Di2 Battery Dies!
#51
Quoted: 4253 Post(s)
Liked 2,968 Times
Someone just needs to come up with a way of impregnating a cf frame with solar panels to trickle charge the battery and you'll no longer have that problem. Hey, I should put that in the next big thing in cycling thread, or just see if I can get a patent. Pcad, you draw me up some good pictures, and I'll cut you in.
Bikes: 1996 Eddy Merckx Titanium EX, 1989/90 Colnago Super(issimo?) Piu(?),1990 Concorde Aquila(hit by car while riding), others in build queue "when I get the time"
#52
Chases Dogs for Sport
So I know this isn't a terribly serious thread, but....
It is good to get a real world number of how long Di2 can go before it shuts off the FD. Recharging is obviously a non-issue, unless you plan to travel 3,000 miles without getting near an outlet.
By the way, how much maintenance or minor tweaks did the drive train require during this period of time?
#53
Lotus Monomaniac
Quoted: 5 Post(s)
Oh my, yes I do. It's so much work to reach down and flip that lever to remove a wheel. I can't wait till Shimano adds remote-control electronic solenoid-activated wheel release mechanisms to the Di2 group. Just press a button on the remote control and a battery inside the hub sends an electric signal to the axle mounted solenoid releasing the tension on the axle. Awesome!
Hopefully Shimano will promote the hell out of it and give it to the pro teams to use. The more expensive it is the better it will be and when I buy it I'll get a huge rush of adrenalin knowing I now have the latest and greatest component on my bike!
#54
Bikes: LOOK 595 & Cannondale CAAD9
My view is that electronic shifting is expensive solution to a problem that never existed, for people with money to spend on what they are told is the latest and greatest. Today it's all about making even the simplest task require even less skill from the operator. I enjoy using the skill it takes to operate friction shifters. But then again, I'd rather use a hand plane than a belt sander to fit a cabinet door and I don't plug in my knife to carve the Thanksgiving turkey.
But hey, if that makes you happy, more power to you.
Next from Shimano, Wii virtual cycling, you don't even have to pedal.
You don't know how many nights I lie awake, reminding myself to check the cables on my shifters before I go out for a ride. If I forget, they might fail, then I'd be stuck with a double-tap occasional front derailleur fail and harsh cross chaining on the back
Di2 may be reliable and low maintenance, but I guarantee you I would (and I am not alone, as the existence of this thread proves) forget to charge it, or forget do something over and above what cable maintenance requires and relive Nacho's experience here. It happens with anything requiring a portable charge: You neglect to charge it or know how much juice you have left, then your reliable and low maintenance system becomes as useful as one side of velcro.
Cables may fail, but in my 30 years of riding I've never experienced it.
AVEO
AVEO
It's all excuses and resistance of change. Human nature really. Fact: cables require more maintenance and have a higher chance of failure than Di2.
Nachoman was still able to shift in the rear and get home. Is that really the end of the world?
#55
The Weird Beard
No, but is sure is a pain in the ass, mainly because it wasn't mechanical failure, it was human error. Just sayin' that your 'fact' about cable failure is flawed. It is not splitting the atom, and I can change a cable faster than you can charge your battery.
#56
I disagree. Unwrapping bar tape, changing the cable out and probably trimming new housing, taping the housing to the proper place on the bars, then re-wrapping the bars is MUCH more work than plugging in a battery. It probably takes a good hour for most people to do a proper job. I don't know about you, but I'd rather charge a battery.
#58
The Weird Beard
If you want to carry a spare battery instead of a spare cable, well, that's up to you as far as weight and cost. If you forget to charge it, it won't do you any good, which is the point of this thread.
#59
I don't have to unwrap my tape to thread my cable - that's nuts. It sounds like you are trying to find exceptions to an obviously superior maintenance process? Why do you unwrap your bars? The cable threads perfectly through the already installed housing.
For crying out loud, it's 1 charge every 1700 miles! It's virtually maintenance free.
#60
well hello there
Quoted: 503 Post(s)
Liked 337 Times
And don't forget 1700 miles was with over 85,000 feet of climbing. I bet you could double that amount of mileage if you lived in the flats and shifted less.
#61
AVEO
AVEO
#62
TFO
I'm still on the original charge but my tentative schedule is to charge when I turn over the thousands digit on my computer odometer. This gives me lots of safety margin. If I were going to do a long trip away from home like Ragbrai, I'd just charge before going
#63
Peloton Shelter Dog
Could you be a bigger Sram Shill? Is that even possible?
https://www.cotsiscad.com
#64
Lotus Monomaniac
Quoted: 5 Post(s)
There just seems to be something to me that feels fundamentally odd when I think about using a battery and a micro-processor to shift my bicycle . . . . my bike! . . . I don't know why I feel that way, I can appreciate the technology, but it just feels odd inside for some reason.
