Pet peeves
Method to My Madness
Quoted: 2027 Post(s)
Liked 1,520 Times
Apparently not the case in sunny southern California, where the weather is finally cooling slightly.
Biggest pet peeve is my recent (circa mid 2022) loss of the ability to edit my previously posted threads; when I click edit, the window is blank.
* Edit: Then serendipitously I find out that if I first click to the post number to display the individual post in a separate browser tab, then click Edit, I can see my original post.
Also:
1. People who do not search.
2. People who start a new thread on almost exactly the same subject as another thread then currently among the top 25 or so threads on the front page of a sub-forum.
3. People complaining incessantly about #1 and #2.
Also:
Quoted: 5885 Post(s)
Liked 2,728 Times
Good point but wrong pronoun. I don't use a tension meter when truing, and use one ONLY as a final QC, to sample tensions when building new wheels.
While I don't use a ruler, my build up process is highly focused on length. I start by turning all nipples to a set depth using an ejector screwdriver, and make a conscious effort to maintain uniform length. Final truing corrects for errors and rim deformities, with spoke lengths typically staying with 0.5mm (one turn). Tension stays even because there's no reason it wouldn't.
Liked 2,728 Times
FB
Chain-L site
FB
Chain-L site
Quoted: 3576 Post(s)
Liked 2,997 Times
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
Liked 2,728 Times
Since you quoted me, I took it to mean me.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
Liked 2,997 Times
Sorry. I was speaking informally, as we are wont to do on this site and others. Guess I should have said "why would one use a tensiometer?"
BTW, as long as we're using precision language, the term "tension meter" isn't found in the Merriam-Webster on-line dictionary.
However, "tensiometer" is ("a device for measuring tension [as of structural material]").
Cantilever believer
Quoted: 554 Post(s)
Liked 1,920 Times
From my cold dead fingers, bucko.
Liked 2,728 Times
Sometimes, I'll use the phrase Tension Meter to avoid having to fight with spell check, especially when using voice to text.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
Quoted: 2624 Post(s)
Liked 1,966 Times
FWIW: Park Tool refers to their TM-1 device for measuring spoke tension as a "Spoke Tension Meter" . The same term appears to be the term of choice used by numerous other manufacturers who make devices to measure tension in physical objects (wires, cables, belts, fabric) when referring to their products.
Liked 2,997 Times
Liked 3,051 Times
if someone understands what the end goal is supposed to be, yet a deliberate impediment using language is the barrier that prevents progress, that is poor behavior in logic.
-Oh Hey!
-Oh Hey!
Which was actually the point of my comment: that the two terms, regarding measuring mechanical tension, are synonyms.
Liked 2,997 Times
Liked 2,728 Times
I agree wholeheartedly. OTOH - language and thought are closely intertwined, and when people don't KNOW, language can drive the process. I try to keep that in mind when responding to questions from folks that seem not to know.
FB
Chain-L site
FB
Chain-L site
Liked 2,728 Times
So both are right, but I'll venture that Tension Meter would be clearer than Tensiometer to the uninitiated.
FWIW - "tensiometer" can also mean a device to measure blood pressure, on in another context. something to measure soil moisture content.
Likes For FBinNY:
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Liked 2,728 Times
Shortening the spoke pulls the rim in and across. The change in spoke tension is a byproduct resulting from the rim's resistance. Those of us old enough to have built with 269gr. rims remember that they barely resisted at all.
An easy way to look at it is that tension is a force, but (in this context) length fixes position.
FB
Chain-L site
FB
Chain-L site
Guest
Liked 3,270 Times
Likes For Rolla:
ignominious poltroon
Quoted: 2275 Post(s)
Liked 3,499 Times
As illustrated in post #2.
Liked 2,728 Times
After losing long posts while editing, I now post the original, including the various dingbats, then edit.
I find this easier, though it leads to some fun for a few minutes.
Some people might like features like auto-correct, but they remind me too much of the Sorcerer's Apprentice.
Likes For FBinNY:
Quoted: 2357 Post(s)
Liked 2,877 Times
Back in the day a lot of crit riders used barcons. I seem to recall Greg LeMond using them in the cat's hill criterium in Los Gatos, certainly other riders did
this years tour de france had riders on 30 to 32 on the cobble stages, 25 on time trial and 25, 26, 28 for everything else (mix of tubular and tubeless)
Liked 2,877 Times
another pet peeve cheap alternative chain lube and grease threads, like people are going broke getting a tube of Phil's or a bottle of Chain-L (or whatever else your favorite is )
Likes For squirtdad:
