ISO and for trade thread part 5
#5026
I knew I had one of those sets of shifters.
The bolt and nut you need are these:
But they're mine, and you can't have them. You CAN, however, have this copy of the nut in brass for use with a suitable screw:
(Some stuff is quick and easy if you have a lathe.)
So pm me a physical address and I'll stick it in the post.
Gotta ask - the nut you fabricated looks to be virtually the same color as the chromed original. White brass?
#5027
Quoted: 2367 Post(s)
Liked 1,756 Times
^^^^^^ Hmm, looks very brass-colored to me (shrug).....
#5028
Hmm, you could be right. I was looking at the machined flats, which look to me (on my screen) to be nearly the same color as chrome. But looking closer, the round "head" end of the nut seems more brass-colored. The flats may just be "washed out" by excess light and showing a false, lighter shade.
It's always hard to tell exact colors on a computer screen unless both the sender and receiver of the image are using calibrated equipment.
#5030
Quoted: 1112 Post(s)
Liked 1,335 Times
Want single-sided (5-speed) Simplex delrin cable guide
I want a single-sided one of these:
Because after the plastic bits come off, it has two studs - both like the left one here.
With some silver-solder on the backside to make sure it stays put, and a few minutes on a lathe for the front side, the stud looks like the one on the right:
Which is now the right size and shape to mount one of those nice Simplex front mechs that otherwise need the special braze-on:
And this picture shows why I want a single, even if the other stud is removed entirely there'll still be an ugly boss remnant there:
#5031
Quoted: 51 Post(s)
Liked 141 Times
Wtt
Hello. Anyone interested in NOS Mavic GP4 tubular rims, 32 hole, an old rusted campagnolo clamp on front derailleur, and a NOS red benotto bar tape? For a clincher wheelset, 100 front, 126 rear, 700c. Thanks. Much appreciated.
#5032
Death fork? Naaaah!!
ISO Park Tool PMP-5 frame punp.
Left mine on the bed cover of my pick-up and drove off
A quick lap around the internet shows them to be discontinued and unavailable from anywhere.
Top
Top
#5033
Mother Nature's Son
Quoted: 854 Post(s)
Liked 1,447 Times
mistake
#5034
tantum vehi
Quoted: 1168 Post(s)
Liked 993 Times
I may have one, but can’t remember if it has a guide on the NDS. I’ll check when I get home.
1970 Gitane TdF; 1973 Gitane TdF
1979 Trek 710; 1981 Trek 412; 1981 Trek 710
1984 Specialized Stumpjumper Sport; 1985 Specialized Allez SE; 1988 Specialized Sirrus; 1989 Specialized Rock Combo
1984 Ross Mt. Hood
1988 Centurion Ironman Expert
1991 Bridgestone RB-1
1992 Serotta Colorado TG
2015 Elephant NFE
1984 Ross Mt. Hood
2015 Elephant NFE
#5035
Liked 1,335 Times
I bent the clamp so the free end bolt hole and the threaded boss were aligned, the qr centre stub went through free-end bolt hole (so it wouldn't go flying about), then put a small nut to lock against the threaded boss when it went on the stub.
Light cuts after that.
Likes For oneclick:
#5036
Tall guy shout out - 40° Stem, high riser bars
Looking for a 50mm+ Riser Bar (~700mm wide) and about a 110-130mm Stem in both a 31.8mm. Pictures are for example. I'll use as many such stems as these as possible - it's the bane of height. I have some 6 speed Suntour 3000 Shifters, front and rear derailleur for trade, working pulls from my own Kuwahara Sage.
https://www.starbike.com/en/procraft-sl-40-stem/
https://ridetigercraft.com/aura-alloy-50mm-riser-bars/
https://i5.walmartimages.com/asr/3dc...0&odnBg=ffffff
#5037
tantum vehi
Liked 993 Times
I silver-soldered it in place first; drilled and tapped the centre of the boss, then took the centre part of a quick-release ( a nice straight one) and mounted that in the lathe with a stub of the threaded end sticking out.
Sadly, my demultiplicateur is double sided too. But if anyone needs one…
1984 Ross Mt. Hood
2015 Elephant NFE
1984 Ross Mt. Hood
2015 Elephant NFE
#5038
Those hoods would be really neat to replace my worn out ones on my faithfull Cannondale CAAD4.
Do you sell these hoods and if so what would be your price?
Cheers
Cheers
#5039
Bikes: '38 Schwinn New World, ’69 Peugeot PX-10, '72 Peugeot PX-10, ‘7? Valgan, '78 Raleigh Comp GS, ’79 Holdsworth Pro, ’80 Peugeot TH-8 tandem, '87 Trek 400T, ‘7? Raleigh Sports, ‘7? Raleigh Superbe, ‘6? Hercules
Quoted: 765 Post(s)
Liked 1,604 Times
If nothing comes up here, try eBay.fr
Here's one (I think).....
With the current $/€ exchange it's pretty cheap. I've had pretty good experiences getting stuff from France lately.
#5040
Liked 1,335 Times
I thunk about it first.
I knew it had to be threaded before it went in the lathe (so as to mount it on a threaded mandrel). I didn't want the riveted end spinning in the hole when it was drilled and tapped, so it had to be soldered before that.
After it was figured out it only took about 20 minutes.
#5041
Quoted: 887 Post(s)
Liked 335 Times
#5042
Shimano stem shifter wanted
I’m poking for a Shimano stem shifter like these. Thanks
#5044
Liked 1,756 Times
^^^^^ Fah, I was just at my local co-op a few hours ago. Closed for the weekend, alas.
#5045
Thanks. I really like the sleek looks of this particular one.
#5046
Stop reading my posts!
Quoted: 1453 Post(s)
Liked 1,074 Times
I do believe I have a pair cause I am a fan of these "micro-ratcheting" shifters, both the stem and the DT mounts.
So let me poke thru my bins and PM me in a day or so.
#5048
Hello Dweenk, tnxs for the response. I definetely need the bar width (lock-on grips, seperate shifters/levers plus bar ends). 640 is going to be too narrow.
#5049
Quoted: 887 Post(s)
Liked 335 Times
I didn't notice that you were in Winnipeg. Shipping alone would have been too expensive for a trade. It puzzles why the US and Canada can't have nearly seamless low-cost parcel service.
