Chain Length calculation?
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
The B screw adjustment? Seriously? That has absolutely nothing to do with sizing a chain. It almost sounds like you don't know what the B adjustment screw is for. And of course the cassette has to be within the limits of the derailleur capacity. Duh.
Feel free to argue with Shimano if you must:
RD-7700
God, for some reason you guys make sizing a chain the most complicated thing about bikes.
RD-7700
When using a drivetrain specced as compatible by the manufacturer I agree; do as the manufacturer says. When using unspecced mixes then some other guidelines are needed (big-big seems the foundation of these). I've a drivetrain with components from Shimano, SunTour, Campag, KMC, Stronglight and Simplex. The Shimano RD-M953 is (I think) specced with a wrap of 42 and max sprocket of 34. With larger jockey wheels, reversed and lengthened B-screw and the chain just the right length this is pushable to a wrap of 53 and max sprocket of 40 (no drop-link).
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1963 Post(s)
Liked 1,483 Times
B screw adjusts the distance between the guide (i.e., top) pulley and the cassette. Depending on the chain tension, it also affects the aforementioned angle between the ground and the line between the two RD pulleys.
And if the cassette is not within the official specifications of the RD (e.g., GS model with a 12-25 cassette) but still shifts fine, it may not be possible to have the two RD pulleys perfectly vertical.
Quoted: 3525 Post(s)
Liked 2,935 Times
I only specifically referenced the Dura Ace 7700 drivetrain. Of course, this same setup was the same for all my Shimano road bike drivetrains going back to 1986.
Liked 1,483 Times
My delay in responding to this post is because I wanted to be absolutely sure about this before I called out BS, so I had to wait until I got home before working on my bike. Now that I've done so, and run the B adjustment screw--all 11 mm of it--all the way in and all the way out, with my chain on the big ring and smallest cog, I can safely say, and without reservation, BS! Moving the screw those miniscule 11 mm one way or the other does not move the derailleur cage at all off the vertical.
But please feel free to insist that the B screw does not affect the angle of the derailleur cage under any circumstances whatsoever.
Liked 2,935 Times
What’s your specific derailleur model number? I want to look up the manual.
Liked 1,483 Times
I am familiar with the diagram you are referring to, which is on page 8, right column "Assemble with sprocket max 27T or less".
With a 12-25 cassette, I have the B screw all the way out, to minimize the gap between the guide pulley and the big cog.
Liked 2,935 Times
I have a Shimano RD-5800-GS. This is the dealer manual: DM-RD0003-09-ENG.pdf (shimano.com)
I run my B screw all the way out too.
Liked 1,483 Times
Liked 2,935 Times
No, a RD-5800-GS has a minimum large cog size of 28T. RD-5800-GS (shimano.com). But I am using a 12-25 cassette, forcing me to have the B screw all the way out. I can get the two RD pulleys pretty close to vertical but not perfectly vertical. It shifts fine so I am OK with that. Next year, before I replace the RD cable, I am also installing a RD-6800-SS and a 11-28 cassette, so maybe then I can get the two RD pulleys perfectly vertical then.
Well, the manual you linked to, for a 2x, on page 8, specifies “Max 27T or less.”
Liked 1,483 Times
A 2X drivetrain with a "sprocket max 27T or less" should use a RD-5800-SS according to Shimano specifications: RD-5800-SS (shimano.com).
Bikes: lots
Liked 2,932 Times
Liked 2,935 Times
Bikes: lots
Liked 2,932 Times
Here's one, it's not even a manual, just a product description:
Low sprocket_Max. 28T Low sprocket_Min. 23T
Or this, from the contents of the 5800 etc derailleur dealers manual:Chain length.. Assemble with sprocket max 27T or less ... Assemble with sprocket max 28T or more
Or page 8 of this, the actual manual:
Derailleur installation: Chain length
That enough?
That enough?
Liked 2,935 Times
Or this, from the contents of the 5800 etc derailleur dealers manual:Chain length.. „ Assemble with sprocket max 27T or less ... „ Assemble with sprocket max 28T or more
That enough?
That enough?
Quoted: 6221 Post(s)
Liked 4,828 Times
or For front triple, assemble with sprocket max 30T or less
or even page 10 For front triple, assemble with sprocket
max 32T or more
Though to be honest, I have no idea what you are even disputing.
Bikes: lots
Liked 2,932 Times
Liked 2,935 Times
Bikes: lots
Liked 2,932 Times
You are obviously trolling this thread. You can't be this thick. Examples...again. Assemble with sprocket max 27T or less (This is the one that's big/small w/ the cage vertical)
Assemble with sprocket max 28T or more (This is the one where you size big/big not through the derailleur and add links) Obviously it means the smallest big cog you can use is a 28t. These last 2 examples are for a double.
For a triple:
For front triple, assemble with sprocket max 30T or less OR
For front triple, assemble with sprocket max 32T or more
From the new 105 product description:
Low sprocket max 36t (pay attention now, this is the part you refuse to acknowledge)
Low sprocket min 34t (understand?)
Remember in post #35 you asked: Minimum large cog?? There’s such a thing?
All of this is in answer to that question.
For a triple:
