Do higher end rotors brake better?
Quoted: 827 Post(s)
Liked 1,968 Times
New bike upgrades?
Sounds like you did not purchase the bike you wanted.
Why not put about 20K miles on it then change out consumables when they are worn?
His comment SHOULD help. He's telling you, you are worrying about stuff that isn't a problem yet, and may never be. Are you an ultra-clyde, going down long and steep descents? On a tandem? I think you're probably worrying about nothing and you should save your money for when you discover an actual problem.
You are looking to upgrade something that probably doesn't need upgrading. Ride the new bike and see if you have any braking issues that require an upgrade. I doubt you will as stock 105 brakes are pretty solid. If you find that you are cooking the rotors and the pads are fading badly on your descents, that's the time to start looking at upgrade options. At least wear them out first!
I guess I didn't quite explain that I love to descend at high speeds and I do so very often so I wanted something better from the get-go if 105 wasn't good enough. I only asked if 105 wasn't good but people got mad lol. If 105 is good enough than I'm absolutely fine with it, but I wasn't clear about that I guess.
I should further add that I live in a very, very high traffic area and therefore I have to ride early in the morning because later in the day it's happened plenty of times where I have had to hit the brakes hard to avoid getting it by a car since there's so many cars in the road. Not ideal for high speed descends I guess but it's the way things are.
Anyway I repeat, I appreciate everyone's help.
Likes For Jon_g2:
Resident PIA
Bikes: Gunnar Roadie, Look 765 Optimum, Spesh Aethos
Quoted: 222 Post(s)
Liked 364 Times
Not a fan of Ice Techs, just saying.
Shad
I knew where I was when I wrote this
I don't know where I am now...
05 Gunnar Roadie Chorus/Record
67'er
Shad
67'er
Resident PIA
Quoted: 222 Post(s)
Liked 364 Times
Shad
67'er
Shad
67'er
Likes For Shadco:
Quoted: 1425 Post(s)
Liked 1,946 Times
I believe the RT70 rotor is an Ice Tech rotor - but might be mistaken
if so - that is a good rotor and will accept many types of pads and the construction (aluminum sandwiched between steel) is said to dissipate heat better
I believe the CL800 rotor is an Ice Tech Freeza rotor - also a good rotor with similar construction and with a slight upgrade over the standard Ice Tech rotor
I have Ice Tech rotors on three Shimano disc brake bikes - they work very well … they replaced Shimano low end rotors
If I rode at higher speeds I would have been tempted to go with Ice Tech Freeza rotors
There is nothing wrong with your inquiry on the braking system of your bike - regardless if you’ve never ridden the bike or if you‘ve logged 5K miles
Likes For t2p:
And yes, I never meant to sound like these rotors I have don't work or. I do believe in trying stuff out before replacing but I did mention that if the RT70s weren't good enough for steep descends I'd rather not have to find that out during a ride. I believe my braking technique is pretty good too. On top of that, it's my first brand new bike and I don't plan on buying another road bike for many years to come so I want to upgrade it where needed.
Quoted: 2350 Post(s)
Liked 2,862 Times
105 is far from bottom end for shimano
Likes For squirtdad:
Method to My Madness
Quoted: 2005 Post(s)
Liked 1,511 Times
I was told higher end rotors dissipate heat better is this true? I guess my real question would be if ultegra is better than 105 which is what I would be upgrading to. If I'm not mistaking there isn't necessarily a "105" or "ultegra" rotor but I do have part numbers written down. I would be going from SLX-RT70 to CL800.
... to (Ultegra) RT-CL800: SHIMANO CENTER LOCK Disc Brake Rotor ICE TECHNOLOGIES FREEZA 203/180/160/140 mm | SHIMANO BIKE-US
Yes, the cooling fins on the latter do help heat dissipation from the disc, although (as others above have suggested) heat dissipation from the pads may play a bigger role to reduce brake fade.
But it seems that most Ultegra (and GRX) bikes are now equipped with (XT) RT-MT800: SHIMANO CENTER LOCK Disc Brake Rotor ICE TECHNOLOGIES FREEZA 203/180/160/140 mm | SHIMANO BIKE-EU
Likes For SoSmellyAir:
You are going from (105 or SLX) SM-RT70: SHIMANO CENTER LOCK Disc Brake Rotor ICE TECHNOLOGIES 203/180/160/140 mm | SHIMANO BIKE-EU
Clark W. Griswold
Quoted: 4426 Post(s)
Liked 4,072 Times
Good rotors and pads make a big difference in braking but brand new equipment that you haven't ridden should be ridden for a bit before you start making changes like that. The only thing I would probably change on a brand new bike is pedals but a road bike shouldn't come with pedals in fact really no bikes from a shop come with pedals anything on it is just a test ride pedal. Maybe saddle if there is one I know that works super well.
