1980s & 90s Italian Road Bikes - Appropriate Frame Size To Height
Quoted: 981 Post(s)
Liked 1,844 Times
Based on all of the other responders here, you're literally the only one who didn't offer the correct advice. Even with a super tall 30cm bottom bracket height set up for criterium racing and a 59cm frame I would have about 5cm of space left between my inseam and the top of a frame - which is two inches.
The image below shows how bottom bracket height is measured. The standard measurements of a frame (seat tube, top tube, main angles) is done on top of this and bottom bracket height does not influence any of those factors.
If you have a bicycle with a 57cm frame with a 25cm bottom bracket height, then your standover height is going to be five centimeters lower than a 57cm frame with a 30cm bottom bracket.
Quoted: 3464 Post(s)
Liked 2,834 Times
58/59 ctc seems about right. I’m about 1/2” taller than the OP.
I tried everything from 56-62cm and found that seat tube angle and top tube length are also important parts of the fit equation. Slack seat post angles (less than 73 degrees) don’t work for me.
Some 1980s Italians I’ve owned:
56 ctc - fun, but required setback seatpost and 130 stem. Ended up selling
57 ctc - good ride overall. Need to get this one back on the road.
58 ctc feels a little less racy than the Ciocc and the tt is 1 cm longer.
way way back I had a track bike that was really unsuitable for my gear limit and racing. Was a British bike, 21-1/2” center to top with a 22 1/2” top tube, very slack seat tube angle, 71.5 degrees!
really a big bloke pursuit bike or an argument as a board track 6 day sword.
this was my first track bike and was a frameset, not easy to find track bikes in 1974. I also was able to buy it on time payments! So, that or nothing. It was not until someone gave me an image of me from the side that I realized how my position was just Wrong.
adjusted the seat forward, which placed me in a much better position to the cranks for high cadence racing but too close to bars. I went from a 95mm to a 135mm stem, I looked much better on the bike after but really went contrary to the geometry.
A compromise for sure. I was fortunate to order a new bike at the end of the year, unfortunately it did not show up until just after the nationals.
I still have that bike. Was amazing from the first ride.
the vast majority of bikes purchased by forum members are as built purchases, one has to adjust the saddle and bars to work, the key is to understand what was built and if that is suitable.
Likes For repechage:
Quoted: 4546 Post(s)
Liked 1,689 Times
One thing to keep in mind is that typical Italian frames are measured ctc, while most American companies size ctt. So what an Italian would call a 57 we would call a 58. But that's just height. On US geo charts, Top Tubes tend to be slightly longer than Seat tubes up until size 58, while Italians often go "square" at smaller sizes, meaning that they generally have slightly shorter top tubes for the same size bike.
Given the OPs height, something between 58 and 60 seems appropriate, depending on how it is measured and TT length.
Likes For Kontact:
Quoted: 981 Post(s)
Liked 1,844 Times
-Gregory
Quoted: 1150 Post(s)
Liked 1,777 Times
A lot of talk of the Lemond fit. A couple of things come to mind. He was flat out racer and a freak of nature. He was very much in an aero dynamic position in peak form.
I had one of his 853 frames in my size. As a casual rider omg it was horrible, as a racer it was nice and weird at the same time. I felt like I was a bus driver, twitchy steering from a back seat.
I don't like the reach in conjunction with saddle to bar drop as much as used to.
Likes For Mr. 66:
Liked 1,689 Times
Quoted: 1965 Post(s)
Liked 2,057 Times
A few weeks ago there was a review posted of the Merckx/Hamsten bike and I thought it was interesting. Eddie moved Andy’s seat back, with a longer stem and a larger frame. But Andy wasn’t taller or more flexible😉
Making up the numbers
Quoted: 111 Post(s)
Liked 519 Times
I had a Lemond and have read all the geo charts, and used his book for my fit way back when. I don't know what you guys are talking about. The geometry is typical (but based on ctc), and the seat set back is KOPS. All of his talk about geometry was in defiance against bikes that were 74/74, which are almost unheard of since the '80s.
