Totally Tubular
#1126
If I own it, I ride it
Quoted: 593 Post(s)
Liked 664 Times
I am guessing a newer formula as I have not used Tubasti in 20 years.
#1127
Quoted: 140 Post(s)
Liked 13 Times
I get Crown Camp Fuel for gasoline lanterns at Walmart - for about half the price of coleman fuel.
#1129
Quoted: 140 Post(s)
Liked 13 Times
Thin and wet doesn't sound right. maybe separated? The stuff I've used is a bit thick - and you can spread a pretty thick layer, definitely not runny.
#1130
I used it once and rolled a tire, which soured me on it permanently. I only ever happened to me that one time. Given that I was 15 and not an experienced mechanic, improper application was at least partly to blame.
In retrospect, I think I'd put at least 3 coats on a new rim, maybe 4, and let the first two dry before the final sticky coat. Also put a coat on the tire. Let dry for longer than it says to on the tube. I'd physically test it by pulling on the tire to see how stuck it is.
#1131
FWIW this was considered by many people to be the tourist glue, at least by the racing set. It stays sticky, so it's convenient if you get a flat. Still, I knew some good racers who preferred it. It is a lot thinner than Clement red was.
My bikes: 1970`s Roberts - 1981 Miyata 912 - 1980`s Ocshner (Chrome) - 1987 Schwinn Circuit - 1987 Schwinn Prologue - 1992 Schwinn Crosspoint - 1999 Schwinn Circuit - 2014 Cannondale Super Six EVO
#1132
Quoted: 2376 Post(s)
Liked 2,904 Times
Got to keep this thread going
OK as usual for me, I get a great bike cheap or free and then obsess over the build (in this case I was justified because the crankset was to small for me )
It is a an '84 team miyata and I am trying to bring it back to close to it's original appearance if not specs
In this case original means gum wall tubular.
I probably should bite the bullet. be done with it, etc and get the Corsa G+, but this is not my prime rider and I want to save some bucks.....
I would like to put a a little (or lot) less expensive tire on it.
Would prefer to have a removable valve core for sealant
or can sealant be forced in through a non-removable valve core? or just not bother and as they are cheap just get extra tires?
Any way the usual suspects at the low end with gumwall seem to be
Vittoria Rally
Continental Giro
Yellow Jacket 3 for 50
Thoughts, experience, invective?
thanks
Vittoria Rally
Continental Giro
thanks
#1133
I never finish anyth
Bikes: 2008 Merckx LXM, 2003 Giant XTC mtb, 2001 Lemond Alpe d'Huez, 1997 Lemond Zurich, 1989 Cannondale ST, 1988 Masi Nuovo Strada, 1983 Pinarello Turismo
Quoted: 294 Post(s)
Liked 137 Times
YJ tubulars 3 for $50 have been surprisingly good. Mount straight, no lumps. Not as good a ride as the pricier tubs (like the Corsa G+) but for the price, hard to beat.
UPDATE: the YJ tubs are 23mm
Dale, NL4T
Dale, NL4T
#1134
Quoted: 1842 Post(s)
Liked 3,453 Times
I've used the Conti Giro and the Yellow Jersey sew-ups, and they've been functional. The Giro is probably a better tire, though.
Currently, I've got a Yellow Jersey tire as my spare.
Are the Conti Giro's still gumwall? I'm using the Sprinter on one bike, and it's progressed from dark brown sidewall (previous generation) to black sidewall. Too modern looking for my tastes.
Steve in Peoria
Steve in Peoria
#1135
Quoted: 1858 Post(s)
Liked 606 Times
Vittoria Rally
Continental Giro
thanks
Vittoria Rally
Continental Giro
thanks
I have tried the Vittoria Rally and the Continental Giro and was less than impressed/
#1136
Quoted: 1361 Post(s)
Liked 425 Times
Vittoria Rally
Continental Giro
thanks
Vittoria Rally
Continental Giro
thanks
Panaracer Practice 270 black/tan. Three for $90 should be the ballpark retail discount.
I've been getting them for less through a LBS (wholesale and when they place large restock orders)
Also consider Tufo S33 pro when on sale. Seem as if they were machined on a lathe. Butyl tube.
#1137
Bikes: many
Quoted: 1461 Post(s)
Liked 1,422 Times
Kinda hard to beat tubulars at $0.06 a pair. Even if I have to fill them to the gills with Orange Seal. That's me, your friendly neighborhood bottom feeder.
https://www.ebay.com/itm/173622247985
#1138
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4369 Post(s)
Liked 3,031 Times
The YJ tires do have a vintage kind of look to them - they're narrow and intended for high pressure and ride hard... but I remember thinking that was cool in 1984.
