Buying cheap bike and then upgrading it
Quoted: 1110 Post(s)
Liked 1,048 Times
Check out something like these
https://bikesdirect.com/products/mot...avel-bikes.htm
https://bikesdirect.com/products/mot...e-roadbike.htm
https://www.bikesonline.com/2023-pol...sora-road-bike
https://www.poseidonbike.com/product...43625995469028
Looks like the bike you're picking out is around 600, depending on where you live many of these bikes ship free and the companies don't always have tax which can bridge some of the price difference.
When looking at a cheap bike the one thing I highly recommend is to avoid anything 7sp, if the rear cogs start with a 14t, then the hub is a freewheel and in my experience not a great system. Freewheels worked well for 5 and 6 speed but came to suck with 7sp when the hub spacing widened. It also means the bike isn't upgradeable unless you replace the wheels first and then you have to waste money on a 7sp cassette at the same time. Better to just start with an 8sp. From there some upgrades are possible but with any of the bikes I listed the bike quality will be decent, not great or amazing, but good and reliable. After a certain point, more expensive bikes are just better but its a systemic thing, the fork and frame is better, not just the parts, and upgrades will only get you so far, but if you can bump your cost a little you'll get a bike that is decent enough you can ride it a long time before worrying about just getting a better bike.
This has never been my experience, we live in the internet age, it takes a little time and searching to get something better than what you'd get at the store for less money.
Quoted: 3598 Post(s)
Liked 3,016 Times
With bikes, you really do tend to get what you pay for.
Quoted: 426 Post(s)
Liked 274 Times
A drawback to the proposed approach is that the components you'll eventually want, won't be compatible with the cheap bike. You'll be endlessly battling with compatibility issues, and accepting compromises such as older style or second-hand parts. And then the new components will be incompatible if you ever get a new frame. And so forth. In my view older bikes only make sense if you're satisfied with them as-is or with relatively minor upgrades.
There's also an issue with pricing, which is that the bike makers get huge volume discounts on components, meaning that a fully built bike will always be cheaper than buying its parts and assembling them yourself, unless you luck into a series of killer deals.
This ^^^^ 100%
I loved my first bike hybrid bike. It was too expensive and not the common standard to upgrade. I had no shimano disc brakes with quick release and only 9 speed. getting tires for it was a pain. it had like 47mm road tires on a wide rim i thinnk it was 650b.
If you could afford it I would get a topstone gravel bike. thru axle; disc brake, threaded bottom bracket. round seat post and round stem. just a normal bike you can upgrade or least find parts for it 20 years from now.
topstone 1 $ 2,200 2x grx i would get this bike if you have enough saved up
https://mikesbikes.com/products/cann...40483601285189
if 2k is a little much you can get a topstone 4 same alloy frame so you can upgrade the whole bike later if you want.
topstone 4 $1,200
https://mikesbikes.com/products/cann...9f67d9e9&_ss=r
Clark W. Griswold
Quoted: 4449 Post(s)
Liked 4,112 Times
No a cheap bike is not worth upgrading. Get what you want from the get go. Spend the money because in the end upgrading is expensive and the only reason to upgrade if you have a really good frame worthy of upgrading. A bottom end bike is there to ride into the ground till you can get what you want. That 105 bike is going to be an entry level bike, it is going to be a good solid reliable bike vs just a low initial cost bike. The lower the price generally the more expensive it is in the long term. If you really cannot afford the bike wait a bit or see if your local shop can do any financing.
Bikes: Way too many
Quoted: 936 Post(s)
Liked 610 Times
hello, im new to road biking and looking for an entry bike.
Does it make sense bying an extra cheap bike in a store and then slowly upgrading it?eg I buy Triban RC 100 or Supercycle Circuit use it then whenever I feel that I've reached kind of peak on this bike upgrade it with newer groupset like Shimano Deore or 105, better fork, brakes etc., and then whenever I reach a new peak I just move all my good components onto a new good frame.
The RC 100 has bar shifters, so you need to move your hands off the hoods/bakes to change gear which is a pain and unnerving if you're not confident. The RC120 has proper shifters built into the brake levers so you can leave your hands where you are.