Important I think to remember that seat tube angle is only part of a geometry/bicycle fit equation. Zero setback seat posts were almost unheard of in the 1980s but have become fairly common as some cyclists sought to return their saddles to where a 74 seat angle would have placed them, but which their newer 72-73 frames would not otherwise allow. Nowadays several popular _race_ frames have returned to 73.5 if not 74 degree seat angles.
Another observation is that the OP asks about 1980s and 90s road geometry. I and others have answered from a racing perspective because at that time the distinction between road and racing was far less than it is now, with the subsequent evolution of a large non-racing road population riding “endurance” bicycles.
In a conversation such as this there will always be broad generalisations and countless exceptions, but to come back to the OP’s question of 1980s/90s c-to-c seat tube ie. frame size for a road cyclist of his height, from a racing perspective I’d expect to see at that time…
1. A 59 or more likely 60x57 74/74 frame if adopting the then-traditional 70s/80s school of thought and corresponding frames with a degree of US criterium and/or UK time trialling (with its short wheelbase/cigarette paper clearances) mindset thrown in.
2. A 58/59x58 74/74 frame with 12-plus stem and max. saddle setback if adopting the emerging school of thought popularised by Hinault/Lemond to frames then available. Maybe even a 57cm c-to-c frame if top tube length could be sacrificed.
3. A 58/59x59 72.5/74 frame if well-funded and buying to order, or sponsored by someone offering such a frame, and on trend with what emerged into the 1990s.
In re-reading the above it’s only a cm or two here and there but in my corner of the world 2. was most common into the early 90s, when sloping top tubes and even greater saddle to bars drop loomed on the horizon and I lost interest…
Of my current bicycles this 59x60cm c. 1995 Ron Cooper is most representative of what I’d have raced, or wanted to race, from a geometry perspective, in the early 1990s, although I’d _never_ have considered an all-leather saddle then, nor have left 2cm of steerer tube and spacers below the stem… whatever saddle I’d have used would have been further back on its rails and the rear hub would also have been fully forward in the dropouts.
Nothing quite says wall hanger like drillium toe straps
Likes For seagrade:
Bikes: Cannondale Synapse, LeMond Victoire, Bianchi Campione d'Italia, Kona Hei Hei, Ritchey Ultra, Schwinn "Paramount" PDG, '83 Trek 640
Quoted: 272 Post(s)
Liked 338 Times
Gregory,
Lots of back-and-forth here, but I can only say that I'm 6'4" and ride a 63cm Bianchi with a 59.5cm top tube. I've never put much faith in the "lift the bike and it should go up some amount" because, as you say, the bottom bracket drop changes things. I tend to size frames by the top tube, since seatposts and stems are now available to make the vertical fit work. But, as you allude to, the seat tube angle makes a difference there, too. The aforementioned Bianchi is a 72-degree seat tube angle.
Likes For mhespenheide:
Liked 1,689 Times
While I haven’t read Lemond’s book/s, I suspect his approach was influenced by, and developed upon, Hinault/Genzlings’ philosophy. Merckx Century geometry also played its part in the move away from 74 degree seat angles, especially in non-US/English speaking markets eg. continental Europe, although it used shorter top tubes in larger sizes than I think Lemond would have advocated.
Today, road and race style bikes aren't really any different from then, except many have taller headtubes. So-called endurance bikes are sometimes road bikes, and sometimes they are sport touring bikes. But long wheelbase Endurance Bikes aren't road race bikes - they are a new category that is supposed to be different. Same with Gravel Bikes.
So I don't know what era you are talking about other than that some steeper angles were briefly embraced in the '80s for crit minded, and pro road racers largely did not use them.
As far as Lemond fit goes, that's all Cyrille Guimard.
Steel is real
Bikes: 1992Giant Tourer,1992MeridaAlbon,1996Scapin,1998KonaKilaueua,1993Peugeot Prestige,1991RaleighTeamZ(to be upgraded),1998 Jamis Dragon,1992CTWallis(to be built),1998VettaTeam(to be built),1995Coppi(to be built),1993Grandis(to be built)
Quoted: 685 Post(s)
Liked 1,008 Times
I am mostly riding 56cm to 57 cm road frames with a 130mm stem.My Grandis, My Coppi and My Pinarello steel frames from the 90's are all of the same size.
Quoted: 3579 Post(s)
Liked 3,001 Times
Figure out what size you need on your own.