#67
Just to provoke some thought over the comment you just made, where do you draw the line with what "feels" right or wrong on a bike? Did brifters ruin cycling for you? Would you rather reach to your down tube and take your hands off the handlebars every time you want to shift a gear? What about carbon fiber? Oversized handlebars? etc etc
It's called progression people. None of it takes away from the fact that to propel the bicycle, you have to use your legs and give it some effort. Di2, power meters, aero frames and wheels... none of it takes away from the pleasure of using your legs to propel the bicycle. Get over it and admit it's the price that's holding you back from getting it. The least you could do is be honest with yourselves. That's why I don't have it. I refuse to pay $3k for DA Di2, but you better believe if it was half the price I'd have it. That's why I'm excited for Ultegra Di2. And don't even start with the weight nonsense. You weight weenies can drop the extra pound off your gut before you complain about the extra weight of Ultegra Di2. Not to mention bikes are so light these days it shouldn't be a problem to have a sub-15 lb. bike with Ultegra Di2.
#68
Super Modest
Quoted: 10996 Post(s)
Liked 4,678 Times
I'm not going to shell out the cash for Di2, but I still think it's an ingenious idea and would be happy to use it. I remember when we went from friction to indexing and some of us claimed it would never catch on.
Anyway, good info here on the system. Thanks to the first adopters for the real life info.
Full disclaimer: I ride Campy.
Keep the chain tight!
#69
Peloton Shelter Dog
I wonder if it feels strange for this guy using that magic box to communicate. It's just not the same as smoke signals.
#70
Bikes: 2008 Trek Madone 5.5, 2009 Cervelo R3SL tdf edition, Cervelo R5 with Di2
I've charged my Di2 battery 4 (maybe 5?) times in a bit over 3000 miles. Only once was the battery indicator even down into the Red. I've never gotten to the point where either of the shifters stopped working.
I get that this is a fun thing to mock, but in case anybody is serious wondering whether this is a real issue or not... it's not.
#71
Peloton Shelter Dog
#72
Bikes: Colnago C59 Italia Di2
Ive had Di2 for thousands of miles, my thoughts are:
1) It shifts faster than any cable system
2) It shifts better than any cable system - no your cables dont shift peferctly anyway, you just think they do until you try something better
3) It doesn't require less maintenance than cables - it requires none at all.
4) Charging isnt maintenance, you unclip the battery, plug it in, come back an hour later and clip it on again. It takes seconds not minutes, that doesnt even count as maintenance.
5) It requires no adjustment - EVER
6) It shifts much quicker between the smallest sprockets than cable systems that have little spring tension at that end of the movement
7) Front ato trim is cool - even if i never use trim on my cable bike, its a nice touch
8) Your battery will never run low without you realising if you place the control unit in a visible position while riding
9) It is the easist system in the world to adjust while travelling at 30mph - I only did this when it was new, i have never needed to since.
10) With internal cables it makes a ver neat looking bike.
I will never go back to cables no matter what the haters say. Di2 is simply better in every way.
#73
Bikes: Cannondale EVO, CAAD9, Giant cross bike.
Quoted: 67 Post(s)
Liked 7 Times
Could you be a bigger Di2 shill. Is that even possible?
The difference between us is I actually understand and know what I am talking about. You like bright shiny things.
I can get it, I can get it for a song, I've ridden it, I rode it a long time before you did. I do not see enough of a difference between what I have and the extra expense and added weight of Di2. Since I've been doing this a while, I'll go with my instincts over a rider who buys the latest and the greatest because it looks cool and people will stare at his bike on group rides.
C'mon...you bought 7900 and I warned you about how bad it sucked, and you still defended it. Latest and greatest...
#74
The Weird Beard
Nerull - We all forget stuff. Please don't tell me you've never forgotten anything.
...and I ride to work in my pajamas. I guess if I got Di2, I would stop forgetting things
#75
Lotus Monomaniac
Quoted: 5 Post(s)
What I see here is you've taken a completely mechanical bicycle and now started adding batteries and micro-electronics to make it work "better".
Would pro football embrace an electronic football with built-in electronic stabilization to make it fly better?
Would a symphony approve of a violinist with electronic auto-tune built into his instrument so he could play better?
How about electronic sights on bows for Olympic competition? Certainly bows have come a long way with technology. Oh, wait, electronic sights and lenses are illegal in competition. I guess Shimano isn't involved or they'd get the rules changed.
Some things just don't seem right unless they remain purely mechanical, in my opinion. Like the football, like the archery sight, like the violin and . . . like the bicycle.
