Brake rotors, really a difference?
Quoted: 46 Post(s)
Liked 7 Times
Not looking for an argument, nor getting worked up, just pointing out that levers to the bar aren't caused "pad/rotor overheat to the point of failure." This is basic stuff.
Followup question. If you learned about pumping the brakes in driver's ed, were you on the ball enough to do that when your levers allegedly pulled all the way to the bar?
nothing to see here
Quoted: 218 Post(s)
Liked 145 Times
Uh, you replied to my post with the smarmy emoticon, hence my question. You really should pay attention.
I survived using that very same training. Never had any air form in the system which will accompany a boiled fluid condition. The rotor was definitely blue afterwards.
I've had brakes fail to the point they were almost useless after a steep downhill and about 50% effective for the rest of the ride well after they cooled down. It was isolated to my off brand pads. Tossed them and never had the problem again on the same rotors (Shimano RT66 at the time). I'll still stand by my statement that pads are much more a factor and difference than rotors are.
Quoted: 46 Post(s)
Liked 7 Times
Once the brake fluid cools, the water is reabsorbed and when you pop the reservoir open everything can look fine, except the fluid is usually darker because it's been contaminated.
Rotors are a pretty simple mechanical device. As already mentioned, spend the money on the pads.
The performance difference between a single stamped metal rotor for 15$ and a stamped metal rotor for 50$ is going to be minimal.
You are paying for artistic design more than functionality. Take a look at this
and you can see that the SRAM Guide disc brakes with a stamped disc rotor can take a ton of abuse before failing and even when they do fail, its because they ran out of pads. The rotor itself has mostly held together and does it's job.
Typically the more expensive rotors will be the two part "floating" rotors (Not true floating in the sense of cars and motorcycles) with 2 parts riveted together. Because of the aluminum carrier these are less likely to go out of true than a single stamped rotor. These also will have a point of failure in the rivet that holds the 2 pieces together. Design in the 2 piece rotors can also include different metals sandwiched together to save weight and fins to increase cooling.
As far as performance in a rotor, spending 30-40$ more on a one piece steel stamped rotor won't increase your bikes braking performance.
For the 2 piece rotors there are many more factors to look at in the design to see what the benefits are. That being said, I'd take a guess that 75% or more of the people on this site are not doing mountainous climbs with 5, 10, 15 minute descents nor are they taking a chairlift up a mountain to do some serious downhill. I'll even throw in that on my regular rides I have 2-3 mile descents in the 5-7% average and get up to speeds of 45mph but rarely do I need to brake to the point that they would actually get hot enough to burn you.
I do have lots of climbing and descending where I live and I do need the braking power but spending upwards of 100$ per rotor doesn't equate to the performance gains I need to be a better descender nor does it equal a safer braking system. The gains are minimal enough that the dollar amount just doesn't justify the spend. And I am not counting pennies on a budget.
-Sean
-Sean
Likes For Wilmingtech:
Quoted: 46 Post(s)
Liked 7 Times
Where are folks selling floating rotors for upwards of $100 per rotor? The Hopes are about $60, depending on size.
Non omnino gravis
Competitive Cyclist
Google Search
Seems like 80+ and tax/shipping is about normal for these.
-Sean
Non omnino gravis
Quoted: 1975 Post(s)
Liked 232 Times
Non omnino gravis
Oof. The roadie tax is particularly strong with that one, seeing that the SRAM Centerline R is 50 bucks and the stamped Centerline is $30.
But hey, "designed for road use" and $105 a pop doesn't even include lockrings. I used to think my RT86 180/160 set were expensive at about $75 for the pair. No more!
nothing to see here
Quoted: 218 Post(s)
Liked 145 Times
Shimano RT 900 Rotors
Competitive Cyclist
Google Search
-Sean
Competitive Cyclist
Google Search
-Sean
The XTR Rt M900 rotors are $80, but discount codes come into play sometimes. I got 20% off when I ordered them.
nothing to see here
Quoted: 218 Post(s)
Liked 145 Times
Disc brakes are pretty well sorted out these days. It's only when you start to really work the parts hard that the improved performance comes into play. The average cyclist doesn't push their equipment to the limit so for most people the basic parts will work very well for them.