The RC120 will do the job fine for a long time, so I wouldn't even bother trying to upgrade it. After you've had it a while then you can always look for a better bike based on what you like/dislike about the first one.
It's also worth noting that there are some good deals on the used market - you can get a lightly used RC500/520 for about the same price as a new RC120, assuming you don't qualify for the cycle to work scheme. If you're not sure what you're looking for then it's worth seeing if you can meet in a bike shop or bring someone more knowledgable with you, but you basically just need to look at condition and check that all of the gears and brakes work, that there's no rattles or grinding noises.
(I wasted a LOT of money initially by buying cheaper bikes and upgrading parts, then selling them and buying nicer bikes).
Quoted: 4547 Post(s)
Liked 5,059 Times
Because I'm not experienced in buying used bikes, so don't want to get a bad buy.
If you do have a larger budget available then I would seriously consider starting off with a better bike with a frame worth upgrading. But you would need to be confident in knowing what sort of bike you really want long term for that to work out. If you buy a decent bike that turns out to be unsuitable then you are back to square one and more out of pocket. A really cheap bike like the Triban might help you to get some riding experience without investing too much money up front.
Do you have any knowledgable biking friends who could help you to find a good quality used bike? This is the most cost-effective way to get started and could lead to a viable upgrade path later on. But it needs input from someone who knows what they are doing as there is a lot of junk out there!
Quoted: 1844 Post(s)
Liked 1,716 Times
The Triban RC 100 is good in that it's cheap, but I'd strongly recommend looking at the RC120 instead.
Liked 5,059 Times
I agree with this. Although the RC 100 is inexpensive, the RC 120 is far superior in that it would provide years of riding without any pressing need to upgrade. The 8 speed cassette is a better choice than the 7 speed freewheel on the Rc 100. As well, the RC 100 has no front derailleur, greatly limiting gear choices. I would choose a bike from Decathlon before any bike from Canadian Tire. Any Decathlon store I have been in has a well equipped shop area with all the proper tools needed to assemble and adjust a new bike. I have never seen anything like this in any Canadian Tire store
Quoted: 7675 Post(s)
Liked 3,562 Times
Hwere is one final bit of "wisdom" from me ... (everyone is laughing at that .... )
Really, why upgrade a bike?
The only real "upgrades" one need consider are saddle 9because everyone's body is different and you need the right saddle shape for you) and wheels (because e=a lot of manufacturers don't put much money into wheels.)
Whether buying a lower-cost bike or a really good one, upgrading is usually not financially feasible.
A groupset---the running gear--shifters, chain rings, derailleurs, cassette----will run several hundred to a couple thousand dollars, retail. Buy a bike that already has the stuff you want, because (as was noted above) manufacturers buy in bulk and get all that much cheaper. get a basic bike and just ride it while saving up for a bike which already has the stuff you want.
Wheels can cost the same or more (for the really high-end stuff.) But if you are a serious rider----lots and lots of miles, competition, whatever---you might want to use really good wheels. Generally they last longer and/or perform better---but this is in a price range well beyond basic or entry-level.
My point is, "upgrading" a bike is rarely financially feasible--and far worse if you cannot do your own mechanical work. And particularly for more casual riders, you are not likely to notice a big difference in the actual riding experience. Going from Claris to Sora---both are so good nowadays---gains you one more cog and maybe saves a couple grams. You won't much notice. Anythi9ng below Shimano 105 isn't going to gain you much in terms of the actual riding experience.
Most important thing is fit, followed by reliability. Get a bike which is comfortable to ride, which is ready whenever you want to ride it, and just enjoy riding. Seriously, modern Claris is probably better than the stuff the pros were using 25 years ago. Plenty of people ride 8-speed groups and don't miss anything. I have bikes with 9 and 10 cogs, and I enjoy riding them just as much as the 11-speeds .... and I cannot see where 12-speed would add a Whole lot to the experience.
Get a comfortable, reliable bike and ride it as much as you like. Future purchase plans will become clear as you rack up the miles.
Likes For Maelochs:
Liked 3,016 Times
I never upgraded any of my bikes thinking it might be "financially feasible."
