to 73" and that seems enough. On the road I use an ATS speed drive, 14" to 122". Can pedal down nearly anything.
Liked 1,314 Times
I think my next saddle will be a Brooks C15 carved. A little narrower and I think the lack of a carved slot made my C17 too stiff... maybe.
Liked 1,154 Times
26" wheels help. I run 36/19 so that's bang on 1.9:1. Only issue I have is Rohloff sprockets seem to be made of cheese, after 3000km or so of heavy riding the teeth get a real hook to them. Yep, you can reverse them, but I'd like longer than that in the first instance, so I'm trying a KMC 1/8" sprocket with a Wippermann E Bike chain. Heavy AF but more like a motorbike than a bicycle.
Mad bike riding scientist
Quoted: 6220 Post(s)
Liked 4,221 Times
The pavement on the right (not the dirt) is a 45mph downhill.
And just to be clear, I use knobs.
Sometimes I’m not too bright
Stuart Black
Stuart Black
Likes For cyccommute:
Liked 1,154 Times
If you can ride down that track at 25mph on a loaded bike, good on you... me, I wouldn't because who knows what's around the next corner...
You will note I said, "if you had to choose" I'll pretty well always chose the widest gear range I can, but the ATS doesn't particularly like deep water or dust, so it doesn't get a gurnsey off road.
Liked 1,468 Times
But touring, I rode a different bike up a fairly steep hill and watched my speed to see what I thought that the slowest I could go without having to do radical steering to stay upright, found the slowest speed was 3.5 mph. And I felt that the slowest cadence that was smooth instead of jerky was 72. I based my lowest gear on that for touring, that came out to be a ratio of 36/16 to give me a low gear with a 72 cadence at 3.5 mph. Thus I have to add or subtract four links when I change chainrings, use a second quick link.
With 57mm wide 26 inch tires, that calculates to a range of 16.2 to 85.1 gear inches for touring. I do wish I had higher gearing for shallow downhills, but I don't want to give up the lower gears that I sometimes need for the steeper uphills.
Before I flipped my sprocket a few months ago, took a photo.
I cut a notch in one tooth, I always put a link with outer plates on that one tooth. More on that here:
https://www.sheldonbrown.com/chain-life.html
Based on that article, you get more wear on the teeth with inner plate links and that is what I saw on my sprocket, those teeth had a more pronounced hook. I use 16T sprockets.
When you have more experience with that KMC sprocket and e-bike chain, please write up a post with your experience.
Bikes: Lemond '01 Maillot Jaune, Lemond '02 Victoire, Lemond '03 Poprad, Lemond '03 Wayzata DB conv(Poprad), '79 AcerMex Windsor Carrera Professional(pur new), '88 GT Tequesta(pur new), '01 Bianchi Grizzly, 1993 Trek 970 DB conv, Trek 8900 DB conv
Quoted: 759 Post(s)
Liked 810 Times
That's the truth. It's good though, to know what saddle suits what style and how they should be adjusted so the decision isn't based on wrong application.
I also have both a B17 std and B17-Imperial (carved)..while the carved version is more comfortable, the standard version is comfortable too.
Likes For fishboat:
Liked 4,221 Times
Stuart Black
Stuart Black
Quoted: 1034 Post(s)
Liked 1,292 Times
I can run my saddle the same height as the bars, or even lower as long as the height is right. I do, however have the bars slightly higher now though.