Quoted: 981 Post(s)
Liked 1,844 Times
Please refrain from responding to my posts until you learn more about how bicycles work.
I was able to figure out what size I need based on the informed and educated comments provided by others in response to my query, for which I am appreciative.
-Gregory
Liked 3,001 Times
And learn how the forum’s signature function works so you won’t have to re-type your name on every friggin’ post you make.
small ring
Quoted: 439 Post(s)
Liked 936 Times
You've made it clear just how much you've forgotten. And please, make more childish insults.
59 Allegro Special -- 72 Bob Jackson -- 74 Motobecane Grand Jubile -- 74 Sekine SHS 271 -- 80 Nishiki International
Liked 3,001 Times
Liked 1,689 Times
You offered advice that is not helpful at all because apparently you don't even know how basic considerations of frame geometry like bottom bracket height and tube angles affects standover height. Anyone using Lemond's sizing chart or taking the advice of almost every other experienced rider/racer here that responded would probably have between 2-3" between the top tube and their inseam. I currently have a 62cm frame with 700x23c wheels sitting in front of me right now that still provides me with more than 1" of space between the top tube and my crotch because it has slack frame geometry and a low bottom bracket, which are apparently things you can't comprehend.
-Gregory
-Gregory
Further, BB height differences aren't sizing differences. If you buy a cyclocross bike with a high BB, you still look at overall fit instead of standover. But "road bikes" don't have considerable variation in BB height. They are all going to be within a centimeter - and usually they are within less than that.
And of course your 62 still has clearance - look at the math. The difference between a 60 and 62 in standover height is only 3/4 of an inch. If you had 2" of clearance with 60 you will have 1 1/4" clearance with a 62.
Quoted: 981 Post(s)
Liked 1,844 Times
I clearly stated that I'm more used to researching and riding road bicycles from the immediate post-war era, when bottom brackets could be as low as 10" on many models of English bikes with 71 degree seat tubes. Alternatively, I've ridden more modern road bikes with 11" bottom brackets and 74 degree seat tubes, which could make the standover almost equivalent for frames as much as 5-6cm different in size.
-Gregory
Liked 1,777 Times
Here's my best fitting Italian, I think it's a 60x58 with a Nitto Pearl 10 stem
The Olmo is different it is 60-56 but its a fit
I am 6'1" ish with 32" inseam, I'm rather balanced proportional.
Neither of these have Lemond's length of top tube. The Olmo is criterium geometry.
Likes For Mr. 66:
Quoted: 981 Post(s)
Liked 1,844 Times
For my inseam the total measurement, assuming a 10.75" bottom bracket) in the chart adds up to 2cm less than my inseam. That does not including frame angle disparities, which lead to significantly more difference in reality.
However, regarding your point about people shorter than myself, which I had not considered, the shortest inseam listed below, 66cm, would result in 71.3cm from the ground to the top of the top tube (adding 1cm onto the c-c measurement shown). That's 5.3 cm higher than the inseam. So yes, you're absolutely correct about shorter people based on these calculations and that's rather fascinating to realize!
Liked 1,689 Times
Just to be clear, anyone with the same inseam (i.e. the same sized legs) would end up with the same size frame (along the seat tube measured c-c) based on the Lemond chart, so their standover height would not vary, whether they're 6' tall or 6'5". They would need to be adjusting their top tube and stem lengths from there. That makes sense, right?
Likes For Kontact:
Quoted: 981 Post(s)
Liked 1,844 Times
-Gregory
Quoted: 175 Post(s)
Liked 453 Times
Anyways, moving into the mid-modern racers. Merckx adapted to era. When Eddy M. came aboard the 7-Eleven team, he completely disrupted Andy Hampsten's fitment due partly the secret sauce of shrinking the frame. Transformed him to make the record book.
Likes For chain_whipped:
Quoted: 175 Post(s)
Liked 453 Times
How old you are and rate your physical condition is what matters.
Touring comfort widely varies among riders. Subjectively endless.
Racing is another matter. Discussion of aero plays a huge part and around 70% of it is rider body. The remaining aero advantage is the bike, etc..
So if you're young and fit, want to be fast on your 80's bike, size down, slam that stem. Cow bells!
