Hydraulics
#51
working on my sandal tan
Quoted: 3873 Post(s)
Liked 2,574 Times
Your riding companions might be the best to judge whether your bike could use a catalytic converter.
Likes For ThermionicScott:
#52
Quoted: 1218 Post(s)
Liked 298 Times
Lots of people say that. but have you personally broke hydraulic brakes in the middle of nowhere?
#53
#54
Advanced Slacker
Quoted: 2764 Post(s)
Liked 2,540 Times
Since I started riding disc brakes 19 years ago, have finished 2 rides with only one functioning brake (also, though it is not what you are asking: one epic day cut very short due to a failing brake, several with a brake so squishy it is barely useful, and several rides that never happened due to brake troubles that I had not had the chance to fix).
ALL of these were involving hydraulic brakes. None with mechanical, despite my using mechanical for far, far longer.
I have (estimate) 4X the ride time on mechanicals as I do on hydros. That’s just mtb. If you count my gravel bike it more like 5X.
My experience with hydros vs mech is that hydros are much less maintenance and hassle.... until they are not, and then they are a huge hassle and time suck.
#55
Mad bike riding scientist
Quoted: 6252 Post(s)
Liked 4,278 Times
Yep.
Stuart Black
Stuart Black
#56
Liked 298 Times
Yep.
my first hydraulic was 2013
the only brakes that I ever had issues with was mechanical BB5. BB5 is why I went hydraulic. I am pretty sure that I have enough of my time invested in BB5 that no amount of bleeding/maintaining hydraulic systems will ever catch up to that amount of time wasted.
My favorite brakes so far are my hydraulic Magura HS11's. Post mounted rim brake hydraulics! Oh yeah, just don't crush a modern rim with them!!
Edit: Realistically stuff in life just breaks. All of it, bikes trains airplanes cars escalators elevators etc..... That is just life. I won't live mine avoiding what is nice! Like a a short flight from eastern Midwest to the west coast. Although some flights get delayed or cancelled due to mechanical failures. Or taking the risk of getting stuck in an elevator.
starters fail, fuel pumps fail, distributor caps fail, Gah I got stranded in the middle of nowhere because my truck broke and there was no cell service either. Should I never drive a vehicle again?
To each their own. Personally some stuff is worth the risk. I mean who wants to stay in their 'safe space' of the lesser of the brakes, Lots of spokes, 4130 frames just in case they break. You know because there is a welder hidden behind MANY boulders in the middle of nowhere. LOL
#57
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,099 Times
my first disc brake (mech) was 2005 Hayes
#58
Advanced Slacker
Liked 2,540 Times
Anyway, if your only experience with mechs is with crap models, you are not really getting a very good representation (Thus I did not include my experience with my Hayes Hydros from 2002). I was comparing BB7s to XT's hydros. In my head, mechanical always meant BB7. Those have been the standard for years. IMO, nothing else mechanical was really worth considering until a few years ago when TRP and Paul came out with some good ones.
BB5s? Ouch. Yeah, no wonder you hated mechanical.
"Stuff breaks".... true, and your your truck crapping out in the middle of nowhere is exactly why you avoid using parts more likely to fail on the road.
#59
Advanced Slacker
Liked 2,540 Times
#60
Liked 298 Times
I said in reply to tim24k
to actually address your questions.
1. I asked the question out of curiosity. Nothing more, nothing less.
2. "stuff breaks" was an after thought.
#61
Tragically Ignorant
Liked 9,099 Times
False. I did NOT ask if 'anyone' had hydraulics brakes break in the middle of nowhere.)
If your mechanic aptitude is on par with reading aptitude, I am not so sure that I would lay the blame onto hydraulic brakes. More likely it was the mechanic of said hydraulic brakes.
Amazing how every conversation with you ends up in you denigrating the person disagreeing with you. The reading comprehension was fine, and there's no basis for calling the guy a bad mechanic other than your usual nastiness.
#63
Advanced Slacker
Liked 2,540 Times
Because when YOU have issues setting up your BB5s, it is the fault of mechanical brakes. When someone ELSE has issues with hydros, it is their lack of mechanical aptitude causing seals to leak.
That all makes perfect sense
#65
Advanced Slacker
Liked 2,540 Times
#66
Rhapsodic Laviathan
Yes, but steel is also an alloy (most basic steel is iron + carbon, other metals are added to achieve desired characteristics; for example, CroMo steel has chromium and molibdenum in the mix as the name suggests) , and all titanium frames ar also made from titanium alloys (typically aluminum and vanadium).
So all metal-based bike parts are actually alloys. Pure metals are mostly too soft or too brittle.
#67
Liked 4,278 Times
subgrade’s point is valid. Alloys are made of several elements mixed together in a solid solution. Steel just happens to be made of iron and other stuff while aluminum alloy is aluminum and other stuff. “Alloys” may be considered by the public to be non-ferrous but the “public” is often wrong.
Stuart Black
Stuart Black
#68
Tragically Ignorant
Liked 9,099 Times
The guy you're arguing with will likely call you some variation of "fat" within two posts, somehow connecting the fact that you eat food to your brake "issues."
#69
Tragically Ignorant
Liked 9,099 Times
No one I know refers to bronze hardware as "alloy", and that's non-ferrous. Orchestras have brass sections, not alloy sections. Again, non-ferrous. I think people are trying to invent a general rule for why aluminum alloys are called this, and I think the answer is a lot simpler. For marketing reasons, it's better to note that it isn't pure aluminum because it's a fairly soft metal if it's not part of an alloy, aluminum alloys don't have short, well-known names, and "aluminum alloy" is a mouthful .
#70
Disco Infiltrator
Quoted: 3132 Post(s)
Liked 2,114 Times
Well this is a fun thread. Perhaps you should call it hydra?
Genesis 49:16-17
Genesis 49:16-17
#71
Tragically Ignorant
Liked 9,099 Times
#72
OP - I am just confused to why people shorten it to 'Hydro'. The o makes it pertain to water?
why not just shorten hydraulics to 'HYDR' ?
Why did you shorten your thread title to "Hydraulics" instead of something like
why do people shorten Hydraulics to 'Hydro' ?
It would save many people from clicking into such a mindless thread.
#73
Tragically Ignorant
Liked 9,099 Times
#74
Quoted: 22 Post(s)
Liked 17 Times
Because the 'alloy' of iron and carbon is known as "steel", or carbon steel.
when we start adding other elements it becomes known as alloy steel. Which is typically called by name. chromoly, stainless, Reynolds, etc....
Universal language, walk into any American car dealership and ask for car with alloy wheels, and it will be aluminum wheels. (unless they ride bicycles, then who knows what you'll get!! )
which is why I asked about hydraulics being called "Hydro" here. Hydraulic isn't typically referred to as hydro outside of the bicycle consumerism.
Cheers, MAC
#75
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,542 Times
Enlightening thread...
...this was a good convo.