Quoted: 46 Post(s)
Liked 7 Times
The long term advantage of floating discs is that when they are repeatedly "worked hard" they don't need to be trued as often as solid rotors.
And bling, if that's your thing.
Quoted: 18883 Post(s)
Liked 10,646 Times
I've been using disc brakes a long time, long before shimano ice tech rotors ever came out, and I've never had a pad/rotor overheat to the point of failure. Everything from BB5/BB7/Spyres/HYRD/Red Hydro/Shimano RS685 with finned pads. I've used everything from original avid cleansweeps to icetech rotors and just about everything inbetween. For both road and mountain. I guess I find it weird that some here claim that its a noticeable performance difference with ice tech rotors and yet pros are running sram discs at pro levels without an overheating issue from gravel to cyclocross to road applications. Campy too at some conti levels. I like icetech rotors mostly because they seem to stay true a bit longer but I've never had a performance failure in the field from my rotors. Pads yes, organic pads in muddy cyclocross races barely last the entire 45 mins etc but never rotors.
I overheated my brakes to the point of needing a bleed, coming down the gravel route from Loup Loup Pass. I'd get a mile or two of good hard pack, then suddenly it's washboards so bad I can barely see. There not visible at speed before you hit them, and there's nothing to do but grab a fist full of brakes when you hit them. I could be wrong, but doubt roads like that are involved in the races you're speaking of.
When you brake.. You are 100% converting momentum to heat. When and if the heating stops, the braking action stops or on the flip side, when your brakes stop working, there is no more heat being generated. At a certain velocity and a certain weight and certain time = a specific amount of heat. There is no way around that. The thing that varies is where and what that heat is dissipated too and how even it is spread around. Ideally it is spread around in some ratio to prevent fade or failure from either the disc, pads, calipers, or fluid. You can have rotors and pads that in theory can dissipate heat better or worse to the surrounding air which is a positive and pads and rotors that conduct more or less heat to other things like your calipers (which then goes to your fluid), your hubs etc.. The less a pad conducts, transfers, or moves heat results in a rotor that gets hotter but a caliper that stays cooler. A pad that conducts a lot of heat means a cooler rotor but a hotter caliper. You can say the same comparing a rotor that conduct better or worse. You do not get something for nothing. There isn't much mass in the system to absorb great amounts of heat so drastic changes in temperature can happen very fast.
Quoted: 353 Post(s)
Liked 92 Times
160mm XT icetech rotors are 30 bucks at Jenson. What's the point of spending $20 on a no-name?
https://www.jensonusa.com/Shimano-XT...t+rotor+180+mm
Liked 232 Times
Liked 232 Times
That seems like a pretty convincing argument. But pros probably have better braking technique that a lot of recreational cyclists, and better roads to race on. And lower weight, you have to be pretty light for the job.
Liked 10,646 Times
I think I overheated the fluid on the way down. Don't remember losing braking power completely, it could be that I'm not as young as I used to be, but I think I'd remember that.
Basically lost all modulation until they were bleed. They'd go from nothing at all to lock the wheels with almost nothing in between.
Non omnino gravis
Only two thoughts - Campy H11 rotors made a lot of air noises (thumping) with my SRAM road setup. Rounded edge rotors go into the caliper easier when changing wheels, keeping your paint nice.
Bikes: Space Horse Disc, Domane SL5 Disc
Quoted: 65 Post(s)
Liked 29 Times
I recently purchased the 6 bolt Ice Tech rotors from Jenson, $60 for the pair. I have Ice Techs on my road bike, but stamped rotors on my gravel bike. Both bikes have Shimano hydraulic brakes, but the Domane's always felt more powerful; less lever force needed. After bedding in the new rotors on the gravel bikes, my brakes feel more like the Domane's, so for me there is definitely a difference. This is not to say that the stamped steel rotors didn't work well or were really lacking, but there is an improvement in performance.
Agree, I have a set of RT86 too no problems. End of thread
Back to my way original first post in this thread... A crappy set of pads will always suck regardless of the rotor. A good set of pads will perform good on just about any rotor and possibly better on a better rotor.
