How to wash my bike with wash gun?
climber has-been
Quoted: 3447 Post(s)
Liked 3,590 Times
It's bicycle lore, where the standard engineering practices don't apply.
https://youtu.be/M2DdRibD6kY
Is that normal after I wash bike with low pressure water gun,but I don't wash hard bearings or not wash it .
Likes For cycling2012:
Quoted: 18439 Post(s)
Liked 15,617 Times
And the award for the largest photos goes to....
Likes For indyfabz:
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Mechanics are not engineers, and they often do stupid things. Tell an engineer that you’re going to fire high pressure water near bearings, the engineer will advise against it in no uncertain terms.
Pro team bicycle mechanics are equally untrained in engineering and tribology, and they are just as susceptible to picking up stupid tricks, passed down from older mechanics who swear they’ve been “doing it for years with no problems”. I wouldn’t trust any mechanic with a high pressure wand, even the “pro team” ones who claim they are “smart” about how they wield it.
Spraying high pressure water anywhere near bearings is risky. Such practice isn’t allowed in any industry that I can think of. Except bicycles, of course, where myth and lore survive.
climber has-been
Liked 3,590 Times
FWIW, I was doing mechanic work after school and on the weekends in my dad's bike shop before I was able to ride a bicycle. I continued to work there through college.
I was educated in Mechanical Engineering (BSc, MSc), with most of my professional experience on spacecraft designs.
I worked on the support systems of this one, before it had a name:
Recently, one of my Hubble units was on display at the National Air and Space Museum:
Hubble Space Telescope Power Control Unit (PCU) - astronaut trainer unit
This unit got replaced on the third Hubble servicing mission, in 2002. Since it was the power control for the whole spacecraft, Hubble had to be fully powered down to permit replacement.
I had my hand in many other spacecraft designs, but most of them were proprietary.
I hope that satisfies your curiosity.
Likes For terrymorse:
Quoted: 741 Post(s)
Liked 412 Times
I live in a city where every other person is an engineer of some sort. I have heard engineers say a lot of things that just were plain wrong. They always justify their position by saying, “I am an engineer at Boeing.” I played in an orchestra with tuba player who was a Boeing engineer. He spent 20 minutes explaining his reasoning for keeping a chromatic tuner attached to his horn. Problem was he didn't account for the fact that pitch rises in orchestras and so was always out of tune. Drove me crazy playing with him.
Likes For colnago62:
Bikes: lots
Liked 2,932 Times
Incorrect on both counts, but why does that matter to you? I don't like to go on about my qualifications, as that falls towards an "appeal to authority".
Hand my hand in many other spacecraft designs, but most of them were proprietary.
climber has-been
Liked 3,590 Times
Very cool. But...it doesn't mean you know any more about bicycles and how to clean them properly than I do. There are tons of shop mechanics that don't understand how nor believe it's possible to clean a bike with a bunch of soap and pressurized water. I have done it for years and as others have said it's pretty easy to avoid ruining things. Just because you can't wrap your head around doesn't mean it's a bad idea. I can't even begin to fathom how to design and build a space telescope but that doesn't mean I'm gonna tell you it'll never work because you've done it. You just have to understand that lots of things are possible even if your highly educated and trained self don't think they are.
If a technology relies on the skill and caution of the operator, or acquired methods passed down from one mechanic to another, it will eventually produce failures.
Some mechanics can get by without using a torque wrench. It's still a bad idea.
Bikes: lots
Liked 2,932 Times
I never wrote that power washing wouldn't work. I wrote that it was risky, which is why I banned its use (and the use of a garden hose with a nozzle) in my shop.
climber has-been
Liked 3,590 Times
An aircraft mechanic doesn't touch a plane without a job card with detailed instructions. The plane doesn't fly until the mechanic has completed the work and signed off the job card, and someone else has checked the job card for completeness.
In my shop, mechanics worked from iPads that provided step-by-step instructions on the job to perform, one task per screen, with the instructions usually copied directly from the manufacturers, and they had to check off each task as they went. Mechanics initially balked at the idea, thinking they were far too skilled to submit to such baby sitting. But quality, reliability, and efficiency all improved.
Bikes: lots
Liked 2,932 Times
Not a bad idea. It also provides a higher level of professionalism for the customer to see this kind of thing.
Likes For cxwrench:
Dead but dreaming
Location: Bay Area, CA (East Bay - Contra Costa County)
Bikes: 2020 Santa Cruz Stigmata, 2022 Cannondale Synapse
Quoted: 171 Post(s)
Liked 326 Times
There is no problem washing your bike with a hose or a pressure washer as long as you pay attention to the stream and where it's aimed. I've been washing my bikes for over 30 years and not once have I ever had any issues from doing it.
“Avoid using the high-pressure sprayers you find at pay car washes to clean your bike. The soaps can be corrosive, and the high pressure forces water into bearings, pivots, and frame tubes, causing extensive damage over time.
Many more on uboob.
Bikes: lots
Liked 2,932 Times
You don't really know how many bearing you have killed. That is just lazy. Those baby bike seals are easily breached with pressure.
Many more on uboob.
Many more on uboob.
Quoted: 741 Post(s)
Liked 412 Times
climber has-been
Liked 3,590 Times
Torque recommendations for bike bits aren't typically set according to the application.
They're set according to the fastener. Here are the rated fastener maximums:
M5: 7 N-m
M6: 11.8 N-m
M8: 28.8 N-m
M10: 57.3 N-m
Bike manufacturers universally seem to pick torques approaching but slightly below these fastener maximums.
Quoted: 1249 Post(s)
Liked 1,327 Times
This is how driver’s education is taught. a torque wrench is not absolutely needed in every situation, it depends on the application. I don't use a torque wrench when adjusting the aluminum seat post on a steel frame bike. I doubt anybody used a torque wrench prior to carbon parts. I have seen people, shops, pro mechanics, myself all use a sprayer on bikes with no negative impact.
Likes For Atlas Shrugged:
Quoted: 741 Post(s)
Liked 412 Times
With respect, no reputable school instructs it’s mechanic trainees not to use a torque wrench under all reasonable situations. I assume you feel the same way about the aircraft mechanics servicing any plane you are on. The same goes for using a pressure washer around bearings sealed or not, it’s not a good idea.
Advocatus Diaboli
Quoted: 4750 Post(s)
Liked 1,536 Times
r
r
