Speed for Overweight Person
Likes For Aladin:
Likes For BlazingPedals:
Likes For thehammerdog:
Quoted: 523 Post(s)
Liked 231 Times
Choose a bike with wider width rims on the wheels over one that has narrower rims. In general, bikes with narrow rim wheels and higher pressure tires are going to be faster than ones with wider tires and lower pressures for the same amount of effort put into pedaling. If you are careful how you ride and avoid potholes and jumping curbs that will help avoiding damaging the rims no matter what wheels are on the bike. I once rode my Greenspeed trike off a 10" drop onto cement going about 12 mph and didn't damage the wheels but they were very strong 20" Velocity Aeroheat rims with 32 spokes. The same drop on my current trike with the same model rim but with a 700C X 23 tire would not have the same outcome.
Cycling is a great way to lose weight if you combine it with monitoring your caloric intake. I've been an active rider for years but never lost any weight, just crept up a little at a time over the years. During this epidemic I decided to lose weight and went from the upper end of being overweight for my age, height, and activity level to being at the lower end of normal weight. No special diet that would put my body chemistry out of wack but just eating less, never eating anything between meals, and riding my trike more. I lost 33 pounds (15kg) in 3 months. Keeping a calorie intake log keeps me honest when it comes to how much I eat versus what I need to maintain my current weight.
Likes For VegasTriker:
Bikes: 2000 Litespeed Appalachian, 1998 Litespeed BlueRidge.. 1977? Schwinn LeTour 12.2 'Rain Daze'
Quoted: 64 Post(s)
Liked 17 Times
Wider rubber... find psi that gives the desired ride. Spend some coins on the rubber. The wide rim **** is just that.
INSULIN .. makes one fat. Eat so the body makes LESS...........
Last edited by cb400bill; 07-19-20 at 05:52 AM. Reason: Do not change the spelling of words to bypass the forum censor
Likes For Aladin:
Bikes: S-Works Stumpjumper HT Disc, Fuji Absolute, Kona Jake the Snake, '85 Cannondale SR900
Quoted: 219 Post(s)
Liked 217 Times
Ditto. Steel or quality aluminum, like an old Cannondale. You’ll be fine at that weight. I am
Just keep moving, each day. Things will get better & you’ll enjoy it.
Likes For Charliekeet:
Quoted: 17 Post(s)
Yes, it was a wonderful experience. I did Kili too but only lasted 4 days as I hurt my neck and back. It wasn't wonderful as it pissed down for 4 days constant. Coming down from EBC on the double day walks was pretty easy.
Quoted: 64 Post(s)
Liked 17 Times
I trekked up to Everest Base Camp two years ago at 115 kg and yes, the going up was an absolute killer so I appreciate cycling an incline the same.
So you are saying that bikes with lots of spokes are stronger? Makes sense.
I'm going to try and lose another 10 kg then buy a bike. On average if I can do 15 km/h on the exercise bike, is that a good target or should it be nearer 20 km/h?
My friend is planning to cycle across India next year and says 5 hours per day at 15 km/h is a slow pace. Seems fast to me? I need to get to that level probably this year.
Oooops----> see India.. heat.. humidity. Sounds like his plan is solid.. NOT to wear one's self down. With Covid myself I'd pick a less populated country.
Quoted: 17 Post(s)
Not sure what other countries we'd like that are cheap, interesting and have warm weather. Also the route we picked is mainly downhill as I will struggle in mountain ranges. I was recommended a really good blog CrazyGuyonaBike and he does Dehli to Goa and while he does some 185km days, we wouldn't.