On a flat bar bike I would replace grips if they aren't Ergon but beyond that I would ride the bike first always. Though I build my bikes from the frame up so I never really have these problems so I put the components I want or at least the components I want within my price range. If I got everything I want it would be Sturdy Cycles and Firefly with Di2 or Rohloff and a ton of really high end ti components and such. So I have to be semi reasonable.
Likes For veganbikes:
Liked 3,022 Times
from the random brands i've tried with rotors & pads, I've noticed poor stopping performance & usually they'll squeal with the slightest splash of muck water. More noticeable when using resin pads. I prefer the metallic pads, even though they'll wear faster & lunch the rotor faster. Affordable metallic pads have been harder to find lately too.
-Oh Hey!
-Oh Hey!
Likes For Troul:
Well, I'm not exactly typical. My lowracers both have one disc in front and a caliper in back. Air resistance to help with braking is basically non-existent. Put me on a straight downhill and nothing short of a tandem team with a 70-tooth chainring can touch me. My home range is pretty flat, but I've had both lowracers in the mountains of Tennessee, with 8-12% grades and hairpins. What rotors do I use? Right now this one has a little sawtooth one that weighs 85g. The other one has just an OEM one from Avid. Unless you're running heavily loaded down big twisty hills, I think agonizing over whether Ultegra brakes better than 105 is kind of funny. But it's your money.
Likes For BlazingPedals:
Likes For Jon_g2:
Quoted: 587 Post(s)
Liked 673 Times
The proper answer is: "kinda"
Here's the problem:
Is there a standardized heat dissipation rating?
Probably not.
And like all engineering, what is the compromise?
Is it "high end" because of the name? model number? material? shape?
Now add the other components: Calipers, pads, actuators, and levers.
So probably, yes, higher end rotors might dissipate heat better.
Now the question is: will you notice?
If heat dissipation is a primary concern, then I suggest a larger rotor.
More surface area = better heat dissipation.
Consider a system designed for cargo bikes or tandems.
Remember: in the world of engineering, ALL cycling components are low end.
Here's the problem:
Probably not.
Likes For CrimsonEclipse:
Thanks for the information.
There have been times when I have upgraded my bicycle components to the best available before trying, but it was never due to a concern that 105 or ultega will not stop my bicycle compared to DA set of brakes. On one of my steel bikes, I still have 105 brakes and they work perfectly well, as they are designed to do.
Sounds like a reasonable plan… so why not determine if an upgrade is really needed. Try a lower grade hill first and see how it feels and work from there to steeper grades.
aged to perfection
Quoted: 851 Post(s)
Liked 1,278 Times
to better dissipate heat, use finned pads perhaps ? that's where the heat build up is
rotors have lots of air passing over them
I like a "center lock" front hub over ISO. feels much more solid.
/markp
/markp
Likes For mpetry912:
Yeah I guess I just like to swap out the things that don't work from the get-go. Or not necessarily that they don't work well, but that may not last very long because they're not of good quality like it happens many times because manufacturers want to save a few pennies. So my reasoning is that if things could be changed for not a whole lot of money, and on top of that you can sell the removed parts then why not do so? But you guys all post very valid points. I came onto this forum to learn and I'm definitely getting an earful from some people but I'm sure most mean well lol
Various people have different style of interacting with each other but to be candid, in this thread I’ve not encountered any post I would consider offensive.
Enjoy your new bike, use it and don’t overthink.
[If you are really terribly keen about heat dissipation from rotors, as a few participants already suggested, use larger rotors.
If that isn’t possible, there’s always the DA rotors with Al layer shaped to dissipate more heat, specially at faster speed. All else inadequate, find someone to custom design rotors for you where instead of Al, a Cu layer is used - with better coefficient of thermal conductivity (a bit heavier though).
Here’s another option, use a wheel set that can use rim as well as disc brakes - combine the two together - it’s quite doable! ]
Likes For Alan K:
Quoted: 4492 Post(s)
Liked 4,964 Times
Likes For PeteHski:
Likes For ofajen:
I use Jagwire rotors on my road bike and cheapo no-name brand rotors on my gravel/commuter bike, and honestly I don't notice any really performance difference between them.
The Jagwire rotors look better, though. 😂