Quoted: 511 Post(s)
Liked 651 Times
Some People Don't Have A Choice!
I have seen a few people delay ridding because they are looking for a suitable bicycle. I personally find this wrong. Ya find yourself some garage sale bicycle and hopefully its of standard specs. First ya replace whats totally broken or worn. Then ya transition to other things all the time keeping an eye out for the frame ya really want. At the mean time you are ridding...That's the ticket... Get ridding...
Laugh at my Dumpster Diving bicycle all ya want... I am ridding...
Slowly it may evolve into a gem or get parted to the gem frame you finally got. So would I kiss a frog? Sure... If it allows me to ride.
Likes For KerryIrons:
Bikes: two blacks, a blue and a white.
Quoted: 445 Post(s)
Liked 849 Times
There's a "higher order" question floating on the outskirts.. "Is cycling something you're going to add to your lifestyle? Will this be a habit or an occasion?" Grab any bike - even borrow a bike - and ride it five times a week for six weeks. That is enough time to learn a lot and also start to feel the benefits. If you love it - or even just tolerate it for six weeks, you will want a good bike, and by then you will have ideas of what you want. But if the six-week experiment fails, then even a $300 big-box-retailer-crappy-bike was not for you.
Likes For blacknbluebikes:
Quoted: 2368 Post(s)
Liked 2,893 Times
of course OP with post count of 1 has not replied yet
Bikes: 2008 jamis ventura race
Quoted: 25 Post(s)
Liked 3,016 Times
PBP Ancien (2007)
Bikes: Cannondale CAADX (for commuting), Cannondale CAAD12, Cannondale CAAD12 Team CNCPT, Giant Contend 2
Quoted: 77 Post(s)
Liked 156 Times
I've ridden in to work today on a Triban 100 with drop bars but would recommend the OP goes for a higher spec' bike. For me, that would be a minimum of an alloy frame, carbon fork and a Claris groupset. That's what I bought for my dry weather commuter in the shape of a Giant Contend and I was fortunate in spotting a mint used one for just over $300.
Likes For Welshboy:
Liked 3,562 Times
Seeing as people are already reading this thread, try putting it here .... the folks who are still responding have shown an interest in your situation.
If eventually you are unsatisfied with the responses, you could start a new thread but it would be more on topic and hopefully more helpful ... but likely the same few posters would respond, so .....
Quoted: 790 Post(s)
Liked 348 Times
Current bicycles, even the high-end ones, are pure garbage consumer-grade trash that only fools consider. The only intelligent move for a serious bicyclist today is to buy a road bike from the 1990s or earlier that was of good quality when it was new. They can be had for a song and a dance and are many times the bicycle that is being foisted upon the public today by unscrupulous profiteers and their marketing executives.
Expired Member
Quoted: 3763 Post(s)
Liked 5,709 Times
Likes For shelbyfv:
Bikes: Time Scylon, Lynskey R350, Ritchey Breakaway, Ritchey Double Switchback, Lynskey Ridgeline, ICAN Fatbike
Quoted: 474 Post(s)
Liked 557 Times
Likes For DangerousDanR:
I'm going to go against the flow and say "Why not?" I have a 12 year old relatively low end Giant hybrid that I've put a lot of money into over the years changing and upgrading it. Why? Because I like the bike. It fits me well and it looks good. I enjoy tinkering with bikes, so buying new parts to put on it is something I enjoy doing. It's now more like a gravel bike than a hybrid, and has nothing original on it except the frame and seat post. But despite having a much flashier custom Ti bike now in my stable (also built up completely by myself) I still enjoy riding the old Giant.
Liked 5,059 Times
Liked 3,016 Times
I think there's a bit of misunderstanding when it comes to "cheap" bikes. Your Giant, while maybe "low end," was able to be upgraded because it is actually a better-quality bike. I think most folks are trying to steer the OP away from more "big-box" bikes, which may be more difficult and expensive (and maybe in some cases impossible) to attempt to "upgrade."
Likes For smd4:
Quoted: 2629 Post(s)
Liked 1,977 Times