And IME, they fail less than V or C brand cheapies.
#1139
Quoted: 1652 Post(s)
Liked 852 Times
Cheapies are good to just start with and get used to mounting tubs on rims and have an idea what the difference in ride is between most clinchers and tubs. But after graduating to higher quality tubs, I now just relegate my Rallys and Giros to spare tire duties, just to get me through a ride after a flat. The whole point of tubular tires is to get the best ride, and the cheapies just don't provide enough of an improvement over clinchers to make them worth it in the long run.
#1140
Liked 2,904 Times
well I pulled the trigger.....trying the Challenge Elite Pro 25mm/removable core/black and tan at $28.99 from probike will report out
meanwhile I have a set of corsa g+ clinchers to installs
damn this addiction
damn this addiction
#1141
Bikes: 75 Raleigh Gran Sport, 88 Bridgestone RB3, 72 Raleigh Super Course, 75 Jeunet 620, 95 Fuji Team
Quoted: 80 Post(s)
Liked 21 Times
I'd like to hear to how the Elite Pro's work out for you. I'll be building my first set of tubular wheels shortly, and this is the tire I'm leaning towards starting with. Either the Challenge Elite Pro or the Tufo S33 Pro.
#1142
What??? Only 2 wheels?
Quoted: 1223 Post(s)
Liked 645 Times
That's how I read the riddle too. When I first considered tubulars the BF member who got me started rode cheapies but admitted they could be better. (One blew out on a ride we were on. Bang!!) Some other BF member once posted that life is too short to ride cheap tubulars. I've subscribed to that philosophy ever since. I wouldn't know what cheap tubulars are like but I doooo like the ride of good ones. My preference has been 23mm Veloflex Criteriums. High-end clinchers like the Veloflex Master can be quite tubular-like but still aren't the same.
Real cyclists use toe clips.
jimmuller
jimmuller
#1143
Liked 2,904 Times
One thing I don't get is the seeming binary aspect of tubies......ether high end and great or low end and adequate (or worse) from the same manufacturer. Seem like the should be some middle ground......
#1144
Quoted: 1618 Post(s)
Liked 2,234 Times
@squirtdad - I agree but..... Look at the thread count to begin with. Higher thread count => ride quality. Then add the additional construction features of multiple layers. The gap is often bridged with sales on the lower middle tires.
#1145
Bikes: many
Liked 1,422 Times
I suspect quality was more continuous BITD when more people rode sew--ups and there were relatively few (no?) good clinchers.
#1146
I just ordered my first nice tubulars - Veloflex Criteriums. Probikekit.com had the best prices I found anywhere. The Veloflex were $60.99 each shipped. The Vittoria Corsa G+ are $58.49. My LBS couldn't order them from their distributor. Other places online were in $80-$90 each.
#1147
It's MY mountain
Liked 3,031 Times
There's more to it than that. I did an event in January that had a good LBS as support and I asked them to check out my bike because I was getting some brake rub around the switchbacks. He told my my rims were shot and I needed new wheels... he was right. He told me he sells a lot of tubeless wheels that would give the same sweet quality ride as the tubulars I had on...but it is not just about the ride quality. There's a whole tubular experience that I enjoy. Built up my own new wheels a couple weeks later and I love them.
#1148
Quoted: 1968 Post(s)
Liked 2,064 Times
Another "whole point of tubulars" is fewer pinch flats at reasonably low pressures and the added security of the tire remaining on the rim after a puncture.
#1149
Quoted: 378 Post(s)
Liked 1,413 Times
Maybe off-topic, but definitely refers to the market. Used tubulars are often a great buy.
Add in the sell-off of a lot of 8/9/10-speed wheelsets because they can't run 11-sp cassettes. (Except for many Mavics, for which used prices are increasing)
Add in that you can get an 11-sp cassette (11-32/34 only) that will run on 8/9/10 hubs.
Equaling some great deals on 8/9/10 tubular wheelsets that can be made to run 7-11 speeds.
I was looking on CL for just such things. Found some 10-sp Mavic SSL tubulars, and yep, they are about double what they were 3 years ago. Found some 10-sp Zipps and they were about half. Bought the Zipps, and the "tubular tired" seller threw in 2 pair of new carbon brake pads, 4 new tubular tires, all his valve extenders, tubular tape, sealant, etc.
The tubular market in used wheels is very, very nice to play in, and tires often come with 'em.
#1150
Bikes: many
Liked 1,422 Times
I love that you sometimes see 8-9-10-speed stuff on eBay in the vintage bike parts category. So not completely off-topic, Rob.
