Presta valve caps
Friendship is Magic
Bikes: old ones
Quoted: 26425 Post(s)
Liked 10,381 Times
Clark W. Griswold
Quoted: 4358 Post(s)
Liked 3,996 Times
Presta valves are fine, no need to damage them just pull the pump head straight off no need to jiggle it around. If you are rough with things than yes they can break or at least get damaged, but you just don't have to do that.
My bikes are in various states of having caps and not having them. I have a couple that do happen to have aluminum caps only because they look nice beyond that I don't really care. I might replace if I have it just by force of habit working in a shop but if it cracks or I drop it I will just go without and no issues.
I do however recommend something like this. Never a bad thing to make sure your core is tight and useful for tubeless set ups.
I would love to see a more modern valve at this point but Presta works just fine and I don't really have issues so not really a need and no want for new standards because new standards suck
I agree with the others who say they use them to keep the valve stem clean. That's why I use them. Will they keep the tube from leaking? Maybe, but probably only keeping the valve seat clear from dirt which would prevent a good seat and cause a slow leak.
The only time I had a problem with a presta valve leaking is when I bend the stem. I just bend it back and it it leaks I replace the tube and keep the leaky tube as a spare.
Valve caps are cool. Like the old SNL skit, "More Cow Bells" with Christopher Walken, express yourself!
Quoted: 1083 Post(s)
Liked 687 Times
Incorrect. Presta valve caps are strictly to keep the valve clean, same as with a Schrader valve cap. The bike might be caked in mud but at least you can pump up your tires after removing the cap. I use the aluminum ones, only because the plastic ones always crack.
Quoted: 3241 Post(s)
Liked 2,512 Times
Shawn of the Dead
Quoted: 277 Post(s)
Liked 448 Times
If I put red valve caps on it might shred the very fabric of space/time !! I actually sold this bike (still mad at myself for that) to fund an equally insane bright red Ducati Monster 1200R. I hope to find another 1098/1198 model in the future.
On Your Left
Quoted: 3004 Post(s)
Liked 2,434 Times
Likes For GlennR:
Quoted: 1364 Post(s)
Liked 1,678 Times
+1 check to see if the tube has a removable core, and if it does, is it loose?
BTW, I just now discovered that some Schrader valves also have removable cores and that removing the cores lets you inject sealant into the tube or tubeless tire without gumming up the valve.
I still run tubes on all my bikes and I have never used sealant so none of this really affects me except when I have inadvertently unscrewed and loosened a presta valve core. Accidentally loosening a Schrader valve core would be a lot less unlikely, and I have yet to do it.
Palmer
Quoted: 1671 Post(s)
Liked 1,825 Times
This is almost as fun as a chain lube thread.
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,308 Times
Likes For Chuck M:
Quoted: 4806 Post(s)
Liked 3,932 Times
???? That valve cap looks black. Jeff beat me. I answered before reading the next post. (This is a thread about valve caps, not frame paint.)
On Your Left
Liked 2,434 Times
Likes For GlennR:
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2585 Post(s)
Liked 5,646 Times
That’s why the cops I know call it “Arrest me red”. Full disclosure, the last sports car I sold was red and somehow managed to avoid tickets no matter how much I deserved them. Sports bike people will understand but others can save your breath. Now back to the important matter at hand.
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Grupetto Bob
Liked 5,646 Times
My wife was stopped for speeding downhill on a blue-purple Cannondale. She was doing 38 in 30 zone. When discussing the ticket she remarked that she really wasn’t trying today and can usually hit 45. he was not amused.
Likes For rsbob:
Cheerfully low end
Quoted: 646 Post(s)
Liked 1,044 Times
Nope. The plastic cap won't keep air in the tube; they don't seal tight enough, and if the valve is open, the cap will just push down on it and make it leak faster.
The only use I have for a presta cap is as an emergency shraeder adapter. Cut off the tip, turn it upside down, and screw it on. You can then use a shraeder pump or gas station compressor.
https://www.purecycles.com/blogs/bic...hrader-adapter
Otto
Grupetto Bob
Liked 5,646 Times
AAMOF one S was a 73 but it was white and the other was a red 82 “S”C. Now my ‘sports car’ is a 2021 Italian steed - a Bianchi Infinito which lives next to my 88 Campy Chorus Bianchi Compione del Mundo.
Quoted: 1109 Post(s)
Liked 1,200 Times
Likes For Camilo:
Bikes: 2020 Masi Giramondo 700c; 2013 Lynskey Peloton; 1992 Giant Rincon; 1989 Dawes needs parts; 1985 Trek 660; 1985 Fuji Club; 1984 Schwinn Voyager; 1984 Miyata 612; 1977 Raleigh Competition GS
Quoted: 1126 Post(s)
Liked 253 Times
For more than 40 years I've never kept the caps or the nut that Presta valves come with on the valves, and never had a problem. I did have issues with a couple of cheap valves found on Slime tubes I used once. However, on my touring bike I leave the cap on since that bike will see a lot more rain and dirt, so I felt I would rather be safe than sorry while far from home.
Anyway, all Presta tubes come with the cap and nut, you don't need to keep the old ones unless they're some specific color you like you can't find on the new tube.
Quoted: 225 Post(s)
Liked 1,101 Times
Never used it but the built in spoke wrench is clever. I like that schrader hack too.
Montana, where men are men and sheep are lying little tramps.
Grupetto Bob
Liked 5,646 Times
Rule 60. From the good book: https://www.velominati.com/
“Ditch the washer-nut and valve-stem cap.You are not, under any circumstances, to employ the use of the washer-nut and valve-stem cap that come with your inner-tubes or tubulars. They are only supplied to meet shipping regulations. They are useless when it comes to tubes and tires”. Amen
