Di2 Battery Dies!
#101
Administrator
Bikes: Cervelo C5, Guru Photon, Waterford, Specialized CX
Quoted: 1106 Post(s)
Liked 2,196 Times
Better just stick to riding that flying dog house in your avatar. Your efforts at humor isn't cutting it
#103
toasty!
Bikes: 1998 Cannondale r200, 2011 Bianchi Via Nirone 7; 2007 Redline Conquest Pro
So say you just got your bike with di2 and you are out on your second ride and you suddenly can't shift. What do you do? Take it to your lbs. But wait! Your mechanic isn't an it guy! You will have to send that part to Shimano, a company that makes MECHANICAL fishing reels, MECHANICAL rowing parts, and up until now MECHANICAL bike parts. So let's face it, Shimano isn't technologically inclined, and all they want is your money, so no they won't be spending the $1000 it costs them to replace your $3000 groupset. They will have some guy, that specializes in mechanical groupsets and took a one week training seminar on electric groupsets take a look at your broken part. He will replace many pieces until he can say "good enough" after seeing that it works sorta good.
Try harder at your trolling.
If the damned thing doesn't shift right, then like any good mechanic, you start isolating the issue. First, make sure that the derailleur is sound, then check the shifter. Next, you check out the wires, make sure they're seated properly then retest. If that doesn't change anything, then you replace the problem wire - usually the one related to the derailleur or shifter in question - with a 'control wire,' a brand-new wire to make sure that the problem isn't the wire itself, then retest. After that, you move onto the junction box that holds the two derailleur wires and battery wires in place, then retest. There's no need to break open the boxes, you just replace the part. If that doesn't change anything, then start all over again.
The problem right now, and it's common to all relatively new technologies, is that there ain't enough supplies to go around to support a testing process like this in all LBS, nor is Di2 repair common knowledge. However, as it becomes more and more common, more and more bike mechanics will know how to deal with the particular issues it presents. Thing is, it ain't computer science: there's no programming to do, just hardware work.
Also, "don't race it if you can't replace it." Nobody's gonna spend their life savings on a damned bike, that's just stupid talk.
#104
Voice of the Industry
Quoted: 1188 Post(s)
Liked 8 Times
"Shimano isn't technologically inclined."
#105
Administrator
Liked 2,196 Times
getaklug is pretty much right. I am not here to diss Di2, it is great technology. But the average guy...even a EE...or bike shop tech won't have a clue how to fix one if they break is the point. Right now, that means part exchange. If your bike shop doesn't have a big spare parts bin of Di2 parts available, you are pretty much hosed...
The other thing is how many people spend the money on Di2 and doesn't have at least one more bike around to ride?
#106
Peloton Shelter Dog
The Stupid is particularly strong in this thread.
https://www.cotsiscad.com
#107
Bikes: ?
Quoted: 22 Post(s)
I asked my LBS about that specific issue. The guy laughed & said that if they didn't have the required parts they'd order them & have them in a day, two tops. He said that Campy owners often deal with a lot longer delays, at least in my city.
#109
Liked 8 Times
That's no different than any bicycle part going out. Your derailleur goes. Unless the dealer has a replacement, they order one which comes in a couple days. But everyone I've seen that sells Di2 has parts in stock.
Apparently you don't get it at all. When a std derailleur fails, it is generally obvious. When a Di2 rear derailleur doesn't shift, you don't know if its the:
a. controller
b. battery (easy to discern)
c. broken wire aka breach in the system
d. servo that shifts the rear derailleur.
The level of complexity of the new Di2 will elude most that attempt to work on it short of replacing parts that are as rare as hen's teeth. This btw will be a windfall for not only Shimano but also for lbs that will end up replacing parts at owner expense that aren't even required.
There is a thread on the web someplace about a frustrated Di2 owner whose bike was down for weeks with little support from Shimano and an equally clueless/helpless bike shop.
Does Di2 shift better than most cable bikes? Yes. Is it harder to fix if it fails? It could be very difficult to fix. I am saying that and I can fix anything...design and build my own computers...built race cas and motorcycles.
#110
It'll definately be much harder for an averag joe to do any diagnosis without having the specific diagnosis tools, whereas any average joe with a bit of basic mechanical understanding can quite easily do all types of diagnosis, maintenance and repair on mechanical systems.
The same has happened with cars and motorbikes in years past.
#111
Descends like a rock
I like how a humorous post about forgetting to charge a battery that lasted a really long time turned into a discussion of how Di2 sucks.
#112
Liked 8 Times
I have never used it, so I can't comment on the first statement ... but it's obvious from simply looking at how it works that it's going to be much more difficult to repare than any mechanical system since it's inner workings are much more complex.
Perhaps better analogy of cars to bikes is throttle by wire. Ask Toyota...lol. Are cable-less throttles generally more acomodative and work best as an electronic interface with other EFI sensors talking to the ECU? Yes. If a throttle potentiometer fails it will cost a lot more to fix however . So technology is a slippery slope.
Bottom line is there is diminishing return. Ask anybody who has ever owned a high end BMW with I-drive out of warranty...lol...why they have such cheap resale...nobody can afford them out of warranty.
#113
Quoted: 22 Post(s)
There should be many such threads if the risk is material. It does sound to me like the risk of increased down time due to issues increases with Di2, but the risk of having an issue to begin with is low. Otherwise this forum and most forums would be littered with unhappy customers waiting for their bikes to be fixed.
#114
thats one fear I would have. I am forgetful person by nature and if I happen to be excited about my ride and off I go without remembering to have charged my bike.....I would be in trouble. To easy for me to make that mistake. I will rely on my manual shifting which hasn't failed me yet. plus I can save my money to buy other things I dont need!
Cat 2 Track, Cat 3 Road.
"If you’re new enough [to racing] that you would ask such question, then i would hazard a guess that if you just made up a workout that sounded hard to do, and did it, you’d probably get faster." --the tiniest sprinter
#115
toasty!
Quoted: 550 Post(s)
Liked 325 Times
with big down time with your bike if you don't have a back up bike.
#119
Di2 cant be that complicated. You have shifters, derailleurs, a wire between them and a brain. If a part malfunctions, you swap it for a new part, just like you do with mechanical.
#122
your god hates me
Bikes: 2016 Richard Sachs, 2010 Carl Strong, 2006 Cannondale Synapse
Quoted: 1270 Post(s)
Liked 1,308 Times
Maybe I'm being unfair, because I tend to be a bit anal about routines. My commuter bike has a headlight with a rechargeable battery; every time I get home from a ride, I put that bike away in the exact same place, a spot reserved for that bike...that happens to be directly adjacent to the always-plugged-in battery recharger. So every time I put that bike away I plug in the recharger. Every time.
If I had Di2 I'd do the exact same thing. Problem solved.
#123
Faster but still slow
Bikes: Trek 830 circa 1993 and a Fuji WSD Finest 1.0 2006
Does anyone care that this is a thread from last year? I think the OP has his battery charged by now.
#124
